Old 12-20-2018, 12:40 AM   #113
spike021
spike021's Avatar
Originally Posted by geraldjust View Post
YUP! Im able to reprogram it for either animation.
If you want.. i have a 86 cluster but i want a BRZ we can always swap if your looking for one that has that white outline like the FR-S.
Are you also able to enable the live G-meter?
Instagram: @spike.grc
spike021 is offline   Reply With Quote
Old 12-20-2018, 01:57 AM   #114
geraldjust
Drives: MR2, Sliver BRZ
YUP. when it switch it to the GT86 screen it enables the live G-meter!
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
Old 12-20-2018, 01:59 AM   #115
spike021
spike021's Avatar
Ah, but you can't with the BRZ screen? Interesting.
Old 12-20-2018, 02:51 PM   #116
JW89225
Drives: E92
Is it just me or I find it awkward how the 86 has the 7000rpm marker dead center and the BRZ has it a bit off centered to the right side? I think I prefer the symmetry of the 86 more...
2013 Scion FR-S 6AT
JW89225 is offline   Reply With Quote
Old 12-20-2018, 02:52 PM   #117
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It’s just you
Old 12-20-2018, 02:54 PM   #118
JW89225
Drives: E92
I could try to do that but since i dont have a turn key car i might not see the same options as that car. So for now its up in the air about that.
Does anyone know if any aftermaket face guage overlays for the 2017+ clusters?
Thinking of making the GRmn face for the new cluster..
2013 Scion FR-S 6AT
Old 12-20-2018, 02:56 PM   #119
JW89225
Drives: E92
It’s just you
I hope so!
2013 Scion FR-S 6AT
Old 12-21-2018, 05:59 AM   #120
Allen Poe
AT Pleb
Allen Poe's Avatar
Drives: 2014 FR-S Monogram (Firestorm Red)
sounds good to me! i'm pretty close to ordering, should I just have them ship directly to you?
Knowledge is knowing that a tomato is a fruit. Wisdom is not putting it in a fruit salad.
Allen Poe is offline   Reply With Quote
Old 12-21-2018, 06:00 PM   #121
geraldjust
DM me so we can finish up the details.
And yeah. For now the live g-meter is on the gr86 animation screen. Unless there is a different market besides USDM that have these clusters that the BRZ stays and have other features besides the ones we already discovered?.
Eventually if I get myself a second cluster for a cheap price for me to start experimenting with it. Then I can figure out how to switch from F to C easy. Or KM to miles. AC controls from F-C. Etc.. see if I can change just the animation screen. Or font. Or who knows what else is there to change.
Old 01-30-2019, 11:05 AM   #122
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Finally able to get my techstream working last night. You don't need security access to program the cluster for key ignition cars. Interesting that the cluster works, and you can test every function of the cluster, but the car just won't start. Need to get the controls for the menus, but I am happy with it so far.
The Following 2 Users Say Thank You to DustinS For This Useful Post:
Akuma-ZN6 (01-30-2019), Sportsguy83 (01-30-2019)
Old 01-30-2019, 02:52 PM   #123
Akuma-ZN6
Akuma-ZN6's Avatar
Drives: Hot Fire
[quote=DustinS;3179708]Finally able to get my techstream working last night. You don't need security access to program the cluster for key ignition cars. Interesting that the cluster works, and you can test every function of the cluster, but the car just won't start. Need to get the controls for the menus, but I am happy with it so far.
Thanks for the confirmation on techstream am also Key version.
Did you buy your Digital cluster used or new?? I am also thinking to swap mines however I would be getting a new one order cheaper than defi gauges
Akuma-ZN6 is offline   Reply With Quote
Old 01-30-2019, 03:36 PM   #124
DustinS
DustinS's Avatar
Bought mine used. Might be able to get the dealer to program your mileage as well if ordering new.
@geraldjust Are you able to pull the static image files out, say for the right screen? The image with the red gradient? Wondering I can change it to blue to match my cluster. Though I know I would need to dump and recompile the file. So most likely something I will need to send the cluster to you to actually put in the cluster.
Old 01-31-2019, 04:01 PM   #125
geraldjust
i somewhat dumped the flash but everything is just saw images. so need do decrypt the flash but so far no luck. but i am able to program the milage to match up with what you got. Also did you manage to go though the steps to bind the cluster to the BCM? Hopefully if its just that then it should be easy to use. And let me know if you want that directional joystick to control the screen.
The Following User Says Thank You to geraldjust For This Useful Post:
DustinS (01-31-2019)
Old 01-31-2019, 04:08 PM   #126
DustinS
DustinS's Avatar
Okay bummer. Hopefully soon, thank you for your work.
I was able to program the cluster with techstream on my own. It's quick and easy. Took a few seconds once I found what menu it was under. I'll get a video of where it is at when I can get some time in the car.
and will do! Trying to decide if I buy it before the car goes down, or send you the cluster (for mileage change) while the car is down for the clutch job and just have you ship it back with the cluster.
2017 Limited Gauge Cluster halleffect Electronics | Audio | NAV | Infotainment 26 10-22-2020 08:32 PM
2017 GR edition cluster mod vagthomas Cosmetic Modification (Interior/Exterior/Lighting) 63 06-29-2020 05:41 PM
Help! Is there anyway to change the 2017 cluster start up image? slashlee DIY (Do-It-Yourself) Guides 2 11-17-2018 06:36 PM
2017 Limited Gauge Cluster halleffect Cosmetic Modification (Interior/Exterior/Lighting) 0 01-16-2017 04:55 AM
2017 gauge cluster Drakiv Cosmetic Modification (Interior/Exterior/Lighting) 2 11-15-2016 12:32 AM
