#15 | |
![]() FRS/BRZs spontaneously combust across the continent. Today at precisely 10:02am thousands of cars all ignited at the same time. All were 2013 models within a specific VIN range. Up to date information indicates that the largest outbreak appears to be in California where a recent recall is mandatory.
#16 |
Only users lose drugs.
Drives: All the time
I'm holding off with mine for now as well...at least, until there's either a change to the bulletin to somehow make sure the the techs are more careful on reassembly, or changing how the actual procedure is done to make it more foolproof. And based on other interesting stuff I've seen in these threads, I think I'm also going to pop the oil pan off and pull the pickup tube and take a look at the screen...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
| The Following User Says Thank You to venturaII For This Useful Post: | Tcoat (03-20-2019) |
#17 | |
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
#18 | |
The recall is specifically to replace the bad parts. Repair of engine damage associated with the part's failure would be a warranty issue, not recall work. They could make my life miserable by denying warranty coverage of the rest of the repair work needed from a valve spring failure if they can show I elected not to have the bad part replaced prior to failure.. Manufacturers can and are ****s like that, on a regular basis..
#19 | |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#20 | |
Drives: 13 Subaru BRZ
They seem to be good at making everyones life hell after they broke the motor... What makes you think that plan is much better
#21 | |
Drives: 13 Subaru BRZ, 02 Audi TTQ
Mine is one of the recalled cars and I feel the same way.
#22 |
I disagree with the comment that they are making "everyone's" situation hell. With the very limited data we have on the post repair failures there are two people they have outright refused to cover the repairs. There are 10 where the repairs have been done without a fight. The other 15 or so either have not contacted the dealer yet or the case is in review. The fear that no dealer will cover it is unwarranted. Of course we pay attention to those where they were refused but at this point they are the minority not "everyone".
#23 | |
You're right, its wrong to use the term everyones. But the previous poster is worried about his motor being blown, due to not doing the recall, and toyota failing to honor their warranty. Seems to me if he has concerns about his local dealership not honoring the terms of the warranty its reasonable to assume he doubts their competence in doing the recall in the first place. |
| The Following User Says Thank You to ybotspawn For This Useful Post: | Tcoat (03-20-2019) |
#24 | |
Drives: frs
I will leave my car alone and stick with regular maintenance |
#25 |
FR Noob
I'm keeping mine "unfixed". There are plenty of used motors that I can easily drop it in if this supposed "ticking time bomb" should go off.
"I'm having too much fun to care about horsepower" - Unknown
6MT FR-S Whiteout:OFT- OTS V2 Stage 2 (93oct & E85), Tomei UEL, Invidia OP, JDL UltraQuiet FP, Ark Grip catback, GS hood struts, Perrin Inlet & K&N drop-in |
#26 | |
When I said I would not have it done it was not through fear of them screwing it up. In fact I said that in other threads well before they started the recall. I just do not feel that the original concern warranted a recall in the first place so why mess with things?
#27 |
JDM Vaping Stance Nation
Drives: 2013 White
I think I got lucky as well. My dealership says he has his "top tech" to work on mine and they were only doing 1 recall a week.
Got mine done a month ago and about 2k miles, with 1 Autocross session a week ago. I'm still going to install a fire extinguisher after I fix the stripped seat bolt.
Clueless
| The Following User Says Thank You to YamahaR86 For This Useful Post: | Tcoat (03-20-2019) |
#28 | |
Drives: 2013 FR-S Argento
I.E. yes there could be a large number of success stories out there we're not hearing, but I'd bet there's a larger number of fail stories we're not even hearing about either. And it's not generalized issues - it's exactly the same issue, every time. Rod knock from oil starvation, being consistently tied to mis-application of sealant (whether it be incorrect bead placement, overuse, or just not letting it cure). And strongly correlated to Toyota, who just doesn't have the experience with putting Subaru boxer engines together like experienced Subaru mechanics. There could be a large # of success stories, but based on this forum sample, I feel there's a solid chance of my engine going south if I took it to my dealer - solid chance meaning more than I'm willing to risk at the moment. I'd rather 'fight the fight' with a dealer to fix my motor post valve spring failure rather than 'fight the fight' after a dealer gums up my oil passages. JMHO |
| Possible recall on the 86 regarding valve spring | tanner | CANADA | 84 | 11-28-2019 10:32 PM |
| Valve spring recall | meadowz06 | Issues | Warranty | Recalls / TSB | 115 | 06-09-2019 12:38 AM |
| BRZ Valve Spring Recall | mrhemi | Issues | Warranty | Recalls / TSB | 6 | 03-01-2019 04:35 PM |
| FR-S Valve Spring safety recall Ħɞ|| | Hypnocracy | Scion FR-S / Toyota 86 GT86 General Forum | 65 | 02-27-2019 12:53 AM |
| Valve Spring Recall | venturaII | New England | 13 | 02-25-2019 08:41 PM |
