Drives: '15 BRZ, '05 Acura TL
Tube blocked off on top of manifold?
Hi All,
I noticed that my automatic 2015 BRZ does not have a tube connected to the manifold next to the tube that connects to the PCV valve. What is this tube (drivers side) for? Mishimoto catch can install says that's the brake booster tube but I don't think so. Radium video says that the crankcase vent. I think this is correct. If there's no tube because mine is an automatic, why don't I have a crankcase vent? The port is just blocked off straight from the factory. Last time I checked, I do have a crankcase. ![]() Vic PS. Google search was no help. I couldn't find a single photo of this area with the port blocked off like it is on my car. 1st owner so I know it came like this from the factory. |
#3 |
I've been trying to find this info using search here for the past hour.
"blocked port, tube next to pvc port, plugged port, mystery port, plugged connector on top of manifold etc..... NOTHING" Kindly point me in right direction. |
#4 |
Drives: 2013 frs red
I believe that's plugged from the factory. Probably another vacuum port for diagnostics
#5 |
Drives: 2017 toyota 86
Manual uses that for brake booster. Auto uses something else so it does not need/use it.
#6 |
Because auto doesn't go fast enough for boosted brakes?
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
#7 |
Because compromise ®
Drives: Red Herring
Is that sarcasm? Hard to tell just from reading.
#8 |
Drives: Red Herring
That is sarcasm.
#9 |
The Gunshine State
Drives: '14 BRZ Limited
![]() Current DD: M235i |
#10 |
Auto uses a separate pump.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | FT86.ca (03-22-2019), RedReplicant (05-10-2022) |
#11 |
I may be an idiot
Drives: Winona - White 2014 Scion FR-S
Why? Is there a reason for this? I've been looking for days and can't find a definitive answer. The AT and MT version both have the same Brake Booster part number, but one gets vacuum from the intake Manifold (MT), and the other gets vacuum from the Cam-driven Vacuum Pump on the rear, passenger side of the engine (Where the leaky cam plate is on the MT version). But why?
What's stopping me from just using the plugged port on the intake manifold for brake booster vacuum? If nothing, then why have the pump at all?
Winona, My Wingless Angel Edelbrock SC w/ Flex Fuel - 18x9.5 Titan 7 wheels w/ 265/35x18 Michelin PS4S - Radium Dual Catch Cans - Verus Aero - OEM Brembos - Prototype HVT 6100e Dynamic Dampening Coilovers - JDL 4-2-1 EL / OP / Dual Catted FP w/ Greddy SP Supreme Catback |
| The Following User Says Thank You to Arcadien Angel For This Useful Post: | Tcoat (05-10-2022) |
#12 | |
#13 |
Might be for reading vacuum?
#14 | |
If you transition from throttle to brake in a manual, you get a lot of manifold vacuum. In an auto, you take your foot of the throttle it upshifts (and some CVTs go to idle) and you have little-to-no vacuum. |
| The Following 3 Users Say Thank You to KillerBMotorsport For This Useful Post: |
| Plastic Vacuum Tube for Perrin Inlet Tube | sebastiansim | Engine, Exhaust, Transmission | 5 | 05-04-2018 08:29 PM |
| 2013 intake manifold vs 2017 Aluminium intake manifold | Bobster | Engine, Exhaust, Transmission | 29 | 12-19-2016 10:40 AM |
| wtb: sound tube delete inlet tube | Jimmy817 | Engine, Exhaust, Bolt-Ons | 1 | 12-21-2014 09:15 AM |
| 'Induction Roar Manifold Tube' | White64Goat | BRZ First-Gen (2012+) — General Topics | 1 | 04-28-2013 06:51 PM |
