Old 07-15-2012, 07:03 AM   #505
FTEIGHTSIX
Switched to the dark side
FTEIGHTSIX's Avatar
Drives: 91 & 95 240sx KA-T SOLD, 2013 BRZ
A 4AG swapped into one of these would be excruciatingly slow.
FTEIGHTSIX is offline   Reply With Quote
Old 07-15-2012, 07:07 AM   #506
inz
Drives: GTi-R
At least it'd be a Toyota engine :P
And hey, I said revised!
They're not THAT bad, and if Toyota fiddled with them ie added VVTi and upped the compression maybe added their D4 injection system... Could have been pretty cool.
inz is offline   Reply With Quote
Old 07-15-2012, 09:35 AM   #507
Apex Chase
El Presidente
Apex Chase's Avatar
Drives: it like I stole it!
Originally Posted by inz View Post
Toyota marketed this car to the enthusiast/modifier market, and yet they used a flat 4 engine and made the PCD 5x100... Seems to hinder the target market a little don't you think?
In the short term, yes. But that is the beauty of the free market. Just wait until SEMA rolls around and see what all comes out. Last year the Camaro and 4 door Wrangler were the HOT cars but I am betting the FRS/BRZ will be everywhere this year.
Apex Chase is offline   Reply With Quote
Old 07-15-2012, 09:39 AM   #508
Don@Accelerated
Don@Accelerated's Avatar
Originally Posted by Psycho_Sid View Post
Don,
Great work! Just a few questions. Is that turbo setup to be water cooled? (ports on the side of the center section) And is the wastegate gonna stay vented to atmosphere or will it be recirc'd to the downpipe?
The Turbo is water cooled. However I have not got the fittings to plumb it yet. As far as the waste gate goes. My car is open and will remain open, but recirc is an option. The kit will have a few options and upgrades .
Don
Don@Accelerated is offline   Reply With Quote
Old 07-15-2012, 12:32 PM   #509
Memphis
Memphis's Avatar
Drives: Scion FantasticRoad-Sex
Don
Why you no answer PM?
Memphis is offline   Reply With Quote
Old 07-15-2012, 12:53 PM   #510
Cheddar
Saving them pennies...
Hmmm Id there a BOV in the system?
Cant seem to find a picture that shows one.
Cheddar is offline   Reply With Quote
Old 07-15-2012, 01:13 PM   #511
Don@Accelerated
Probably not in those pictures on here. There is a Tial Q in the system.
-Don
Old 07-15-2012, 02:48 PM   #512
rusty959
Drives: DGM BRZ limited
Originally Posted by Coheed View Post
hp is related to mass flow rate, not boost. a slightly larger turbo will make more hp on a given psi.
larger turbos have better flow characteristics and provide higher VE and scavenging. All with less retained heat, lower intake temps, and less tendency for knock in most cases.
A knock limit on a GT25 may be 6psi, but upgrade to a GT30r and you may find that 8-10psi is safe.
Yes, but that isn't the point of what I said. Setup A set to 3 psi makes X hp. Setup A set to 6 psi makes Y hp. In basically any case assuming good tunes, 6 psi on setup A will make more power than 3.
So to a point there is reason to spout off hp guesses, because obviously there is a limit to how far we can push this engine in reasonably stock form. But, shift what you consider a reasonable safety of margin, up the boost a hair, and you are making a different level of hp.
rusty959 is offline   Reply With Quote
Old 07-15-2012, 03:05 PM   #513
FTEIGHTSIX
FTEIGHTSIX's Avatar
Don't forget the 4G63 and more importantly, the 4AGE.
Imagine if they'd reworked/revised the 4AGE for the new 86... If only. Im waiting for someone to drop a 4AGE-F20C-SR20DE/VE combo into one of these. 2J's are cool and all - but they're a little bit of overkill...
Just a tad.
You did say revised, but you also said ^^^^
Sorry, I guess I was confused because you threw in all those other engines that actually exist and could be possibly swapped in.
Old 07-15-2012, 03:24 PM   #514
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Don
Water fittings not fitted yet? Are you going to dyno and tune the car tuesday without them?
Silverdub is offline   Reply With Quote
Old 07-15-2012, 03:36 PM   #515
jedibow
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
Bingo. Also a can of MAF cleaner is about 8 bucks,
My number one reason is no cutting. No hacking the harness. Period.
I was wondering if the length of the harness had anything to do with it.
Slow FRS, I agree with the pros you listed, however if you properly seal the draw through, and run a by pass valve, then you maintain the advantages of blow throw, with the additional benefit of increased off boost throttle response.
G
Originally Posted by ImAwesome
Great info in here. arghx7 what do you do?
He's obviously a very knowledgable landscaper.
jedibow is offline   Reply With Quote
Old 07-15-2012, 04:29 PM   #516
slow_frs
Drives: turbo scion tc
There is no issue with this, you can run a water cooled Turbo on just oil, also with the location of the turbo so far downstream the cooling isn't needed
G
The bypass doesn't quite do as well, and yes the harness would have ha to been extended toward the back of the engine where te intake is, gotta also remember what I said about the IAT sensor being on the maf
slow_frs is offline   Reply With Quote
Old 07-15-2012, 04:29 PM   #517
Don@Accelerated
If they do not come. Yes.
Old 07-15-2012, 06:36 PM   #518
Coheed
Coheed's Avatar
Drives: DGM BRZ Limited
Just a tad.
I only stated engines with chain-driven 86x86mm construction
Coheed is offline   Reply With Quote
accelerated performance, brz forum, brz forums, brz turbo, brz turbo kit, fr-s turbo, fr-s turbo kit, frs turbo, frs turbo kit, scion fr-s turbo, scion fr-s turbo kit, scion fr-s turbocharger, scion frs turbo, scion frs turbo kit, scion frs turbocharger, subaru brz forum, subaru brz forums, subaru brz turbo, subaru brz turbo kit, subaru brz turbocharger
Accelerated Performance 2013 BRZ Intake Dyno Testing Video Don@Accelerated Engine, Exhaust, Transmission 109 05-17-2013 12:24 PM
Accelerated Performance 2013 BRZ Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 135 09-04-2012 12:24 AM
Accelerated Performance 2013 BRZ/FRS Exhaust Systems Don@Accelerated Engine, Exhaust, Bolt-Ons 24 07-07-2012 08:05 AM
Hello from Accelerated Performance! Don@Accelerated Announcements, Contests, Giveaways 5 07-04-2012 09:14 PM
