Old 02-22-2019, 12:03 AM   #1
btan219
Drives: DGM 15' BRZ Limited
Stripped a screw where the tire lug nut goes, how much does it cost to replace?
I lost my stock tire wrench so I used an 8in socket wrench with a 19mm attachment + pvc pipe to get that extra strength since the lug nuts wouldn't budge with just the socket wrench. I'm not sure if this is what caused it, but I stripped two screws, one in the front passenger and the other in the back passenger. Lug nuts won't fully go in. Is it recommended I use a breaker bar next time? Any one's you guys would recommend? I'm kind of new to this.
https://imgur.com/a/mf6sMX0
Here's an image what what I'm talking about. I'm not sure what the part is called exactly. How much would it cost if I went to a shop to replace the front and back passenger? Or is it simple enough that I can do it on my own?
Also, how imperative is it I get this fixed? Like, can I go a while with one missing from the tires? Or is it something I should get fixed asap?
Thanks
btan219 is offline   Reply With Quote
Old 02-22-2019, 12:07 AM   #2
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Thanks
Looks like you’ll need to replace a wheel stud and possibly a new lug nut. Parts should cost around 15 dollars each stud and lug nut, but the labor might be 60 dollars per hour or so if you go to an independent.
Subaru wheel studs are easily stripped, if you have the money you should switch them out with some good after market ones. This is usually caused by over torqued lug nuts though.
N1rve
The Following User Says Thank You to N1rve For This Useful Post:
btan219 (02-22-2019)
Old 02-22-2019, 12:18 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Over torqued nuts sounds possible, if "since the lug nuts wouldn't budge with just the socket wrench"
Old 02-22-2019, 12:39 AM   #4
btan219
Originally Posted by [URL="http://www.ft86club.com/forums/member.php?u=61305"
N1rve[/URL];]Looks like you’ll need to replace a wheel stud and possibly a new lug nut. Parts should cost around 15 dollars each stud and lug nut, but the labor might be 60 dollars per hour or so if you go to an independent.
Thanks for the info. I just want to make sure, the screw part i stripped in the photo is called a wheel stud?
Old 02-22-2019, 01:06 AM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Yes. "screws" in wheel hub are wheel studs, and wheel is mounted on hub with lug nuts torqued onto them. Unless it's bmw, where instead of fixed studs+lug nuts they use wheel bolts, that get bolted into threads of wheel hub.
Old 02-22-2019, 01:19 AM   #6
I'd suggest you take your car into a shop and have them remove all the lug nuts and inspect the wheel studs (the "bolts" that the lug nuts screw on to).
Replace any stripped wheel studs or lug nuts.
I'd suggest you use this type of lug wrench to take off and put on lug nuts. This way you will get even torque applied to the nuts and studs.
btan219 (02-22-2019), soundman98 (02-23-2019)
Old 02-22-2019, 01:39 AM   #7
86MLR
86MLR's Avatar
Use a torque wrench whenever you tighten lug nuts.
Don't let a shop use a rattle gun to tighten lug nuts, never, ever.....
Monkey fisted "tire techs" will daka daka your studs to death.
I also put a very "small" dab of grease on the studs thread and the face of the lug where it meets the rim.
Always start the thread by hand, if it's tight, back it out and try again, you should be able to hand tighten the lug 95% of the way in.
The studs and lugs hold your wheels on, this is a good thing, give them the maintenance and torque settings they require.
Options may vary
Old 02-22-2019, 01:39 AM   #8
GrantedTaken
http://www.ft86club.com/forums/showthread.php?t=125303
I got the $3 Dorman lug bolt installed.
Got a replacement Dorman lug nut for $2 also.
Used the washers, bolt, and electric impact to pull it.
The splines did feel like they lined up.
I got a bunch of M12 and M14 washers at HD for $2.
I also got an M12x1.25 bolt for .50 cents.
Better to use the open nut than a closed lug nut.
DarkSide, that HF tool worked perfectly.
M12-1.25 Zinc-Plated Metric Hex Nut
https://www.homedepot.com/p/Everbilt...d=887480403183
14 mm Zinc-Plated Steel Flat Washer (3-Pack)
https://www.homedepot.com/p/Everbilt...d=887480069587
12 mm Zinc-Plated Metric Flat Washer (5-Pack)
https://www.homedepot.com/p/Everbilt...d=887480024784
Caliper slider bolts (14mm) torqued to 20 ft/lb
Caliper mount bolts (17mm) torqued to 60 ft/lb
GrantedTaken is offline   Reply With Quote
Old 02-22-2019, 01:41 AM   #9
GrantedTaken
[ame]https://www.youtube.com/watch?v=FRB3jD1zXIQ[/ame]
Old 02-22-2019, 01:44 AM   #10
GrantedTaken
@BTan291
You're the same guy who posted this.
Well, what happened with that ?
http://www.ft86club.com/forums/showthread.php?t=126063
Old 02-22-2019, 01:59 AM   #11
86MLR
86MLR's Avatar
You may want to invest a small outlay into a tool and replace all your lugs, safety first
https://www.familyhandyman.com/autom...stud/view-all/
Old 02-22-2019, 02:16 AM   #12
btan219
Originally Posted by GrantedTaken View Post
@BTan291
the dealership was able to replace it with no cost. i specifically requested to have all lugs torqued at the recommended 90lbs. Today was the first time since then I worked on my tires and I guess they over torqued some of them, again! This is why I hate going to the dealership if I can do things on my own. But it looks like replacing wheel studs isn't something I can do without buying extra tools. I'm going to try to find a reputable shop in my Orlando area to get this resolved and bring my own studs and lugs.
Old 02-22-2019, 02:23 AM   #13
Good plan! -
Old 02-22-2019, 02:58 AM   #14
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
It's actually very easy to do in a garage with a basic tool kit.
All you world need to supplement it with is a universal ball joint separator ($20 from harbor freight to pull and help seat the stud), some washers, and an open ended lug nut
I know from experience
EndlessAzure is offline   Reply With Quote
Stripped tail light screw Jajanken86 Issues | Warranty | Recalls / TSB 9 12-11-2017 11:55 PM
Screw in RS-4 (relatively new tire) CB750F Tracking / Autocross / HPDE / Drifting 4 11-24-2017 05:27 PM
Cost to replace pads/rotors on AP Racing BBK c8Face Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 05-02-2016 11:35 PM
Replace Only 1 Tire? / Spare Tire Question chermo12 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 07-28-2015 02:44 PM
Screw / Nail in tire kpamir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-03-2015 01:20 AM
