| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 | |
Only users lose drugs.
Drives: All the time
They're certainly at the top of the bang-for-your-buck list, although there are many options that will ultimately outperform them. Nothing you'd notice on the street though.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
#16 |
A.K.A. Starlord
Drives: 2015 Series.Blue
Those are all pretty heavy. My DD wheels are slightly larger than yours (18x9), but only weigh 20 lb. The 17x9 wheels I use for autocross weigh 17.6 lb. So they are 1" wider than your previous 17x8s, but weigh significantly less. STOP BUYING HEAVY WHEELS!!!
![]() Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos! You can also find me on Instagram, and on Facebook. |
#17 | |
Rust bucket enthusiast
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Stang70Fastback (12-06-2018) |
#18 |
Wes
How much heavier is an 18" tire than a 17" one in equivalent spec?
Instagram: @gt86ws
#19 | |
Drives: 2017 86 860 Special Edition
Can't comment on what tires have stiff sidewalls, but I get what you're after. Maybe a more commonly known stiff sidewall 225 on a lightweight 17x9 might give you enough stretch/stiffness to bring back that crisp turn in? |
#20 |
That'd be a nice treat! God knows if I had the boss' permission I'd have 17x9 RPF1s or some OZs
#21 | |
A.K.A. Starlord
However, both are significantly heavier than the OEM 215/45R17 size, which is only 19 lb. If you're only going to run a 225 tire size, then don't use a 9" wheel. Use something narrower that won't stretch the tire.
| The Following User Says Thank You to Stang70Fastback For This Useful Post: | StraightOuttaCanadaEh (12-06-2018) |
#22 |
Country Boy 4 Life
Why? Some race teams use 18x9 with 225/40s.
I LIKE TIRES! |
#23 |
Drives: 2014 GT86
Yes, it's possible with stretch, but as for 9" wide wheels in general case minimum is 235, ideal 245-255, max 265, it might be outside optimum what tire/wheel are designed for. From gains - reduced sidewall flex, from losses - increased chance of tire debeading from rim, risky if happens due high speed/side-g turn, and also slight loss of competitiveness via carrying unnecessary wheel weight. Why they choose to run with 225? Most probably of certain class rules regarding tire limits. Why they keep using heavier wheels and overstretch? Who knows actual reasons. Maybe subjective handling feel change inspiring extra confidence in particular driver due sharper steering feel. Or that wheel needed to clear some specific BBK. Or that is some specific non generic tire used, eg. some race slick that might be used on wider width range. Or they keep using same wheels with different tires depending on weather or class regulations. However, in generic case with generic tires on generic wheels, overstretching imho is not optimal. It may have it's use in past for illegal street racers / drifters using stretching as hack to enhance somewhat handling by reducing sidewall flex of then worse performance tire selection or cheap non performance tire usage due tight budget, but these days with much better tire offering for reasonable prices or better cars/better suspension, imho not needed.
| The Following User Says Thank You to churchx For This Useful Post: | SuperTom (12-07-2018) |
#24 |
Drives: 86
Edelbrock supercharged on e85 here. Dynoed at roughly 330whp. Currently on 215/45/17 mpss on stock wheels.
If conditions are right on the street I've gently rolled into first and maintained a decent amount of traction, although there's almost always a little slip. If conditions aren't right first gear will completely break away. Second can be rowdy, but it's uncommon to completely light the tires up the way first occasionally does. Things are drama free in third gear and above, but the car continues to pull hard. Honestly I feel like if I swapped to a 3.7 FD traction wouldn't be half bad, first is just so short with this power level and stock gearing. For what it's worth I'm wanting to go with a 17x9 and run 255's although most of that is for the road course. Hope this helps! |
| The Following User Says Thank You to Colin86 For This Useful Post: | DarkPira7e (12-11-2018) |
#25 | |
Most R-Comps are wider than the stated 225, I'm willing to bet he could pull it off with very minor, if any, stretch. That minor stretch/undersquare shoulder might give him some steering feel and sharpness back. |
| The Following User Says Thank You to RayRay88 For This Useful Post: | DarkPira7e (12-11-2018) |
#26 | |
Drives: 2016 Subaru BRZ
Glad to see your post man. Most people will just say you need 245 or higher because of X while being factually wrong. |
#27 | |
You could put that power down with a 165. But lets see how greasy/overheated your tires get after a few hard pulls, or sustained abuse like on a track. |
#28 | |
Drives: 86
MPSS's don't offer the grip of a more track focused tire, but traction never fell off. |
| Tags |
| 200tw, cheapskate, yolo |
| Putting a '18 86 bumper on a BRZ? | 370zBRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 04-09-2018 01:40 AM |
| Putting Some BRZ parts in a FR-S? | Sazexa | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 09-21-2015 08:55 PM |
| Dynamics difference between 16inch 205s and 17inch 215s tyres | light | AFRICA | 21 | 10-11-2014 02:47 PM |
| How much are you guys putting down on your BRZ? | 86design | BRZ First-Gen (2012+) — General Topics | 138 | 04-19-2012 09:20 PM |
| anyone putting TRD parts on their BRZ?? | poormans_LFA | BRZ First-Gen (2012+) — General Topics | 33 | 03-10-2012 03:17 PM |
