Old 02-03-2019, 12:58 AM   #1
zaockle
Drives: 2017 Toyota 86
Noise from driver side front wheel well
zaockle is offline   Reply With Quote
Old 02-03-2019, 01:21 AM   #2
Originally Posted by zaockle View Post
Hey all. I've been having an issue the last couple months. In August of last year I had BC Racing RM series coilovers with Swift springs installed on my car. At first all was good. But in late September I started hearing a noise when going over bumps. Not the usual road noise but more of a rumbling like somethings loose. I've had the motorsports shop where I had them installed check it over several times, but they can't seem to find anything. I took it to Toyota, and no big surprise but they blamed the coilovers saying everything else that was Toyota parts looked fine. At this point it's getting worse and I just don't know what to do. I almost want to just swap back to the stock suspension to see if it really is the coilovers. I reached out to BC Racing earlier today via email but they haven't gotten back to me. Wanted to see if anyone has had a similar issue to this, and if so what they figured out.
Here's a video. The little thumping you hear is the sound in question.
Well, that has to be an irritating sound while driving your car.
It's the weekend - maybe BC racing will get back to you the first of the week.
Back-in-the-day, I would guess you had part of your exhaust system bumping up against something. Easily fixed with a piece baling wire.
Maybe the sound is being made by a wheel or brake part and not the suspension. -
I'd suggest you take it into a different auto shop, take the tech for a ride, then ask them to identify and fix whatever is whacked out.
Reminds me of the day that my younger brother had this 1954 Chevrolet. He asked me to take a ride with him to see if I could figure out what was making the noise. Just after we pulled out of the gravel lane onto the paved road, I yelled "stop the car" and I got out and discovered one of his wheels had all of the lug nuts just about to come off -
zaockle (02-03-2019)
Old 02-03-2019, 01:42 AM   #3
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Loose spring or tophat? Also sounds like possibly loose where the coilover goes into the tophat. Easiest way to tell is to get the car off the ground, pull the wheel and start shaking stuff.
Old 02-03-2019, 02:04 AM   #4
Andyxin
Drives: 2017 BRZ WR blue PP
Hi zaockle, this sound is really like the noise I had. I also took the car to various places to check and they couldn’t find anything loose or bad. I think the key point is the noise is transmitted through car body if I'm not mistaken. Thus the parts that make noise most likely are connected to the car body directly. I would guess it is your top hat. I just put some white lithium grease on the spherical bearings of my LCA today and the clunk sound is gone. You can try it since it is pretty easy and cheap.
Andyxin is offline   Reply With Quote
The Following User Says Thank You to Andyxin For This Useful Post:
Old 02-03-2019, 04:40 AM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
imho it's the camber plate, either the top nut is loose or the spherical bearing has worn out. Try tightening the nut with an impact driver first. If that doesn't work than swap the camber plates and see if the noise changes sides. During the swap you should also be able to inspect for any play and save yourself the time of taking it apart again. There's a outside chance it's the sway link but that usually doesn't make noise based on the driving in the video. BC will sell you a replacement bearing no problem,those parts wear over time and eventually need replacing.
ineedyourdiddly
Old 02-03-2019, 03:42 PM   #6
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I understand parts need replacing over time, but I just got these not even 6 months ago and I had just been daily driving the car when I started noticing it. Seems like a bad product if it fails that quick.
Things can work loose after initial install. Though BC is also not known to be of the highest quality. I did have some Verus camber plates that I could never get the top nut to stay tight and it would knock all the damn time. I check my coils(Tien) about every 3 months to make sure the lock rings on the springs are tight. It kind of becomes general maintenance when you have aftermarket parts that don't have the compliance of OEM components.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post:
strat61caster (02-03-2019), zaockle (02-08-2019)
Old 02-05-2019, 12:49 AM   #7
Joveen
Joveen's Avatar
Drives: Bone stock
Check the endlinks as well.
Sent from my SM-N960U using Tapatalk
Joveen is offline   Reply With Quote
Old 02-05-2019, 01:33 AM   #8
ett808
Drives: 86 & CX-5
I had a similar noise but not as often as yours. Check this video to see if it helps.
[ame]https://www.youtube.com/watch?v=4rOifDVVYmE[/ame]
ett808 is offline   Reply With Quote
The Following User Says Thank You to ett808 For This Useful Post:
Old 02-05-2019, 07:56 AM   #9
ermax
ermax's Avatar
Everyone thinks thumps are always suspension related which I think draws attention away from our flawed EPS. Does the sound seem to come directly bellow the steering column down by your feet? If so it could be the EPS unit. The easiest way to reproduce the noise on mine is run over some road reflectors or do some heavy braking. There are a few threads going on this forum about the EPS unit. It’s $1400 to replace.
The Following User Says Thank You to ermax For This Useful Post:
djliquidsteele (06-03-2019)
Noise at the Driver's side of the hood. Exrald Issues | Warranty | Recalls / TSB 24 04-02-2017 05:04 AM
Driver Side Front Wheel chirping shellslinger Issues | Warranty | Recalls / TSB 10 12-03-2015 07:51 PM
Clicking noise in wheel area, driver side Rabbit of Caerbonnog Issues | Warranty | Recalls / TSB 19 02-18-2015 02:59 PM
Creaking/Clinking Noise from Driver Side Touge86 Issues | Warranty | Recalls / TSB 17 08-17-2013 09:20 PM
