#20119 |
Drives: 17 Asphalt 86
My black Friday splurge arrived today and is now on the car.
Corsa catback. ![]() It sounds fantastic, better than in videos I've seen. Noise is there when you want it, and quiets right now to near stock when you are cruising not into the pedal. |
#20120 | |
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
#20121 |
Drives: 2015 Scion FR-s Release series 1.0
Oil & Filter Changed (AMSOIL XL 0W-20)
#20122 |
#20123 |
Not really pic worthy, but I installed the steering rack limiters from the verus brake ducting kit over the weekend. Three spacers takes away the last half turn lock to lock.
I'm not rubbing anymore now, which is very nice. While doing that, I found about five pounds of rocks from Streets of Willow Springs in the undertrays. Coincidentally, my high RPM rattles have all disappeared!
#20124 |
Drives: 2015 FR-S
I installed a magic trunk button. Now I can turn the trunk light off or on manually when the trunk is open.
This is so when the trunk doesn't fully close, it doesn't completely drain the battery overnight., so I will keep it in the off position until I actually want it on now. Switch that fits exactly in the preexisting hole on that latch mechanism. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 ![]()
#20125 | |
#20126 | |
Drives: red 2014 FR-S
Nice Install. Have you had a problem with leaving your trunk open? you could have just installed a led bulb and it should easily burn all night without draining the battery. |
#20127 | |
Drives: 2015 FR-S
Yep. I've drained the battery 3 times dead now. I even removed the black trunk bumper things to make it easier to
close and still didn't shut it fully. This is a 100% fix for no more dead batteries from that light being left on. Quote:
I also installed a LED strip light in there that is crazy bright so that might be why it fully drained the battery overnight. |
#20128 | |
#20129 |
Drives: 2015 FR-S
#20130 |
#20131 |
Drives: 2015 FR-S
#20132 |
Drives: Subaru BRZ
| Tags |
| :popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
| Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
| Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
| If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
| Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
| Got my VIN today... | Enemies | BRZ First-Gen (2012+) — General Topics | 63 | 04-12-2012 10:19 PM |
