Drives: 2018 Ford Mustang EB Premium 6M
TRD springs
Am deciding if I want to lower my brand new car or not. I like not scraping anything so if I do lower it I will use the TRD springs as it only lowers a bit more than half an inch. Have a question for TS owners or anyone with the sachs dampers who may have used the TRD springs. How is the ride quality? I really do not want to stiffen up an already stiff ride. Really would be nice to lessen "the gap" but only if there is no negatives involved. Thanks
Don
Modern warriors saddle iron horses of chrome
#2 |
Drives: 86
They lower 1", not 0.5"
Another thing to think about is spring rates. The RS*R Superdowns for BRZ lower the car about 1.2" but they are softer than the TRD or RS*R 86 versions in the rear. RS*R Superdown BRZ Front 3.16kg/mm Rear 3.88kg/mm RS*R Superdown 86 Front: 3.16kg/mm Rear: 4.49kg/mm TRD (allegedly Eibach Pro-Kit) Front: 3.6kg/mm Rear: 4.9kg/mm |
#3 |
Country Boy 4 Life
I only scraped 2 or 3 times in 70K miles lowered 1". I had Eibach Prokit springs.
IMO, there is no downside to installing them. I have coils now; many downsides mixed with some up too...
I LIKE TIRES! |
#4 |
I stand corrected they do lower an inch. I thought I saw 15mm some where. But do either of the above suggestions take into account Sachs dampers vs stock dampers? Or would that really not matter too much?
Don
#5 |
Where could I find the info on the spring rates that I have in my 2019 86 TRD SE? Dampers and springs are what the BRZ TS would have. Would love to know if the lowering springs are softer, firmer, or equal to what I have. Thanks
Don
#6 | |
The ride is fine except when I hit a bump fast enough to hit the stops. Think they would be fine with the Sachs. The TRD are made by Eibach but that does not mean they are the same. I think they would be fine as well though.
#7 | |
Drives: 86
Most people will tell you to get RCE Yellow springs which are about 4.5kg/mm front and rear. RS*R have the softest spring rates. |
#8 |
Drives: 2013 FR-S Series 10
You will stiffen up the ride, there's no free lunch here. Less suspension travel = more jarring impact on the big bumps. Small imperfections will be fine, if anything the small stuff will be softer, since the shocks are now a bit underdamped versus stock.
Honestly depends on the roads where you are. I would look at the RCE yellow springs, they lower a little under an inch. Get camber bolts for the front while you're in there, and max out your camber. |
#9 |
BRZ ts dampers are not the same Sachs of the PP/TRD USA
| Review: Swift Sport Springs vs RCE Yellow springs on B6 Shocks | EGOBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 02-15-2018 09:21 PM |
| Widest wheels without rubbing on stock springs with eibach springs ? | H214M | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 10-09-2017 12:41 PM |
| [PA] [NJ] RCE Tarmac 2 coilovers w/ 400lb springs. Optional 11/13k swift springs | leunglambs | NY / NJ / CT / PA | 3 | 06-09-2017 03:49 PM |
| WTB: RCE yellow springs or eibach prokit lower springs fr/brz | Gt86-turbo | Want-To-Buy Requests | 0 | 03-08-2015 04:18 PM |
| Swift Sport springs/or any springs.. regrets ? | rikdrt1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 04-21-2014 10:10 PM |
