#16 | |
First off, if your battery runs all the way down, driving around for a while will not usually bring it back up to speed. For that to happen, it needs to be put on a charger. Secondly, if your older battery would not start the car, after only the car had not being driven for a while. it's most likely time for a new battery. The battery in my 2013 FR-S is starting to slow down. I'm also a light driver in the PNW (many short drips a week). So, enjoy your new battery - ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | e_lunatic (01-08-2019) |
#17 | |
Technically, I'm not allowed to unplug this device unless the port needs to be used for something else, like diagnostics. I'll look into some standalone battery chargers and see if those work. |
#18 | |
According to their web site: "6. Will the Pulse drain my car’s battery power? The Pulse device should have little to no effect on a healthy car battery. Even if your car isn’t being driven, the pulse will not drain a healthy battery for several months." I would suggest that you give your fresh battery a go first. OR you could hook up your car to a "battery tender". Personally, I don't like to leave things plugged into my car's OBD-II port. (I never know when some jealous husband from my past may be tracking me - )humfrz |
#19 |
Rust bucket enthusiast
Mine was getting pretty weak this year so I replaced it. Still started decent in temperatures above 50 degrees. 6 years is good life for any battery that's not sealed in a trunk.
#20 | |
If it doesn't work, I'll just get a new battery. |
#21 | |
Drives: 2015 FR-S
It will never be 100% but that is the proper way to do it. I've already ran mine dead 3 times from the trunk light being left on and did an overnight slow charge and I'm still going. You already got the charger which is good to have anyway to trickle charge every now and then for maintenance. |
| The Following User Says Thank You to Impureclient For This Useful Post: | humfrz (01-07-2019) |
#22 |
Now comes the physical part, where I have to detach the battery from my car, and haul it several floors up to my apartment.
![]() We don't have wall outlets in the underground garage. I hear these things weigh like 40 pounds! |
| The Following User Says Thank You to tzhu07 For This Useful Post: | humfrz (01-07-2019) |
#23 | |
![]() If have to just grab hold of it to carry it, don't wipe your hands on your pants. While you have it in the light, you might as well check the electrolytic level. Add distilled or deionized water ONLY, if necessary. If the battery is grubby, clean it up with water and baking soda. Clean the battery posts and cable ends prior to re-installation. Let's hope it gets revived. humfrz |
#24 |
Drives: 17 86
Some people don't think chimistry be like it is, but it do.
Battery Tender's can do a good job of getting some extra use out of a battery. Battery Tender Last edited by PetrolioBenzina; 01-08-2019 at 01:21 AM. |
#25 | |
#26 |
Battery is out of the car, moved into my 3rd floor apartment unit, and is being charged right now.
Thoughts and prayers... Thoughts and prayers... Thoughts and prayers...
| The Following User Says Thank You to tzhu07 For This Useful Post: | humfrz (01-08-2019) |
#27 |
Hypnocratic Missionary
Mine was replaced when I brought it second hand...a buddy that was a early adopter (2013 BRZ) bought new just replaced his at six plus years
#28 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
March '13.
Still with the original Panasonic. When it goes, it goes. Time enough for another then. Cranking right over at 42deg the other day. We haven't got into freezing temps yet this year.
"I gotta rock." -- Charley Brown |
| Stock Shock Lifespan | TommyW | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 03-06-2017 12:07 PM |
| LCA Spherical Bushing lifespan. | x808drifter | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-14-2016 02:50 AM |
| Stock Suspension Lifespan? | smg1138 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 03-18-2015 01:19 AM |
| Rear brake pad lifespan | ddeflyer | Tracking / Autocross / HPDE / Drifting | 21 | 07-16-2014 02:15 AM |
| Weak battery or bad alternator from factory? | empower-auto | Issues | Warranty | Recalls / TSB | 2 | 09-21-2012 03:17 PM |
