Old 07-14-2012, 08:16 PM   #57
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Toyota part number is SU003-02911 in case anyone was interested.
Im gonna order a few gotta rack mine up and check it in the next few days.
Touge Monster is offline   Reply With Quote
Old 07-14-2012, 08:23 PM   #58
ft86Fan
ft86Fan's Avatar
Drives: FR-S, Exige S, Miata
Originally Posted by ahausheer View Post
That's the hole that should be capped with the rubber grommet during PDI. Water and road debris can get up there and eventually cause rust or rattles but I would personally worry about a small animal getting up there and taking a shit or dying. Ive opened my hood and found poop on top of the engine because an animal found it to be a warm dry safe place to take a nap in the winter.
Thanks. Of course my dealer just takes the grommet out of the glove box and throws it away. I don't think they even have or read the PDI instruction for this car .
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield
'95 Miata (Montego Blue)
ft86Fan is offline   Reply With Quote
Old 07-14-2012, 08:27 PM   #59
ft86Fan
ft86Fan's Avatar
Wow, this is difficult to find. This is the only place I can find and they are $3.68 each before shipping. http://www.toyotapartszone.com/oem/t...003-02911.html
Old 07-14-2012, 09:08 PM   #60
mr. slim
SoCal86
mr. slim's Avatar
Drives: '13 Whiteout FR-S
Someone needs to post up the whole PDI check list so everyone can do it themselves.
.: SUPER KAWAII :.
.: BUBSQUAD :.
.: LivinLow :.
.: FRS86 :.
mr. slim is offline   Reply With Quote
Old 07-14-2012, 09:10 PM   #61
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
So it looked like no one posted up pics of how this area looks from the factory and I'm quite single/bored so I went outside and got'er done
Make sure you don't break any of these little buggers while you're doing this.
Decided to do a quick detail while I was out there, shamelessly dropping in a clean roof picture
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 07-14-2012, 09:13 PM   #62
Touge Monster
I couldn't check the availability right now but I have a feeling it might take alittle while to get
Old 07-14-2012, 09:15 PM   #63
ft86Fan
ft86Fan's Avatar
Its in the shop manual.
http://www.ft86club.com/forums/showthread.php?t=8374
Old 07-14-2012, 10:31 PM   #64
|-Goku-|
|-Goku-|'s Avatar
Drives: 2011 Civic Si
If anyone is missing the plugs, you need to call your dealer and be like "WTF!"
You shouldn't have to buy part that should already be included
|-Goku-| is offline   Reply With Quote
Old 07-14-2012, 10:34 PM   #65
ft86Fan
ft86Fan's Avatar
True that.
Old 07-14-2012, 10:53 PM   #66
Blue86
Drives: Sonic Blue 86GT Manual
Just put some gaffa tape or similar over the holes while waiting for the grommets.
I was joking about water getting into this car because I'm so used to a few little drips coming in from my targa roof on my MR2 on very wet days
Last night (quite wet) i did notice a bit of condensation on my rear window when i got into my car after being out for a few hours
Blue86 is offline   Reply With Quote
Old 07-14-2012, 11:32 PM   #67
Blue86
Ok... so I just checked my car and the rubber grommets are definitely there and I've checked the strut tops for water/dirt etc and its bone dry and clean.
So it seems that these grommets in place will sort it all out.
Old 07-15-2012, 01:16 AM   #68
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Is this the hole you guys are talking about? The opening is only 1.5" long and 0.5" wide. Its on both side of the car. I don't see any grommets in the glove box.
Attachment 10415
there is small uncovered hole, in the bottom right corner of the picture, is it normal ?
adprokid is offline   Reply With Quote
Old 07-15-2012, 01:18 AM   #69
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
How many plastic plugs they put in the glove box ?
Old 07-15-2012, 01:34 AM   #70
|-Goku-|
|-Goku-|'s Avatar
There should be 2...one for each side
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 03:56 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 03:57 AM
Impressive boot space! BD AUSTRALIA 14 08-24-2012 05:30 AM
Fatal FRS Flaw!! Skin Scion FR-S / Toyota 86 GT86 General Forum 4 07-12-2012 05:21 PM
Pics of rear passenger area with plastic removed JRitt Cosmetic Modification (Interior/Exterior/Lighting) 20 06-12-2012 09:17 AM
