| AUSTRALIA Australia and New Zealand |
Potato Farmer
Drives: #SLOBRZ
[Aust] - Valve spring recall
Anyone here already been through it? how did it go?
or when are you lined up to get it done? I am booked in for the end of April..
Something something butter..
www.vic86brzclub.com |
#2 |
Drives: BR86
howdy Fudd, going in early May for the surgery which will inlcude some bits & pieces whilst it's all out, so to speak. Who knows what will come of it, hope no extra sealant included :|
#3 | |
Potato Farmer
Drives: #SLOBRZ
What else are you getting done? I am getting my plugs replaced, since they need to remove them to do the job.. saves me a bucket on labour..
#4 |
Drives: Sonic Blue GTS MT
Hi all,
I've had it done and so far, no dramas. I live in a small town in central Queensland and the local dealership (Callide Valley Toyota) phoned me up and invited me to come to get it done. Apparently there's special tooling required for the job that they have to send back, so they wanted to get whatever cars done they could while they had it available. Don't know if that is the case for larger dealerships. I have a Harrop supercharger installed and I wasn't charged any extra for the additional work to remove and reinstall it. I had the spark plugs changed while they was in there, all I had to do was pay for was the parts price. |
| The Following User Says Thank You to BMJ76 For This Useful Post: | fuddbutter (03-09-2019) |
#5 |
Drives: 4wd zooks
Well i choose to wait and see if ten or more can be successfully done , here down under (with no problems caused , including dents and scratches) before i take the risk.
Just not happy with previous work done on my other cars. |
#6 | |
Potato Farmer
Drives: #SLOBRZ
I am going to photograph and go over the whole car before they work on it, also want some sort of warranty for the work in writing too.. I don't want to be left stranded if the motor dies after and them blaming my mods on it.. Already been down that road with the Subi dealership i bought it from, even though they knew the problem i had existed before I did any mods.
#7 | |
Drives: BR86
Plugs are due soonish so I'll get them replaced, apparently they have to come out anyhow. COP's & engine main harness will get inspected & replaced if necessary, TOB will be changed & re-greased properly. I'm asking my dealer if they can install a modded clutch disc plate to cure the racket it makes @ low revs/speeds even I can hear with my noisy rumbly exhaust. HPFP will be changed if they have a new version available. Loan car will be provided, have requested for a new Camry Hybrid for testing
#8 |
Potato Farmer
Drives: #SLOBRZ
I am trying to work out what you want to test it for? Uber driving?
#9 |
Drives: BR86
#10 |
Drives: 2013 WRB BRZ
http://www.ft86club.com/forums/showthread.php?t=133573
http://www.ft86club.com/forums/showthread.php?t=133306 http://www.ft86club.com/forums/showthread.php?t=133095 http://www.ft86club.com/forums/showthread.php?t=133383 http://www.ft86club.com/forums/showthread.php?t=133474 http://www.ft86club.com/forums/showthread.php?t=133550
#11 |
Potato Farmer
Drives: #SLOBRZ
I say that cause Subaru don't bring the cars into Australia, a 3rd party importer does, Inchcape, and they look after the warranty here.
www.vic86brzclub.com Last edited by fuddbutter; 03-25-2019 at 09:04 PM. |
#12 |
Understood. The first link is referring to an Australian vehicle. The others are worldwide.
| The Following User Says Thank You to BigTuna For This Useful Post: | fuddbutter (03-26-2019) |
#13 |
Steve Bodalenko
Drives: Toyota 86 GTS
Have had mine done and ‘SO’ far it’s been fine and my car actually feels a bit more responsive for whatever reason. Perhaps the new springs allow more valve stroke and therefore more intake charge and exhaust extraction.
Have a Harrop install booked for late April so doing as many k’s in it as I can to check for oil leaks and issues. Mine was done by Essendon Fields/Airport Toyota and can’t complain about the job or the service. Only issue, and it was out of their control, was that they couldn’t change the plugs over because there is apparently a ‘global’ shortage of them! Checked with the Subi dealer across the road and they didn’t have any either so perhaps it wasn’t bullshit like I thought! Not a big deal since I’ve just clicked over just 35k kms in the six years I’ve owned the car and saved myself $180. |
| The Following User Says Thank You to Bodalenko For This Useful Post: | fuddbutter (04-01-2019) |
#14 | |
Potato Farmer
Drives: #SLOBRZ
That's reassuring! Which dealer did you go to? Hopefully they have more plugs when i need to go, if they don't, ill find somewhere to get some from so they can do them!
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 10:32 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-09-2019 12:38 AM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 04:35 PM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 08:41 PM |
| I have the valve spring recall information. | meadowz06 | Issues | Warranty | Recalls / TSB | 24 | 12-23-2018 09:44 PM |
