Old 04-11-2019, 12:59 PM   #1
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Inexpensive adjustable rear lower control arm
So, I'm still using stock springs on my 2013 FRS, and would like to keep doing so for the time being. I've got camber bolts and slightly slotted struts up front to get the camber I want, but the rear is still unadjustable with the stock arms.
I would really like to keep the simplicity and streetability of stamped steel arms with rubber bushings, but get some adjustability with an eccentric bushing (which is how these should've come in the first place, IMO).
I've found a very inexpensive OEM-style arm with an adjustable bushing, ULTRA-POWER's K100136. Just curious if anyone has used this particular brand/part number themselves? Kind of hard to screw up an OEM steel control arm, but figured I'd ask anyways.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 04-11-2019, 03:38 PM   #2
Spawn_Of_Creation
Human
Drives: 2015 BRZ Black
SPC lower control arms are basically stock with adjustment.
Whiteline are the same as SPC, but give you an additional .5 degree of adjustment.
"Always listen to experts. They'll tell you what can't be done, and why. Then do it." - The Notebooks of Lazarus Long
Spawn_Of_Creation is offline   Reply With Quote
Old 04-11-2019, 04:01 PM   #3
kch
Senior Misanthrope
kch's Avatar
Never heard of the ultra-powers. SPC is the standard for OEM-style with an eccentric bolt. I've used them for 30k+ miles and quite a few track days with no issues.
Old 04-11-2019, 04:57 PM   #4
venturaII
venturaII's Avatar
I thought I'd read in a thread somewhere that the SPCs will lower the rear...is this true? That makes them a non-option for me if so..
Old 04-11-2019, 04:58 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
SPC works for 99% of the folks out there that don't need bling and don't need to be compliant with autocross rules.
For the remaining 1%, it's usually because they need more adjustment or they want the bling.
Old 04-11-2019, 04:59 PM   #6
mav1178
mav1178's Avatar
SPC arms are identical to stock minus the camber adjustment + the spherical bearing.
Old 04-11-2019, 05:22 PM   #7
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Another vote for SPC here, mine have been holding up fine.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 04-11-2019, 05:53 PM   #8
86league
Drives: '13 BRZ Limited
One other potential downside of the SPC (and I assume the whiteline) is if you are doing alignments/settings yourself without the help of a real-time display of camber and toe -- they can be hard to get dialed-in. There is some slop in the bolts/cam washers leading to a tendency to undershoot/overshoot in my experience.
That said I have about 20 track weekends using my SPC and they have held up fine.
86league is offline   Reply With Quote
Old 04-12-2019, 10:22 AM   #9
venturaII
venturaII's Avatar
Whoa...glad I asked. That's exactly what I want to avoid. Looks like the el-cheapos will be the pick. Can't really go wrong for $25 a piece anyways...time to use this lifetime alignment again.
The Following User Says Thank You to venturaII For This Useful Post:
Tcoat (04-12-2019)
Old 04-12-2019, 10:35 AM   #10
maslin
Benz Tech
Drives: 2017 BRZ Premium
Spherical bearing, not helm joint.
Those arms look like an exact copy of SPC/Moog/etc.
The Whitelines are the same arms with the bearing pressed out and “synthetic elastomer bushings” at the inner joint for SCCA compliance.
Spherical bearing is a normal type of joint used in automotive suspension, not some huge performance upgrade. “synthetic elastomer bushings” tend to puke out every so often and have to be maintained, in my experience.
maslin is offline   Reply With Quote
Old 04-12-2019, 10:45 AM   #11
venturaII
venturaII's Avatar
A Heim joint is essentially a spherical bearing. Kind of like how Kleenex is facial tissue. Heim makes rod ends, standalone spherical bearings, Uniballs, etc....the word "heim" is pretty universally used when this type of bearing is referred to, especially when replacing a rubber bushing.
Ultramaroon (04-23-2019)
Old 04-12-2019, 10:47 AM   #12
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
I've been happy with the Whiteline LCA's. They're basically the same as SPC but painted silver and the bushings are STX legal.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
wparsons (04-12-2019)
Old 04-12-2019, 11:21 AM   #13
maslin
Benz Tech
I’ve never heard a rubber enclosed suspension joint pressed in to an arm referred to as a “heim joint”.
Heim joint meaning an exposed metal bearing with a threaded rod. Like all the “racing” lower control arms.
Stock cars do not come with that style of joint on suspension. Lots of enclosed spherical joints on cars from the factory.
Old 04-12-2019, 11:31 AM   #14
venturaII
venturaII's Avatar
You are describing a rod end, not a "Heim joint", specifically. Rod ends are only radially rated, while spherical bearings are both radially and axially rated. Which I find even stranger, since the lower control arm is essentially a two force arm and only needs a radial rating, really. The axial load is handled by the toe arm. A rubber boot covering the joint doesn't change what type of joint it is, it just makes it a little more weather tolerant.
Or think of it another way; if you buy all your spherical rod ends from Aurora instead of Heim, what are they called then? Chances are, everyone still calls them Heims, the same way everyone points at a box of tissues and says "Hand me that box of Kleenex", even though they're made by Scott.
Diftech Adjustable Rear Lower Control Arms justinco Brakes, Suspension, Chassis 0 03-14-2019 09:41 PM
FS: SPC Adjustable Rear Lower Control Arms skylinekin Brakes, Suspension, Chassis 6 09-09-2018 04:24 PM
SPL Parts Pro Rear Adjustable Lower Control Arms StickThatClutch Brakes, Suspension, Chassis 0 11-21-2016 10:17 PM
WTB - Adjustable Rear Lower Control Arms swift996 Want-To-Buy Requests 0 06-12-2013 01:23 PM
SPC Rear Adjustable Lower Control Arms Bcarlos Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-19-2013 11:56 PM
