Old 12-06-2018, 11:58 AM   #15
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Originally Posted by DarkPira7e View Post
A lot of people give me shit for defending the Azenis, but I've had them intermittently for about 10 years on at least 8 different cars. I always go back to them. They've gotten far better as time has passed, too.
They're certainly at the top of the bang-for-your-buck list, although there are many options that will ultimately outperform them. Nothing you'd notice on the street though.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 12-06-2018, 12:19 PM   #16
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Oh I guess I neglected some important information. They're heavy 23lb XXR wheels. I had wheels that were a 17x8 previously that were 22lbs a wheel (5zigen wheels) and responded extremely well.
Those are all pretty heavy. My DD wheels are slightly larger than yours (18x9), but only weigh 20 lb. The 17x9 wheels I use for autocross weigh 17.6 lb. So they are 1" wider than your previous 17x8s, but weigh significantly less. STOP BUYING HEAVY WHEELS!!!
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
Old 12-06-2018, 12:23 PM   #17
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Haha that's the point of this thread. I am either using wheels I already own that are small and 17lbs a piece, or getting a set that's under 20lbs a wheel.
Stang70Fastback (12-06-2018)
Old 12-06-2018, 12:31 PM   #18
StraightOuttaCanadaEh
Wes
How much heavier is an 18" tire than a 17" one in equivalent spec?
Instagram: @gt86ws
Old 12-06-2018, 02:32 PM   #19
RayRay88
Drives: 2017 86 860 Special Edition
The car isn't driven very hard and it's my DD, I've found that the last set of 200tw tires I had lasted for two years before I voluntarily parted with them, they still had 70% life- I will take what you've asked literally and confirm that I don't drift and will have junk tires for autocross if I partake. I will admit an r compound would be a huge waste! I also want to confirm that I'm looking for increased turn in response compared to the 245s. I like a super stiff sidewall and solid tread blocks. It honestly could be that I had the wrong tires in this size and am scarred because it gave me a perceived lack of turn in. They are Goodyear Eagle F1 Asymmetric 2.
From my NA Miata days I came to love the Falken Azenis, and it is definitely apparent that the 200tw segment has great size variety in a 16" wheel. I admit, I'm also hoping the increased profile makes life better on our roads.
Can't comment on what tires have stiff sidewalls, but I get what you're after. Maybe a more commonly known stiff sidewall 225 on a lightweight 17x9 might give you enough stretch/stiffness to bring back that crisp turn in?
RayRay88 is offline   Reply With Quote
Old 12-06-2018, 02:45 PM   #20
DarkPira7e
DarkPira7e's Avatar
That'd be a nice treat! God knows if I had the boss' permission I'd have 17x9 RPF1s or some OZs
Old 12-06-2018, 02:56 PM   #21
Stang70Fastback
A.K.A. Starlord
Not QUITE the same width, but as far as the Michelin Pilot Sport 4S, a 255/35R18 tire is 23 lb, whereas a 245/40R17 tire is 22 lb. So the weight difference is rather minimal.
However, both are significantly heavier than the OEM 215/45R17 size, which is only 19 lb.
If you're only going to run a 225 tire size, then don't use a 9" wheel. Use something narrower that won't stretch the tire.
The Following User Says Thank You to Stang70Fastback For This Useful Post:
StraightOuttaCanadaEh (12-06-2018)
Old 12-06-2018, 07:33 PM   #22
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Why? Some race teams use 18x9 with 225/40s.
I LIKE TIRES!
Old 12-06-2018, 07:49 PM   #23
churchx
churchx's Avatar
Drives: 2014 GT86
Yes, it's possible with stretch, but as for 9" wide wheels in general case minimum is 235, ideal 245-255, max 265, it might be outside optimum what tire/wheel are designed for. From gains - reduced sidewall flex, from losses - increased chance of tire debeading from rim, risky if happens due high speed/side-g turn, and also slight loss of competitiveness via carrying unnecessary wheel weight. Why they choose to run with 225? Most probably of certain class rules regarding tire limits. Why they keep using heavier wheels and overstretch? Who knows actual reasons. Maybe subjective handling feel change inspiring extra confidence in particular driver due sharper steering feel. Or that wheel needed to clear some specific BBK. Or that is some specific non generic tire used, eg. some race slick that might be used on wider width range. Or they keep using same wheels with different tires depending on weather or class regulations. However, in generic case with generic tires on generic wheels, overstretching imho is not optimal. It may have it's use in past for illegal street racers / drifters using stretching as hack to enhance somewhat handling by reducing sidewall flex of then worse performance tire selection or cheap non performance tire usage due tight budget, but these days with much better tire offering for reasonable prices or better cars/better suspension, imho not needed.
SuperTom (12-07-2018)
Old 12-07-2018, 12:32 AM   #24
Colin86
Drives: 86
Edelbrock supercharged on e85 here. Dynoed at roughly 330whp. Currently on 215/45/17 mpss on stock wheels.
If conditions are right on the street I've gently rolled into first and maintained a decent amount of traction, although there's almost always a little slip. If conditions aren't right first gear will completely break away. Second can be rowdy, but it's uncommon to completely light the tires up the way first occasionally does. Things are drama free in third gear and above, but the car continues to pull hard.
Honestly I feel like if I swapped to a 3.7 FD traction wouldn't be half bad, first is just so short with this power level and stock gearing. For what it's worth I'm wanting to go with a 17x9 and run 255's although most of that is for the road course.
Hope this helps!
Colin86 is offline   Reply With Quote
The Following User Says Thank You to Colin86 For This Useful Post:
DarkPira7e (12-11-2018)
Old 12-07-2018, 11:18 AM   #25
RayRay88
Most R-Comps are wider than the stated 225, I'm willing to bet he could pull it off with very minor, if any, stretch. That minor stretch/undersquare shoulder might give him some steering feel and sharpness back.
The Following User Says Thank You to RayRay88 For This Useful Post:
Old 12-07-2018, 01:46 PM   #26
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
Hope this helps!
But but but this goes against what most internet car forum guys think! Impossible! Putting 330whp down with stock tire size!!!!11!!!
Glad to see your post man. Most people will just say you need 245 or higher because of X while being factually wrong.
Trueweltall is offline   Reply With Quote
Old 12-07-2018, 02:24 PM   #27
RayRay88
You could put that power down with a 165. But lets see how greasy/overheated your tires get after a few hard pulls, or sustained abuse like on a track.
Old 12-08-2018, 12:49 PM   #28
Colin86
Drives: 86
For what it's worth my 215 MPSS's have handled many 20 minute HPDE sessions without complaining or getting greasy (65-80 degree ambient). Had to air out as they gained something like 15+psi, but otherwise they performed admirably for what they are.
MPSS's don't offer the grip of a more track focused tire, but traction never fell off.
200tw, cheapskate, yolo
Putting a '18 86 bumper on a BRZ? 370zBRZ Cosmetic Modification (Interior/Exterior/Lighting) 4 04-09-2018 01:40 AM
Putting Some BRZ parts in a FR-S? Sazexa Scion FR-S / Toyota 86 GT86 General Forum 15 09-21-2015 08:55 PM
Dynamics difference between 16inch 205s and 17inch 215s tyres light AFRICA 21 10-11-2014 02:47 PM
How much are you guys putting down on your BRZ? 86design BRZ First-Gen (2012+) — General Topics 138 04-19-2012 09:20 PM
anyone putting TRD parts on their BRZ?? poormans_LFA BRZ First-Gen (2012+) — General Topics 33 03-10-2012 03:17 PM
