Old 07-15-2012, 03:16 AM   #589
FRSjeff
Drives: FR-S (red manual)
Originally Posted by Ebay View Post
My dealer warned me to only use 93 octane; it was nearly empty when I picked it up (employee purchase price doesn't come with full tank) did notice inconsistent idle shortly after purchase but not since getting gas at trusted source. Have had same issue with my Q45 which also runs on premium.
That's going to be tough to do here in California when all the gas stations use 91 octane as their premium option.
FRSjeff is offline   Reply With Quote
Old 07-15-2012, 01:20 PM   #590
bneale
bneale's Avatar
Drives: Scion FR-S
Originally Posted by Hanzo View Post
Try a different brand of gas.
It doesn't seem to be anything to do with the gas. I just filled up yesterday with 93 from Chevron. I can get my idle to drop in neutral just by activating the AC while the car is running. I'll record a video with my phone today and post it for you guys. But just to be clear, these are the steps I'm taking:
1 - with the car running in neutral, turn the fan on full without AC. Idle should be around 800 or 900 to start.
2 - activate the AC by pressing the button. When I do this the idle drops to 400. This is when I feel a small shudder. Then the idle will return to 900 on its own.
I have no CEL yet and I also do not have a chrip.
On my car, I can repeat these steps and have done many times yesterday. It was hot yesterday so I had time to play with the AC and that's how I discovered this.
Now I need to go get some cone marks off my front bumper. Lol.
bneale
bneale is offline   Reply With Quote
Old 07-15-2012, 03:26 PM   #591
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
It kinda feels like a slight misfire at idle. I feel it every so often. No CEL light, still drives smooth, doesnt sputter. But I guess maybe its the hot weather that affects the idle with no wind blowing by. Ill wait till it cools down later on the year before I take it in to the dealer.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 07-15-2012, 04:31 PM   #592
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
That's normal. Its on every sti ever and on my brz.
blu_ is offline   Reply With Quote
Old 07-18-2012, 12:48 AM   #593
Tad_07
Drives: 06STi, 98RSTi, 62VW
Has never happened on my 04 STI or V4 STI swap wagon. Didn't happen on my 97 Coupe or my 02 WRX either.
I have an issue with the idle at random. Whether its right after I've come to a stop or just sitting there for a minute stuck at a light. Has happened with the a/c on and off, same for the brake pedal being pushed or not. Told my dealer about it today since I went in for my first oil change.
Tad_07 is offline   Reply With Quote
Old 07-18-2012, 02:05 AM   #594
RandomHero
SW5 Driver
RandomHero's Avatar
Drives: Asphalt FRS
I have definitely noticed an occasional rough idle while decelerating in this car. Didnt realize so many people had the same thing.
RandomHero is offline   Reply With Quote
Old 07-18-2012, 01:44 PM   #595
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
IDK what to say. First, I don't know what you are talking about. IF you are talking about a small hiccup that almost feels like a single miss every once in a while at idle, its at least very common on newer ones. My 07 STI had this "hiccup", my friends 10 had one, and coworker with an 04 told me his did as well. Most people, including myself, just chalk it up to the hard motor mounts.
Here is a thread on the STI forums for the hiccup.
http://www.iwsti.com/forums/2-5-lite...ling-idle.html
Here is a thread on idle dips as well FYI. Part of why I say this is normal, unless your car is violently shaking and throwing CEL's.
http://www.iwsti.com/forums/2-5-lite...-5k-miles.html
Old 07-19-2012, 01:16 AM   #596
Tad_07
No hiccups on any kind on any mine but I'm a maintenance freak and ocd about every mod. I have group n mounts and stiffer depending on which one of my cars we are talking about. Never hunted on iwsti or nasioc for the issue but guess I should check it out just in case. I know idle dips are normal (usually once you start to mod them) but its not good that my brz has almost died out from it a number of times now and probably would have if I hadn't fleathered the gas.
Old 07-19-2012, 01:43 AM   #597
Northside
Drives: Civic FD 1.8L
. . . but its not good that my brz has almost died out from it a number of times now and probably would have if I hadn't fleathered the gas.
The cars with the idle dip issue don't die now because they are new and the ignition system is still operating efficiently. Wait a couple years when the wirings, connectors, sensors and the rest of the D-4S System are a little worn out and has lost some of that "brand new car operating efficiency" and I see these engines dying out randomly.
An idle dip is not normal especially for a car that is stock and brand new.
Northside is offline   Reply With Quote
The Following User Says Thank You to Northside For This Useful Post:
sierra (07-19-2012)
Old 07-19-2012, 11:27 AM   #598
brillo
Drives: 2013 Firestorm FR-S
can't the ECU tuners set the idle a bit higher say 75rpm? that migh smooth things out with the A/C etc....the manufacturers always set idle low for emissions reasons and sometimes a small bump is all that is needed.
brillo is offline   Reply With Quote
Old 07-20-2012, 10:51 AM   #599
kramerica_industries
kramerica_industries's Avatar
Drives: 2013 Ultramarine FR-S
I just picked up my Ultramarine FR-S yesterday afternoon and put 130 miles on cruising around town/highway. When I was at highway speed I also heard a "chirp" about every 30 seconds roughly. It sounds like what Hawaiian posted - it sounds like the noise a smoke detector makes when it's low on batteries. It sounded like it was coming from the interior not the engine. Not sure what it is.
kramerica_industries is offline   Reply With Quote
Old 07-20-2012, 10:51 AM   #600
Chirpity chirp chirp
Originally Posted by Hawaiian View Post
I've noticed a "squeak" or chirp similar to when a fire alarm is low on batteries. I have sensitive ears from years of working as a sound technician, and it bothers me a little. Once you notice it, it's hard to ignore.
I'm positive it's related to the DI.
Old 07-20-2012, 11:37 AM   #601
Mcdj18
Drives: Toyota FR-S
I'm having the same sound. It sounds like its coming from the trunk area in my case. It drives me nuts!!
Mcdj18 is offline   Reply With Quote
Old 07-20-2012, 11:56 AM   #602
karma003
auto-crosser/drifter
karma003's Avatar
Drives: 2013 scion FR-S black M/T
Originally Posted by carbonBLUE View Post
they did, its a part of the calibration i guess, engine trying to figure out how low it can idle without dying i guess :P new engines and ecus are weird...
Agreed. When I worked at mike Shaw Toyota in corpus christi, when we would do the ecu recalls on corollas I would be instructed to haul Ass down the back roads (id go to 100-120mph then slow all the way down for each turn. It's so the ecu can recalibrate its self & relearn its boundrys. That's from what I was told. Didn't know that til I worked there.
karma003 is offline   Reply With Quote
A Small Easter Egg avusblue Scion FR-S / Toyota 86 GT86 General Forum 28 06-29-2012 12:38 AM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 02:21 AM
Received my FR-S with a small ding Neurytic Scion FR-S / Toyota 86 GT86 General Forum 10 06-03-2012 01:53 PM
Isn't 6-10 miles on a new car kinda high? houseofsuffering BRZ First-Gen (2012+) — General Topics 45 05-15-2012 01:32 PM
Kinda make me worry! (Radiation related thing) EJ20 Off-Topic Lounge [WARNING: NO POLITICS] 32 05-09-2011 01:58 AM
