Old 04-07-2017, 11:47 AM   #1
peaches
Drives: '14 BRZ Limited
Peache's build
'14 BRZ Limited, white.
Bought it in Akron, OH in July of 2015 as the last 2014 available with 102 miles on it, got a great deal. Traded my MazdaSpeed6 after driving my student's FRS at Mid Ohio.
Never drove it in the winter, moved to south Florida September 2016. I do most of the work aside from alignments and tune. Had Circuit Motorsports change all my fluids and install accessory pulleys since I no longer have a place to work on it.
Car was used for autox in CS and STX, and has been at Mid Ohio, PittRace, NCM and Sebring. Mods have been done as problems arise, mostly for the purpose of having it perform better on track.
Videos can be found here: https://peachesmotorsports.com/videos
Track times
Mid Ohio club course: 1:48.636
Mod Ohio pro course: 1:45.828
PittRace: 2:17.007
NCM: 2:47.646 - only been there once
Sebring: 2:40.27 - only been there once
PBIR: 1:36.2
Suspension & brakes
CSG Spec TEIN coilovers
alignment: -3.5 front, -2.4 rear, 1mm toe out front, 1.75mm toe in rear
HAWK DTC-60 (track only)
StopTech BBK front and rear
Weds TC-105X 17x9 +35 with Hankook R-S4 245/40/17
Cusco steering rack bushings
RBF660 fluid
ARP extended studs
SPC toe arms
Whiteline LCAs
Grimspeed master cylinde brace
Geimspeed strut tower brace
Engine
Jackson Racing radiator
Jackson Racing oil cooler
Mishimoto hoses
CSF filler neck
Jackson Racing SC C38 + HBP
DW 300 fuel pump
ID 1200cc injectors
Jackson Racing 4BAR MAP sensor
Fluidampr pulley
Visconti Flex Fuel kit
EcuTek
custom tune by Delicious Tuning
Nameless header
Nameless 3" catted downpipe\overpipe combo
Nameless mid pipe
CSG Spec Touring catback
Velox fuel door
Velox cam plate
Accusump
Drivetrain
ACT SB7-XTSS clutch kit
Verus forged clutch fork & pivot
Cusco rear diff brace
Cusco transmission mount collar
Cusco engine mounts
IRP short shifter
no spring in the clutch
Interior
OEM Audio + Reference 450Q
Broadway mirror
INTEC high mount brake light
Subaru interior lighting kit (came with the car)
Surabu rubber trunk mat (came with the car)
Block8Head dual vent pod + Innovate oil pressure\temp gauge + Innovate PSB-1 AFR\boost gauge
ATI vent pod
PST gas pedal kit
Gerald Adjust box
Series blue switches
Exterior
18% tint
hitch
THULE bike rack
Perrin short antenna
Helix smoked side markers + OLM amber LEDs
TracSpec hood vents
Grimspeed hood shocks
Valenti smoked tail lights
parts on the way
wish list
suspension bushings
1.5 way diff
peaches is offline   Reply With Quote
The Following 2 Users Say Thank You to peaches For This Useful Post:
aimforapex (12-22-2018), dattran86 (04-07-2017)
Old 06-25-2018, 03:54 PM   #2
peaches
replaced the suspension and had a clutch, mounts, braces and driveshaft installed
Old 07-09-2018, 09:29 PM   #3
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
How's the clutch feel compared to stock? I just ordered one to put into mine. Do you notice the lighter flywheel?
Trueweltall is offline   Reply With Quote
Old 12-16-2018, 03:38 PM   #4
peaches
Sorry for the delayed response. After the break-in period (500 miles) it feels normal, the only thing that happens now because of all the items is that if you don't give it enough revs you'll hear a clatter. Other than that it's hard to quantify the gains, you'll feel a small difference at first but after you get used to it you can't tell.
Old 12-18-2018, 05:33 PM   #5
eastendraceshop
eastendraceshop's Avatar
Drives: '13 Scion FR-S & '17 Toyota 86
Love the set up and the wheel/color choice!
eastendraceshop is offline   Reply With Quote
Old 12-19-2018, 09:27 PM   #6
peaches
Thanks, those Sparcos are gone. I have 2 sets of RPF1s now
Old 12-19-2018, 09:40 PM   #7
peaches
End of season maintenance and upgrades:
- brake fluid flush
- caliper pins greased
- fuel door installed
- new control arms for more camber
- more aggressive alignment
- replaced the track pipe with a real muffler
Old 12-19-2018, 09:43 PM   #8
peaches
A photographer friend came tot he track and took some nice pictures, these are some of my favorites.
Old 12-20-2018, 04:58 PM   #9
eastendraceshop
I see! Really digging the red RPF1's
The Following User Says Thank You to eastendraceshop For This Useful Post:
mistople (12-20-2018)
Old 12-22-2018, 11:20 PM   #10
aimforapex
aimforapex's Avatar
Drives: car
loving the direction of this build. it reminds me so much of my old FRS. Keep it up
aimforapex is offline   Reply With Quote
The Following 2 Users Say Thank You to aimforapex For This Useful Post:
D_Thissen (12-23-2018), peaches (12-27-2018)
Old 12-23-2018, 05:44 PM   #11
Go Frogs
Go Frogs's Avatar
Drives: '19 WRX Base in Lapis Blue
All go and no show = perfect. I like things you can't see that add the most to the experience as it catches people off guard. Car is in the goldilocks zone.
no stickers, no tacked on body work, nothing to draw an attention flag except gold wheels.
the wheels look good, as they always do.
#Savethemanuals
#Savethewagons
#Savethemanualwagons
Dear SoA, what petition do I need to sign to bring the LeVorg 2.0t 6spd to North America?
Go Frogs is offline   Reply With Quote
The Following User Says Thank You to Go Frogs For This Useful Post:
Old 06-05-2019, 02:13 PM   #12
peaches
I couldn't help myself...
JRSC C38 + HBP
JR radiator\oil cooler combo
Mishimoto hoses
DW 300 fuel pump
ID 1200cc injectors
Currently being tuned
Old 06-06-2019, 02:56 PM   #13
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Hey love the post, I noticed you use a OEM sized battery and track the car often. Sorry this is random, but are you interested in a lightweight battery? Shorai is the brand.
https://www.ft86club.com/forums/showthread.php?t=32544
More info here if your interested
Marcoscrdo is offline   Reply With Quote
Old 06-06-2019, 03:16 PM   #14
peaches
Not really, the battery died during the install so I replaced it with an Optima red top. More interested in the capacity than the lightness
The Following User Says Thank You to peaches For This Useful Post:
Marcoscrdo (06-06-2019)
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 08:52 PM
[B is for Build] BRZ resurrection build im_topher Member's Car Journals 49 03-05-2018 10:41 AM
CJO's Build Oliva95 Member's Car Journals 0 03-17-2016 07:04 AM
Superpenguin's "Not Another Build Thread!" Build Thread superpenguin Member's Car Journals 7 06-17-2015 05:00 PM
No build date on passenger side sticker, how to determine build date? BBYZILA Scion FR-S / Toyota 86 GT86 General Forum 5 01-20-2015 11:14 PM
