Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 03-21-2019, 04:41 AM   #1
David242gt
Drives: Toyota 86 2012
JO2 RECALL - ENGINE FAILURE
Hi,
My father who is 78 owns a 2012 86, with 85,000klms, which he bought used from a major Toyota dealer with a warranty 4 months ago.
2-3 weeks ago his car went in for the JO2 Valve recall.
On the weekend he went for a spirited drive in the country to enjoy his toy. When he was out in the mountains he called me and I had to collect him with a trailer, as his engine went pop pop pop and seized.
The car has been taken back to the Toyota dealer to discuss what should be done to fix the problem, and they quoted $19,000 to replace/rebuild the engine and did not seem to consider the JO2 recall to be the problem.
I have been doing a lot of reading about the JO2 recall engine failures and his engine failure would seem to have the exact same story.
The recall service was done at 85,908klms, with less than 250klms done after the recall service
What I need to hear directly from any AUSTRALIAN 86 owners who have been in the exact same situation is;
- What process did you follow?
- What were the major disagreements (if any) with Toyota to fix the problem.
- What actions did Toyota take?
- What level of Toyota Australia did you have to contact and who.
- What result was achieved.
I really only want to gain comments from those who have been through the process.
Please leave your comments here, send me a Private Message or contact me via email.
Cheers
David
David242gt is offline   Reply With Quote
The Following 3 Users Say Thank You to David242gt For This Useful Post:
alan.chalkley (03-21-2019), fang_gt86 (03-21-2019), ZZT86 (03-25-2019)
Old 03-21-2019, 05:06 AM   #2
David242gt
here are the photos of the engine
Old 03-21-2019, 07:05 AM   #3
ermax
ermax's Avatar
First off you can see they used the wrong sealant on the timing cover. The instructions are very clear that it’s mandatory to use Threebond 1217H which is gray not black. If they ignored that part of the instructions then what else was ignored.
Do you have any more pictures?
Be sure to add your dad’s car to the registry here:
http://www.ft86club.com/forums/showthread.php?t=133095
The Following User Says Thank You to ermax For This Useful Post:
why? (03-21-2019)
Old 03-21-2019, 08:43 AM   #4
Boomerang
86
Boomerang's Avatar
this whole recall issue worldwide is like a horror movie, hope the manufacturers take responsibility for the complete debarkle that has unfolded..
these cars used to have a great record for reliability and durability but this one recall could ruin all that..
Old 03-21-2019, 08:50 AM   #5
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
Sorry to hear about the car.. This seems to be the first case that has been posted on this forum about an Australian vehicle.
BigTuna is offline   Reply With Quote
Old 03-21-2019, 09:15 AM   #6
Boomerang
86
Boomerang's Avatar
No
Originally Posted by jaseow View Post
It really depends on the mechanic really. I probably got lucky and got a mechanic that knew what he was doing. Im in Perth, Western Australia
I did my recall about 3 weeks ago now and I have no issues (so far). Ive only done about 600-700km on it since then. Im waiting till at least 1000kms before i post in the thread on NO ISSUES after recall.
Old 03-21-2019, 10:31 AM   #7
Vital
Drives: 2015 BRZ
OP, this all has been well documented in these threads.
https://www.ft86club.com/forums/showthread.php?t=133306
https://www.ft86club.com/forums/showthread.php?t=133095
Vital is offline   Reply With Quote
Old 03-21-2019, 10:52 AM   #8
BigTuna
BigTuna's Avatar
Originally Posted by Boomerang View Post
No
I should have been more clear. This is the first FAILURE of an Australian vehicle.
https://docs.google.com/spreadsheets...zow/edit#gid=0
Old 03-21-2019, 07:44 PM   #9
David242gt
Yes I wanted to get first hand experience from a similar AUSTRALIAN as we will have to address the situation to suit our local systems.
Old 03-23-2019, 04:56 PM   #10
Hags86
Drives: Toyota GTS 86
So I had a failure years ago (Direct Injector Seal) which was due to an early ECU ignition map error - since fixed with a software update.
Read about it here https://www.ft86club.com/forums/showthread.php?t=119638 but Toyota were a pack of C*UNTS to deal with, however the dealership was excellent. Only when I took Toyota to VCAT (Victorian Civil Administration Tribunal) did they fix it.
IN your case whilst the dealer did the work, the car no longer has OEM warranty you could well imagine there is some dialogue between the dealer and Toyota about who's fault this was. In my case when it was clearly Toyota's fault they denied it. Now your car is 7 years old and out of OEM warranty they'll be impossible to deal with.
My advice if you get pushback from a well-worded letter, go straight to DEFCON 5. Do everything in writing from now on. You don't want to take them to court where they can lawyer up. VCAT is great as neither side can bring lawyers and there is no ability to awards costs to the other party if you loose. There might even be 'lemon laws' in your state that you can use.
The other thing is $19k is ridiculous. I'd buy a used engine for $2-3k, probably $800 in labour to install it. Jesus, I built a engine that can hold 800hp for less than half that and that included a new block!!
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger.
Hags86 is offline   Reply With Quote
The Following User Says Thank You to Hags86 For This Useful Post:
fuddbutter (03-25-2019)
Old 03-25-2019, 07:06 AM   #11
ZZT86
ZZT86's Avatar
Drives: BR86
. . . & another one . . .
ZZT86 is offline   Reply With Quote
Old 04-09-2019, 12:40 AM   #12
Russell86
Drives: Toyota 86 gts
Recall valve spring
Had my 86 in for recall when they phoned and said ready
Went in to pickup but before I took possession I started it and immediately noticed ticking and rough idle was told that’s normal and it had rough idle when brought in
After arguing for sometime as to who is going to fix they wanted to charge me to look I told them find the problem they said compression down in 3 rd pot could be cause
Went back to get and ticking gone till I traveled 6 ks then started again back in it goes again for a week couldn’t find problem picked it up now getting worse emailed Toyota they said take back to look at but won’t say who paying to look might have to go consumer affairs?
Russell86 is offline   Reply With Quote
Old 04-09-2019, 12:58 AM   #13
ermax
ermax's Avatar
You aren’t alone. Be sure to add your details to this thread:
Old 04-14-2019, 06:54 PM   #14
fuddbutter
Potato Farmer
fuddbutter's Avatar
Drives: #SLOBRZ
Which dealer did you go to?
Something something butter..
www.vic86brzclub.com
fuddbutter is offline   Reply With Quote
australia, failure, j02, recall
Failure After J02 Recall - Discussion Threads mswbrz Issues | Warranty | Recalls / TSB 1654 05-30-2023 03:26 PM
Registry Thread: Failure After J02 Recall DarkPira7e Issues | Warranty | Recalls / TSB 489 05-26-2023 03:46 PM
Catastrophic Engine Failure After Recall Work? MJones_RB Issues | Warranty | Recalls / TSB 20 06-09-2019 10:54 PM
Update on J02 recall failure. msaikhan Issues | Warranty | Recalls / TSB 28 03-20-2019 12:29 PM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
