#15 |
Drives: 2013 FR-S 10 series [755]
2013, hitting 70k miles this year, still running strong!
IG: @rearwheelclub
#16 |
Drives: FR-S 10 Series
Not all 2013 MY have the spring recall, check the VIN first, and like any other sporty car: look for unmodified, maintenance records, and low miles.
#17 |
Drives: 2013 WRB BRZ 6MT
If the spring recall was done at least 2000 miles ago, it will be fine, all failures with the recall service seemed to occur within 500 miles of getting the service done. If I were you though, I'd eat the extra cost of a 2014 or 15 model year car because other common issues were resolved in those model years but if you are getting a particularly good deal on a 13, I wouldn't turn it down based on being a MY13 alone.
#18 |
Drives: jrsc_brz
If anything, avoid buying one that's HAD the recall done, they're blowing up like fireworks after. Toyota is doing a bad job working on the subie engines.
| The Following User Says Thank You to HaXx For This Useful Post: | why? (04-19-2019) |
#19 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
My 14 Monogram Edition has a 1-14 build date. I've put about 8,000 miles on it and the odometer is now about 37,000. I've changed oil twice at about 3500 and didn't notice any significant consumption. However I just discovered a front timing-cover leak. I have only 3-400 miles on it since I cleaned the cover, and no oil on the garage floor yet. I canceled plans to install my new oil cooler last weekend because of the leak. I'll drop the pan in about 1000 miles and see how much oil I'll find at the leak spot.
Other than that, the car has been totally reliable and lots of fun to drive. I don't plan to go FI because of the reliability factor, but do plan a header and tune. That'll pretty much be it for mods. I tend to keep cars for a long time, so if I don't run into an irresistible deal on a Cayman or something similar, I'll probably have the 86 for many years. |
#20 | ||
Drives: 2014 BRZ Limited
I consider this car reliable, and that's coming from someone who lost an engine at 64,000 miles from a fluke failure of the oil pump gear. I would 100% buy this car again.
However, personally I'd stay away from the ones subject to the recall if I intended to rely on the car as my only transportation. There seems to be an issue with the recall work itself sometimes causing more problems than it fixes. The 2014 and later models are not significantly more expensive than the 2013 models, so there doesn't seem to be much of a downside to just restricting your search to the cars made after the batch with the questionable valve springs. Quote:
My general impression (which could be wrong) is that the ones that leak or burn oil generally have either been opened up for service at some point or modded in such a manner that has caused some unusual wear. If I bought a used one that hadn't been modded or beat to shit, I wouldn't expect the heavy oil consumption the Impreza guys are always complaining about. |
| The Following User Says Thank You to extrashaky For This Useful Post: | DarkPira7e (04-18-2019) |
#21 | |
Drives: Scion frs
I had to resort to swapping my engine since I didn’t realize how low my oil was and blew a bearing. Already had 80k on it, might as well get a newer engine Sent from my iPhone using Tapatalk |
#22 |
The BRZs are going at a proportional rate to the FRS so it isn't just the Toyota techs. Not sure they are going like fireworks either but there are certainly more than should be acceptable.
#23 | |
Drives: 2016 Oceanic, "base" model
Consumption has dropped to about one quart per 5k miles since I switched to 0W-30 oil... Back to OP's question, if you are getting an M/T, you might want to get a 2017+ due to throw out bearing issues ($800 repair). The TOB was updated in MY2017 cars. But OTOH I haven't had any issues after replacement. |
#24 |
The Dictater
Drives: '13 Red Scion FRS
Short answer, yes.
Long answer, Yeeeeeeeeeeeeeeeeeeeeeeeessssssssssssss. |
| The Following User Says Thank You to Spuds For This Useful Post: | Tcoat (04-18-2019) |
#25 | |
My car has never lost so much as a drop of oil so this is another thing that seems to be really hit and miss.
#26 |
Only happy when it rains.
Drives: series.blue
I wouldn't touch one that has had the recall done.
If it hasn't been done then you can buy it, but don't do the recall, there is no need for it. |
| Car is running too cool, safe or not safe? | 5150 | Engine, Exhaust, Transmission | 15 | 03-31-2019 11:03 PM |
| At least it kept me safe! | Mailman1117 | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 08-13-2016 08:59 PM |
| Safe to use DOT 5.1? | mechaghost | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 6 | 10-27-2015 04:32 AM |
| Is it safe to top off with different oil? | bizintine | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 8 | 10-23-2015 04:50 PM |
| Are these safe? | mrlewistan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 28 | 03-22-2013 05:22 PM |
