Old 12-02-2018, 11:40 PM   #1
CokeZero
CokeZero's Avatar
Drives: 2015 brz
Project Restore Life
Well to start off, I bought a 2015 Subaru BRZ Series Blue. It's a flood car and my intention is around a 700hp ls2 street build. But for now I'm just trying to get the car back going like factory before I swap it.
The previous owner replaced the computers due to the flood but some things still aren't working.
The cluster doesn't come on. The car will not go into accessory mode or run or start. The hazard indicators flash in the cluster when their on.
The cluster, the clock, the radio, the power windows, the heated seats all do not work.
The lights, interior lights, horn, hazards all work fine. The car just won't turn on. (The obd port does get power too)
Ive replaced all 3 ecms, checked all fuses, made sure the battery was good, tried holding key to start button, nothing is working.
[ame]https://www.youtube.com/watch?v=M5KOtsy0Zfg[/ame]
The obd 2 port does work. when I put a dongle on there it lights up. But I thought you had to be in the "on" position to be able to program anything.
In this pic #1, #6 and #7 were replaced.
Would them not being programmed cause the cluster not to light up? I assumed it still would. maybe even turn over, just not start. But the previous owner told me its because all the computers need to be programmed that's causing this.
The Toyota dealership in my town said they can't reprogram mine that only a Subaru dealership can (which i don't have in my town)
I've checked all the fuses and swapped around some relays. I've put the original computers back in and switched out every combination of the three.
Kind of clueless where to go from here. I don't wanna take it to the dealer for program and them tell me something else is wrong and charge me anyway
CokeZero is offline   Reply With Quote
Old 12-03-2018, 02:53 PM   #2
CokeZero
CokeZero's Avatar
Drives: 2015 brz
Well it looks like I may go ls3 Instead of ls2 because I found a company in Australia that sells a plug n play ecm for 500 bucks and everything works
Old 12-03-2018, 08:56 PM   #3
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
good luck
SuperTom is offline   Reply With Quote
Old 12-03-2018, 10:31 PM   #4
CokeZero
CokeZero's Avatar
Drives: 2015 brz
Originally Posted by SuperTom View Post
good luck
Old 12-04-2018, 05:02 AM   #5
Tk rocket
Drives: Prius
if ur gonna swap a motor cause you have at least do something that is cool
rb26
rb25
sr20
1jz
2jz
rotary engine
but not another lame ls swap
Tk rocket is offline   Reply With Quote
Old 12-04-2018, 08:40 AM   #6
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
rb26
rb25
sr20
1jz
2jz
rotary engine
Obvious troll is obvious.
Old 12-04-2018, 08:31 PM   #7
CokeZero
CokeZero's Avatar
Drives: 2015 brz
rb26
rb25
sr20
1jz
2jz
rotary engine
Rb26 would be cool but I'm def staying with a LS.
This is why I was a little biased to the LS2, here is my old GTO.
[ame]https://www.youtube.com/watch?v=LARnhiwkOV0[/ame]
But after talking with the Australian company, they have an affordable plug and play setup for a LS3 where everything works. for the LS2 only most things work. So I'm currently sourcing a LS3 drive train and researching cams because I want this one to sound even more of a beast than my GTO.
The Following User Says Thank You to CokeZero For This Useful Post:
JeremyR (12-04-2018)
Old 12-04-2018, 08:35 PM   #8
JeremyR
JeremyR's Avatar
Drives: 2015 BRZ Limited
plug and play LS3 setup doesn't sound too bad! What company offers the kit??
REALMS BRZ Build Thread
HKS|Parts Shop MAX|Battle Version|ADVAN|Beatrush
JeremyR is offline   Reply With Quote
Old 12-04-2018, 09:16 PM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Oh, shit. You on ls1gto.com at all?
https://www.ls1gto.com/forums/showthread.php?t=441667
That's my old car. Best car I ever owned hands down.
Had a street sweeper HT cam in mine and it sounded nasty. You always want a bigger cam though, lol.
Old 12-05-2018, 12:45 AM   #10
CokeZero
CokeZero's Avatar
Drives: 2015 brz
AGT Engineering.
Only lurked on the forum. I sold my gto a while back it was a 06. Can’t wait to get this BRZ sounding like that.
The Following 2 Users Say Thank You to CokeZero For This Useful Post:
JeremyR (12-05-2018), Summerwolf (12-05-2018)
Old 12-06-2018, 12:24 AM   #11
CokeZero
CokeZero's Avatar
Drives: 2015 brz
Alright, I got the swap ordered. LS3’s are considerably more than LS2’s. It should be here by Christmas. Now I get to do a little research and find a cam I want. As well as list things I should do to the eng before I install it into the car.
Summerwolf (12-06-2018)
Old 12-07-2018, 08:07 PM   #12
CokeZero
CokeZero's Avatar
Drives: 2015 brz
Well I called all 3 dealers that are around me. The earliest one has an opening is next Saturday (15th) I gotta rent a trailer to take it over there (2 hrs away) and hopefully just recoding is all it needs to get the cars basic functions back.
I have techstream and a cable that should be here hopefully by tomorrow so that I can play with it a little bit and see if I can figure some things out.
Old 12-08-2018, 04:27 AM   #13
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Good luck with your swap!
Originally Posted by humfrz
I'm old and lazy
Old 12-08-2018, 04:15 PM   #14
CokeZero
CokeZero's Avatar
Drives: 2015 brz
Thanks, I'm going to need it.
Techstream didn't come in today so i tried my cheap little blutooth adapter. You can see obd has power. just cant get into on mode to read anything. Hopefully techstream will let me in to see a few things. I made an apt with the dealer 2hrs away for next saturday the 15th.
[ame]https://www.youtube.com/watch?v=wUjSle82qWQ[/ame]
Headlight Restore kit YamahaR86 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 18 04-30-2019 04:19 PM
Restore 1 Stay Fresh Car Care Cleaning and Detailing 0 05-03-2014 05:26 PM
Headlights Restore FRS_Sovereign Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 09-28-2013 01:57 AM
Garage Life: We bring your dreams to life! Garage Life Southern California 0 08-17-2012 08:33 PM
