| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
Drives: it's grey
This is a direct changeover with no ill effects or fitment issue. |
#16 |
I Love custom Turbo kits
Drives: Limited BRZ
I wonder if the Stoptech BBK front hats are big enough to fit the front hubs, then either re-drill them or get a same size Subaru but with 5x114 pattern.
#17 |
Drives: Frs
So in the rear the stock rotor fits over the new hub and we can just redrill the stock rotor?
#18 | |
Drives: it's grey
You could use the rotor you already have with the PBM drill guide. Absolutely. The subject car here has about 65k miles and was on the original rotors so we swapped em out.
hot dogs are sentient beings
#19 |
Drives: Frs
Alright thank you very much!! Very glad you made this post
#20 | ||
Drives: Scion FR-S
Thought I better submit this so anyone seeing this does not make the same mistake I made.
#21 | |
Drives: it's grey
well shit. I guess my base circle measurements didn't factor for the uneven curvature of the pad bracket. Realistically the solution is exactly what you did in clearancing it but that doesn't change that my statement is wrong. Can you take photos of how much you had to remove to make it work and I will amend the write up.
#22 |
Do you have a picture showing the 4 nuts holding the rear hub? You mention removing them from the rear but don't show it. I need to change my hub bearings and am apprehensive about trying this in my driveway. Some good pics would definitely help. Thanks.
#23 |
Drives: '13 Argento FRS
Did some searching and was trying to find our stock size rotor in 5x114, seems to be that they only come in that size for other Subaru models which are 5x100
Any other rotors that you might know of that are not too wide? |
#24 | |
Drives: Scion FR-S
#25 | |
Drives: Scion FR-S
#26 | |
#27 |
Drives: Scion FR-S
#28 |
Drives: turbo frs
Hi
Thank allot for this threat Just i need to know Could I use legace gt 2005-2009 Roter + caliber + hub?? At the front ?? If yes good If no why?? Coze here lots of salvage legace gt I can use thim for this project |
| WTB: STOCK BRAKES | Jetbill | Want-To-Buy Requests | 1 | 04-23-2015 08:09 AM |
| convert into 5x114.3 | guslucatero | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-14-2015 04:37 PM |
| Stock brakes too small for stock wheels | ndsleep612 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 44 | 04-11-2014 09:24 PM |
| What's the average/your baseline full-oem/stock dynojet numbers? & convert to fly HP? | fooddude | Software Tuning | 5 | 03-31-2014 07:41 AM |
| convert drum to disk brakes | DIG1992 | Other Vehicles & General Automotive Discussions | 2 | 11-09-2011 05:04 PM |
