Old 04-15-2019, 08:43 PM   #1
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Chirping in Cabin
Hey guys, just wanted to see if anyone else has experienced this. Getting a chirping in the cabin when the temperature is >60 degrees. Initially I thought it was the blower motor, but it happens even when the HVAC isn’t being used. I’m not sure if it’s fuel pump related because I don’t notice it outside of the cabin. When the chirping is persistent I can hear what seems like a pump coming to a stop when I turn off the car too. On days warmer than 60 degrees I don’t normally hear this. I have an appointment at my dealership next Thursday to see if they can figure it out. Any ideas?
DaBoBo21 is offline   Reply With Quote
Old 04-15-2019, 09:17 PM   #2
hmmmm.
Is the sound tube still hooked up and open?
Does it make the sound regardless of whether or not the engine is running?
Where in the cabin does it sound like the sound is coming from?
Any power mods on your car?
Old 04-15-2019, 09:24 PM   #3
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
hmmmm.
Hey sir,
I have the sound tube off and blocked the hole in the firewall with the A/V cap. It was doing it before I did that though. It only happens when the car is on, and just a cat-back.
Old 04-15-2019, 09:25 PM   #4
The older ones had an issue with a cooling fan in the head unit. Not sure if that is your issue but worth checking.
Old 04-15-2019, 09:26 PM   #5
HKz
Reformed
HKz's Avatar
Drives: '23 GRC, '11 Prius, '04 RAV4
hmm my bet is you're just hearing the normal DI crickets...sometimes they chirp pretty loudly in the cabin especially when warm
my '13 had that noise but I never heard anything similar from my current '16. Hard to believe Subaru didn't incorporate the change on their end..
HKz is offline   Reply With Quote
Old 04-15-2019, 09:33 PM   #6
OK, I'll guess - it might be the car doing a fuel evaporation leakage check (the purge pump running) -
Old 04-15-2019, 09:33 PM   #7
Well it is a totally different HU but who knows maybe the issue survived. Worth checking.
Old 04-15-2019, 09:35 PM   #8
That happens after the car has been shut down for 2 hours. I know some guys love their new car but if they are just sitting there after two hours they should seek counseling.
Old 04-15-2019, 09:46 PM   #9
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
This pretty much happens every time I let it sit over night when the temperature is low and I start it up the next morning. Like I said, when it’s warm it doesn’t do this.
Could it be air in a line maybe?
Old 04-15-2019, 09:50 PM   #10
In the fuel line? - I doubt it.
I'll guess again, maybe it's the fuel pump in the tank?
Old 04-15-2019, 09:56 PM   #11
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Maybe, I’ll have to focus my attention toward the backseat next time it happens. It does sound like a chirpy pump coming to a stop when I turn the car off.
Old 04-15-2019, 10:12 PM   #12
Also, you might listen real close when you turn on the ignition, not starting the car, the pump should be priming itself.
Old 06-20-2019, 10:28 PM   #13
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
Hey guys, wanted to bump this. Was looking through the forum and came across a couple people who have mentioned this, but to be more specific, it sounds more like an erratic/constant bubbling noise from behind the dash, no crickets or anything outside of the car like the HPFP noise (have had that before with two twins, but not this one, this is different).
http://www.ft86club.com/forums/showt...light=bubbling
- It now happens pretty much daily and you can only hear at idle w/ and w/o the HVAC system on. Seems to go away some times when the car is up to full temp, but not all the time.
- Still hear something like a circulation pump shutting off when turning the car off.
- Fuel pump primes just fine before starting the car, no issues there.
It's been difficult to get a video because I can't get anything to pick up the noise over the catback.. Car still operates fine, just want to know what the hell the noise is coming from for peace of mind because it can be pretty annoying to hear every day.. If anyone has experienced this please let me know.. Dealership just shrugs me off about it..
Old 06-21-2019, 12:09 AM   #14
radroach
Drives: car
@DaBoBo21 check that the front defroster isn't on? That's where I had mystery chirps when I didn't realize it cycled the A/C on and off even with the blower motor off.
Chirping. _anthonygd BRZ First-Gen (2012+) — General Topics 21 09-08-2015 11:06 AM
Chirping from HPFP c4lvinnn Issues | Warranty | Recalls / TSB 12 05-25-2015 03:21 PM
Chirping Poll Wilsonk227 BRZ First-Gen (2012+) — General Topics 16 04-18-2014 05:28 PM
TSB Chirping ngabdala Issues | Warranty | Recalls / TSB 10 11-04-2012 10:04 PM
TSB for Chirping mankarn86 Scion FR-S / Toyota 86 GT86 General Forum 1 09-28-2012 05:09 PM
