Old 05-10-2019, 01:11 PM   #15
jflogerzi
jflogerzi's Avatar
It's the second haft of the tube that goes into the firewall. It's near the back on the passenger side
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
j_ros94 (05-10-2019)
Old 05-10-2019, 03:33 PM   #16
wparsons
wparsons's Avatar
Originally Posted by j_ros94 View Post
No regrets just a little concerned how it got to 13psi peak boost.
What is the wastegate sprung for? Is there any sort of boost controller in the setup? Have you checked the vacuum lines for the wastegate to make sure there's no leaks/blockages?
flickr
Old 05-10-2019, 03:38 PM   #17
j_ros94
Drives: 2017 Subaru BRZ
Doesnt seem to have any leaks but as for blockages im not sure.
Sent from my SM-G960W using Tapatalk
j_ros94 is offline   Reply With Quote
Old 05-10-2019, 03:39 PM   #18
wparsons
wparsons's Avatar
Are you sure you have the T518Z kit and not T620Z? From what I can find, the T620Z is set with a 12psi spring vs the 7psi of the T518Z.
flickr
Old 05-10-2019, 03:41 PM   #19
j_ros94
Im sure it is.
Old 05-10-2019, 03:41 PM   #20
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
33x on pump gas with a 518z kit is very very high in my opinion...
I don't even think with the t620z would be able to get that high on pump
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
The Following User Says Thank You to Soloside For This Useful Post:
wparsons (05-10-2019)
Old 05-10-2019, 03:46 PM   #21
wparsons
wparsons's Avatar
Im sure it is.
I'd check if the actuator is binding or anything, and if the vacuum line has any blockages. Definitely shouldn't be holding 6psi over the spring pressure.
Where is it connected into the vacuum system?
flickr
Old 05-10-2019, 03:50 PM   #22
j_ros94
Alright I'll check that out. Like what greddy told me I should adjust the actuator arm to lower boost?
Old 05-10-2019, 03:55 PM   #23
wparsons
wparsons's Avatar
Is there two (or more) holes on the actuator arm? If there is, you'll want the one that gives the most leverage (further from the pivot).
flickr
Old 05-10-2019, 03:58 PM   #24
j_ros94
Ill update you when I bring it back to the shop to check but i appreciate all the info and keep an eye on it!
The Following User Says Thank You to j_ros94 For This Useful Post:
Old 05-10-2019, 07:51 PM   #25
Irace86.2.0
Irace86.2.0's Avatar
Drives: Q5 + BRZ + M796
What sound tube?
See the red tube on the left going to the sound generator? Remove the rest of the sound generator.
https://www.ft86club.com/forums/showthread.php?t=72263
The Following User Says Thank You to Irace86.2.0 For This Useful Post:
Old 05-13-2019, 05:10 PM   #26
j_ros94
So my car doesn't backfire even while Sasha was dyno tuning my car. Is that a tuning related question or?
Old 05-13-2019, 05:12 PM   #27
jflogerzi
jflogerzi's Avatar
Do you want a pop and bang tune? If so ask your tuner to give you map. With ecutek you have 4 maps you can use and switch between.
Old 05-13-2019, 05:13 PM   #28
j_ros94
I see. I thought it'd just do it itself due to power lol
GReddy T518Z Turbo Kit Richytort Engine, Exhaust, Bolt-Ons 4 09-01-2017 02:39 AM
FS: GReddy T518Z Turbo Jefffrs Engine, Exhaust, Bolt-Ons 2 08-15-2014 01:08 PM
BRZ GReddy t518z NOTORIOUS.BRZ BRZ Photos, Videos, Wallpapers, Gallery Forum 26 04-15-2014 03:15 PM
GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) NOTORIOUS.BRZ Engine, Exhaust, Transmission 21 09-24-2013 07:09 PM
