69gtojeff, CT86, gravitylover
Old 03-13-2019, 01:19 PM   #57
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Failure After J02 Recall: Registry Thread
Originally Posted by tanner View Post
If anybody cares, I put this into Google Sheets... a little easier to see all of the failures and what not, so feel free to update/add any new failures.
https://tinyurl.com/y2hy5kx4
Legend.
Can you add a total cell for BRZs/Scions and a cell the calculates the average mileage driven after the recall?
Please add this to the OP and request that everyone add their data to the spreadsheet when they make an entry in the thread!
Old 03-13-2019, 01:29 PM   #58
kimkong1981
Vehicle Mileage: ~70000
Vehicle Make: scion
Mileage After Recall Performed: ~72000
Symptom(s): car caught on fire during drive
Failure: yup definitely a failure
State: California
Is Dealership Offering Repair: insurance in process of paying out. Didn’t even bother with talking to dealer, just filed a report with nhtsa.
-Took the car in for the engine valve spring recall at Toyota of Berkeley on Jan 29.
-Got car back, did regular commuting to work for 2 weeks, everything seemed fine.
-took car for drive up highway 1 on feb 17.
-maybe 3 hours in... drove around a turn and saw that it was down hill with two sharp hair pin turns
-tapped brake to slow down.. immediately felt rear tires give out (only going 25 maybe 30 mph btw). Saw the traction control light blink a few times (again slow speed, dry road.. no reason for traction control to engage)
-let off brake, thought, that’s interesting, coasted a little, hit brake again, same thing, traction control light blink, felt the rear end just act a little weird.. traction wise.
-thinking I may have brake issues, decided to downshift from 3rd to 2nd
-after 2nd was engaged, heard a pop, saw the hood jump up as if something inside hit it.
-still going down hill, made it around first hair pin turn, trying to see where I could park the car (highway 1.. along the coast) safely...
-coming up on hairpin 2, felt my feet and legs get burning hot.. looked down, saw flames through the window coming from driverside tire well.
-brought car to stop by hitting brakes and immediately ditched. Just filled up gas 20 miles back.
-fire spread and engulfed the entire car. Total loss
Please be safe 86ers. And be sure to report your problem to the nhtsa!
kimkong1981 is offline   Reply With Quote
The Following 5 Users Say Thank You to kimkong1981 For This Useful Post:
bcj (03-14-2019), Cheeky (03-15-2019), CT86 (03-14-2019), gravitylover (03-14-2019), mazeroni (03-15-2019)
Old 03-13-2019, 01:38 PM   #59
GrantedTaken
The fire is a much better outcome than spending the next few years in court. Start shopping!
GrantedTaken is offline   Reply With Quote
The Following 7 Users Say Thank You to GrantedTaken For This Useful Post:
caus (03-15-2019), CT86 (03-14-2019), ermax (03-13-2019), marco1ca (08-06-2019), Summerwolf (03-14-2019), Teseo (03-13-2019), Turbo (03-14-2019)
Old 03-13-2019, 02:00 PM   #60
tanner
Drives: '10 S4/'13 BRZ/'16 GT4/E30 M3
Done, had to clean up the numbers so an average could be calculated... it's just under 500 miles.
Mike
tanner is offline   Reply With Quote
The Following 3 Users Say Thank You to tanner For This Useful Post:
caus (03-15-2019), msaikhan (03-13-2019), Teseo (03-13-2019)
Old 03-13-2019, 02:42 PM   #61
Crabasitor
Drives: silver A/T 2013 Scion FR-S
Post Engine failed during drive home after recall was performed
Vehicle Mileage: 40k
Vehicle Make: 2013 Scion FR-S, A/T. Zero mods.
Mileage After Recall Performed: 40k
Symptom(s): car lurched and tried to keep chugging for about 6 seconds before stopping, no major leakage noticed.
Failure:Replacement valve spring broke, both valves bent in containing cylinder, #3? piston shredded, spun bearing, crank shaft gouged, crank case deeply scarred.
State:TX
Is Dealership Offering Repair: Yes and everything including a Camry lender free of charge. they have been on hold for parts since january 24th when the incident happened and they should be arriving in about the 22nd of march. There is 2 other cars in the dealership with the same issues so i expect my car to be ready by about early april I'm guessing. i was told that experts were brought in to oversee the repairs.
Crabasitor is offline   Reply With Quote
The Following 2 Users Say Thank You to Crabasitor For This Useful Post:
Dadhawk (03-13-2019), Teseo (03-13-2019)
Old 03-13-2019, 02:52 PM   #62
subaru
Drives: STI
Man what a joke. Be happy you can just move on. I would say do not buy another one as people are getting valve adjustments on their new brz's now and before recall.
