Old 01-09-2019, 08:03 PM   #43
JMon85
JMon85's Avatar
Drives: 2019 WRX
Yo thats legit i like it!
JMon85 is offline   Reply With Quote
Old 01-21-2019, 11:13 AM   #44
Wiscocrashtest
Drives: 14 BRZ, 16 FoSt
bump!
Any news on the rallyx spring prototypes? Thanks!
Wiscocrashtest is offline   Reply With Quote
Old 01-21-2019, 03:47 PM   #45
Antonovich
Drives: '13 BRZ, 04 rust bucket Suburban
Doing all this research on how to lift the twins is kind of mindfuck for me! I'm trying to lift my BRZ and put some meaty offroader tires on it. Not just for aesthetics, but for practicality - I have 3/4 busted Enkei TS10 wheels just from daily driving it on our shitty NYC roads!
I've decided to get the 2-inch spacers from Anderson Design Fab, but still not sure about which coilovers and which wheels will fit. When I've emailed Anderson Design, they said it's best to keep stock coilovers because their spacers are solid at the top. But I still want that adjustability.
Will these wheels at least work? 42mm or 48mm offset?
Focal X
As far as tires, I'm thinking General Grabber AT2
Antonovich is offline   Reply With Quote
Old 01-21-2019, 05:15 PM   #46
Racecomp Engineering
Focal X
I'm not really a fan of lift spacers because they don't add any actual travel, just ground clearance. They have their uses but your suspension wont deal with bumps any better.
Would recommend a good strong wheel from a reputable brand. On the lesser expensive side, the 16x7 +35 Sparco Terra will do the trick.
- Andrew
Antonovich (01-21-2019)
Old 01-21-2019, 05:40 PM   #47
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
@Racecomp Engineering, I'm guessing you've talked to them about it but what about a wheel from Braid made for the car?
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 01-21-2019, 05:40 PM   #48
Antonovich
- Andrew
Huh, those Sparco's were actually the other wheels I was thinking about.
And I get the fact that spacers don't add travel. I am mostly thinking of clearance with a bigger 215/65R16 tire. My thinking is that the meatier tire will help absorb the bumps better.
I am now thinking of getting the Subtle Solutions spacers instead. Since they have a hole through, so coilovers shouldn't be a problem.
Old 01-21-2019, 06:11 PM   #49
churchx
churchx's Avatar
Drives: 2014 GT86
Antonovich: i suggest to be careful if choosing too thick of a spacers. I somewhat expect similar issues as to overlowered car but now with too much of a lift. As in geometry issues like changed rollcenter, too much of an angle of axles to now too high placed diff. And if there are parts to correct such things for cars lowered too much, i haven't heard for such for too lifted twins. And if "safe/reasonable" range to not require other parts is often considered within 1" of lowering, i guess it might be similar for lift, as in still reasonable if within 1", even if even thicker spacers exist, eg. like your linked 1.5" ones. Probably because they are reused from imprezas/foresters with similar sized topmounts.
Of course, one is complete rally build with most of suspension parts designed custom anew and strenghtened and with proper suspension knowledge behind .. but if you are in this thread, i guess you plan for "mild rallying" with mostly stock parts? Then imho springs like these + some extra engine protection plate + being reasonable with not too much offroading/jumping should do.
Old 01-21-2019, 07:25 PM   #50
Antonovich
Mild rallying? lol, not even close. I want to do this setup because I busted up 3 out of 4 wheels daily driving on shitty roads of NYC, on Enkei TS10, 225/45R18 front, 255/35R18 back. This "off road" setup is strictly daily driving.
Old 01-21-2019, 07:32 PM   #51
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I read that you busted 3 out of 4 of your wheels. That sucks!
How about scraping though... Do you scrape your front and rear often?
I LIKE TIRES!
Old 01-21-2019, 10:40 PM   #52
Antonovich
Not really. I did scrape it once but no real damage.
Sent from my ONEPLUS A5010 using Tapatalk
Old 01-22-2019, 12:45 AM   #53
Leonardo
Country Boy 4 Life
Leonardo's Avatar
If you are not scraping, and if the lift is not going to give extra travel; I would think about 16s and big tires.
I've seen a ton of posts about running 245/40/18s, which are the same diameter as 225/55/16s. They will fit on stock suspension and will lift your car .55 inch. They would also increase your side wall to 4.9" (pothole proof?)
Older 5x100 WRX 16s are usually a couple hundred in my area. Just ideas...
I LIKE TIRES!
Old 01-22-2019, 12:58 AM   #54
churchx
churchx's Avatar
Drives: 2014 GT86
Antonovich: If you didn't scrape but busted few wheels .. i wouldn't try to lift as much if doing that at all. Rather just get stronger wheels and of smaller diameter, so that tire used is of higher sidewall. Many gravel rally wheels will fit the bill. They won't be light, but they will be extra strong, after all, some of them are meant to finish the race even on punctured tire. Most of 16" of such should clear our stock brakes with ease. There are even some 15" that may fit, but it's harder to find clearing wheel model/size/offset, but possible. Slight acceleration loss from upping tire overall diameter, as eg. Leonardo suggested, for even more sidewall height increase, may help too. Of course, steering may become less sharp .. but then again, one needs to choose, track toy on good tarmac or something that can be driven over awful potholes without minding.
Leonardo (01-22-2019)
Old 02-11-2019, 11:14 PM   #55
Antonovich
Done!
Also, copy-pasta from another thread, hoping more people would see and maybe help me further.
So yesterday I've installed Anderson Design & Fab 2-inch spacers and changed the wheels from 225/35R18 to 215/65R16. Took me like 6 hours (mostly because of my own incompetence). And I got...mixed results. First of all it definitely feels more comfortable driving (which is one of the things I was going for), there is minimal rubbing - mostly at full lock. But I also get a strange knocking sound at the front from small bumps. Like metal on metal. I'm thinking it might be the end links because the actual coilovers sitting much lower now, so the end links or sway bar is hitting something. Maybe I'm wrong, but I'd appreciate any feedback on this issue.
Edit: also I got a little over excited with the impact gun, screwing in the wheel nuts, and I kind of stripped a small portion of one of the wheel hub screws. Is there an easy fix for that?
Chuhatsu Plus MultiRoad lift springs mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 84 11-07-2022 01:57 PM
Where to Lift with Two Post Lift? Don Ivey Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 08-18-2022 09:51 AM
Review: RS*R Down Springs Hiko Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-22-2021 01:42 PM
EZCarLift Easy car lift portable super easy car lift bren5279 Mechanical Maintenance and Tools 16 09-11-2015 02:57 PM
Mach V Springs Review Mikepage Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 10-22-2014 08:55 AM
