Drives: Subaru BRZ
Anybody else ?
if so are there any fixes ?
![]() Sent from my SM-G930T using Tapatalk |
#2 |
Drives: Toyota
Still under warranty?
| The Following User Says Thank You to TooSlow For This Useful Post: | Youngmanhenry (04-11-2019) |
#3 |
Drives: Subaru BRZ
One or more of the plastic retainers looks like its not seated properly. Pull the panel back and give it a firm push in. Not too hard though you dont want to blow the airbag
| The Following User Says Thank You to Brz_racer For This Useful Post: | humfrz (04-11-2019) |
#4 |
Have you been trying to run wires down behind it?
Mine used to do that. I finally figured out how to place and push it so that it stayed in place. How, sorry, I don't remember - ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Youngmanhenry (04-11-2019) |
#5 |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
weight reduction
NARFALICIOUS
Noob Poster 1988 | 2016 |
| The Following User Says Thank You to NARFALICIOUS For This Useful Post: | Youngmanhenry (04-11-2019) |
#6 |
[insert cool phrase here]
Drives: BRZ Premium
It's totaled. Sorry.
Don't bother trying to sell it. You'll get maybe $50 with a bj on top. Maybe $100 for some booty play but who wants to deal with that? Then there's option #2 It requires a bit of elbow grease, more like pull out the panel find the plastic clip. Either glue it or replace it. Option #3 Drive car to dealership, cry about how your car is about to explode, tell them the dude on the internet says that it's going to set off the side airbags and the trajectory of that failed cover is going to cut your balls clean off.
Weekend fun/track car - '91 MR2 Turbo Gen3 Old daily driver - '88 MR2 Supercharged |
| The Following 7 Users Say Thank You to Mr.ac For This Useful Post: | HaXx (04-11-2019), humfrz (04-11-2019), jrb363 (04-11-2019), MJones_RB (04-11-2019), soundman98 (04-12-2019), Tcoat (04-11-2019), Youngmanhenry (04-11-2019) |
#7 |
Drives: Subaru BRZ
#8 | |
Drives: Subaru BRZ
| The Following User Says Thank You to Youngmanhenry For This Useful Post: | Decep (04-11-2019) |
#9 |
Mine did that but not quite as bad. I also had some rattling wires up in there. I just wiggled the wires around with a piece of coat hanger (battery disconnected!) heated the cover up with a blow drier (wife was pissed I used it) and gently pushed it back into place. Been there about 80.000 miles without issue now.
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#11 |
Drives: Subaru BRZ
#12 |
Drives: 2013 Firestorm FR-S AT
I removed this panel to run the power wire behind it for my radar detector. The panel slips down into place and snaps in on the bottom and top. Pull the panel out on the top and make sure the top and bottom plastic fasteners are aligned and then snap it back in. This may help: http://www.ft86club.com/forums/showp...&postcount=101
Yes, the rubber seal sits over the panel and helps to hold it in place. |
#13 |
Just the tip
Drives: 2017 DGM BRZ
As already established, your clip is either not seated properly or broken. I had a similar issue when running my dashcam and aftermarket HU microphone wire through that pillar and had to persuade the clip the seat properly.
If you need a replacement, I believe the part number for the upper clip is: 909150037 |
| The Following User Says Thank You to wolffbite For This Useful Post: | Youngmanhenry (04-11-2019) |