If you estimate 1500 bucks - 2500 for all labor parts, paper pushers and rental cars X the cars to fix thats 2-500 million just for the USA. Man subarus stock is going to be reallll bad. I hope it falls to 5 bucks a share and then the little money pusher men think twice about waiting 6 years for an engine recall, or about cheaping out the first time around. Those involved deserve to pay a steep price,
Subaru is the new ford / gm of japan.
subaru is offline   Reply With Quote
Old 03-13-2019, 03:21 PM   #63
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Actually, I believe the failure was the result of Subaru's steel suppliers falsifying QA inspection records for the materials eventually used to make the springs. I don't think this was Subaru's direct fault, per se, unless you just mean them waiting for failures before acknowledging there could be a problem in the first place...
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
The Following 3 Users Say Thank You to venturaII For This Useful Post:
Tcoat (03-13-2019), Teseo (03-13-2019), Ultramaroon (03-14-2019)
Old 03-13-2019, 04:24 PM   #64
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
"Mileage After Recall Performed" is referring to the number of miles you've driven since you got the car back.
Sent from my SM-G930V using Tapatalk
BigTuna is offline   Reply With Quote
Old 03-13-2019, 04:34 PM   #65
One more link in the chain that you missed.
It is probably the steel supplier to the parts manufacturer that sold the parts to Subaru.
Subaru would have had no clue until things started to fail. Even if Subaru tested each spring (not gonna happen) the low failure rate would mean that it could slip through the cracks for a while. This happens in the industry all the time. Just normally doesn't cause such a ruckus.
Don't think the timing was coincidental.
https://money.cnn.com/2017/10/16/new...now/index.html
The Following 8 Users Say Thank You to Tcoat For This Useful Post:
akyp (03-13-2019), gravitylover (03-14-2019), Gunman (03-14-2019), humfrz (03-13-2019), OwlDance (03-13-2019), Summerwolf (03-14-2019), Teseo (03-13-2019), why? (03-13-2019)
Old 03-14-2019, 02:00 AM   #66
ORrooster
Drives: Your FR-S like he stole it.
Originally Posted by DirectorBrandx View Post
At my dealership, four FRSes have now shown up. All are awaiting a Toyota Corporate review.
My car is at our dealership for a week, now. A corporate review is underway and the corporate staff are to be arriving this week to determine what to do about the four FRS failures sitting in their service dept.
Sounds like Toyota Corp.is about to take a giant shit on that dealer. They'll have every pencil pushing penny pincher in there for a Major Audit going over every repair order and debiting any claim without every i dotted and t crossed for ALL WARRANTY CLAIMS after the Field Techs. get done with the Service side of things.
If that 'technician' there doing those jobs has half a brain... he already quit. If he doesn't, the GM and Service Manager (if he's not fired as well) will be showing him the way soon after they pay the $?XX,XXX.oo bill to 'Yota I'd wager.
"99% of life is what you make of it. So if your life sucks, you suck." ~ Mike Muir
ORrooster is offline   Reply With Quote
Old 03-14-2019, 02:05 AM   #67
ORrooster
Updates??
On that topic... Can we get those in chronological order, like in a new post?? Nobody checking these regularly is going to see your updates on your original posts on page 2 if we last read page 6.
Old 03-14-2019, 11:55 AM   #68
ka-titties
Drives: 2013 BRZ Limited 6MT
Y'all wild for thinking this repair could be done without issues. I'm not surprised in the slightest that this type of post-repair fallout is happening.
ka-titties is offline   Reply With Quote
Old 03-14-2019, 01:09 PM   #69
subaru
Drives: STI
guys can you please link the spreadsheet on post#1, thank you.
Old 03-15-2019, 03:21 PM   #70
jesslax32
Drives: 2013 FRS Argento
I just edited my post to reflect that the dealer corrected their error of borking the oil regulator. Car is currently trouble free as of 10 miles past recall work.
'07 Mini Cooper S Dark Silver - traded for a Forester
'15 Mini Cooper Volcanic Orange - traded for the '17
'17 Mini Cooper Electric Blue
'13 FR-S Argento
jesslax32 is offline   Reply With Quote
fa20, failure, recall, spun bearing, subaru, toyota, valve spring
2013 Valve Spring recall - modified (FI) engine thread shiumai Forced Induction 71 08-11-2020 07:21 PM
TSB / Recall thread take over Sigh-on-Rice Issues | Warranty | Recalls / TSB 17 02-19-2019 12:24 AM
CV Joint Failure and Differential Failure AreteAuto Issues | Warranty | Recalls / TSB 26 06-16-2015 06:18 PM
PA Monogram Registry! kazetaro NY / NJ / CT / PA 0 06-06-2014 07:49 PM
Another Detonation thread. (DI failure related) Input Please. Thorpedo Issues | Warranty | Recalls / TSB 15 08-02-2013 08:23 PM
