CANADA Canada
Old 04-09-2019, 04:25 PM   #57
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Originally Posted by J-Mac View Post
Hey, just wondering if anyone from Nova Scotia has had this recall done. At this point I’m more scared to have it done then just leave it alone. My 2013 FRS only has 56,000km and runs great.......for now.
If it runs great now and continues to run great, I'd forget about it. Cars that had sudden valve spring failure experienced it at very low mileage, from the reports I've read.
If you do have sudden valve spring failure, then take it in and they'll perform the recall work all the same - there is no advantage to having it done early, other than you're controlling when it goes in.
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Dadhawk (04-10-2019), humfrz (04-09-2019)
Old 04-09-2019, 05:28 PM   #58
wparsons
wparsons's Avatar
If a spring breaks, it won't be as simple as the recall. It'll likely need a whole new engine at that point. It'll drop the valve and mash it between the piston and head.
flickr
Old 04-09-2019, 05:43 PM   #59
DarkPira7e
DarkPira7e's Avatar
Forgive me if I'm jaded, but that's essentially what risk you sign up for with this recall anyway
Old 04-09-2019, 09:27 PM   #60
J-Mac
Drives: 13 FRS FireStorm
That’s why I’m so torn. The cars out of warranty and it seems like a gamble either way. I read in another thread that there has been more failed engines from the recall than the actual problem they’re trying to fix.
Did you have the recall done?
J-Mac is offline   Reply With Quote
Old 04-09-2019, 09:46 PM   #61
J-Mac
I recognize your user name from the failure thread. I’d be a bit jaded as well. I feel like either way I’ll never fully trust this engine again. Might have to upgrade to a 17MY. I can’t imagine driving any other car now.
Old 04-09-2019, 10:38 PM   #62
Oh, J-Mac, I'm getting the feeling that you're letting this valve recall thing interfere with you enjoying driving your car.
My 2013 (with < 25,000 miles) has been recalled, but it's running good now, so, I'm in the mind set, iffen it ain't broke, don't let em break it.
If I'm out on the road and a weak/broken spring leaves a valve in the combustion chamber and the piston smashes the hell out of it, I will have it toed to the nearest dealer and trade it in (give it away), for a new car on the lot and continue my vacation.
Meanwhile, I ain't gonna worry about it.
Old 04-09-2019, 11:04 PM   #63
DarkPira7e
DarkPira7e's Avatar
I still don't have my back. They've rebuilt it twice, they still get oil leaks every time they test drive it and have to tear it down again. This is just an issue with my dealership, but given that it feels like a risk to have it taken apart at all I'd try to avoid it. My situation is more fortunate than others - not only do I have a second car, I've got the budget set aside to do a new engine myself if they just can't get it and I don't trust it. Which I don't.
My hesitation aside, I really wouldn't think about it. If your car is still running great, I'm sure it will continue to
Old 04-10-2019, 09:58 AM   #64
wparsons
wparsons's Avatar
I haven't, and I'm even more torn. Mine needs the drivers side valve cover gasket (or sealant, whatever it is) replaced for a slight oil leak and also needs the clutch/TOB replaced. Valve cover is free with the recall, and the clutch would be parts cost only.
So I can let them do it and hope it's fine, or I can pay a shop I trust to pull the engine to do the gasket and clutch, and at that point it'll be getting a new engine since mine has ~176k kms and over 50 track days on it.
I'm leaning towards chancing it since the absolute worst case is it spins a bearing after they "fix" it and I have to pay another shop to swap the engine anyway.
flickr
Old 04-10-2019, 10:28 AM   #65
The recall does cover a repair that results from the broken spring, in the case the recall was not done. Of course, you run the risk of proving that was the issue.
I had mine done early and fortunately there have been no issues. However, at this point, and with over 140,000 miles on the engine, I wouldn't have it done and take my chances. Works case, you get a new engine. Seems OK to me.
Old 04-10-2019, 03:22 PM   #66
J-Mac
No worries. I’m still enjoying it every chance I get. It’s just a toy for me.
I just don’t trust it to keep it long term anymore. This was gonna be a project car eventually.
The Following User Says Thank You to J-Mac For This Useful Post:
humfrz (04-10-2019)
Old 04-10-2019, 03:33 PM   #67
J-Mac
That’s just nasty. And exactly what I’m trying to avoid. I feel bad for anyone with this as they’re daily car. I bought this as a summer toy and have another vehicle as well if things go bad. I’m hoping now that the money I’m saving for a 4x4 winter toy doesn’t have to get used for this car.
Old 04-10-2019, 03:53 PM   #68
J-Mac
That is a tough spot to be in. At least mine works perfectly at the moment. I’m definitely chancing it for now. Just feels too risky at this point. Might have to call around and see if any of the dealerships around here have done any yet. Just for curiosity.
Old 04-10-2019, 04:03 PM   #69
J-Mac
Well that’s good to hear. I wasn’t aware of that.
I can’t imagine it being any harder than trying to prove the tech dropped sealant into the engine and clogging things up. I don’t know the first thing about any kind of engine failure though. Fingers crossed it stays that way.
Old 04-10-2019, 04:19 PM   #70
I guess I should add that's my interpretation of the recall (it has language allowing for reimbursement of persons that had to have work done due to a spring failure). YMMV of course.
valve spring issue? nikitopo Issues | Warranty | Recalls / TSB 1037 05-01-2019 11:55 PM
VALVE SPRING WORLD - PRESS RECALL Trap63 Issues | Warranty | Recalls / TSB 85 03-13-2019 12:38 AM
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
