Drives: frs
lowered, scraping on bumps
Hey guys,
2013 frs with ISC coils, under 1 in lowered. Coils are on somewhat soft setting. I got 225/40/18 on 18x8 +45 rims. I'm hearing rubbing or scraping on bumps. I think the tires are rubbing the top of the fender liner on bumps. My suspension already pretty stiff, a little bouncy in fact. I still have at least 1 or 2 finger gap between wheel and fender. Do all the lowered guys just deal with the occasional rubbing or scarping when going over bumps. or is there a magic fix? Thanks. Last edited by msaikhan; 11-16-2018 at 07:30 AM. |
#2 | |
Country Boy 4 Life
PICS? What do you mean your wheels are scraping on bumps? With those specs, your wheels should not rub. Your bumper may be scraping or somewhere under your car.
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | wparsons (11-15-2018) |
#3 |
Drives: 2014 FR-S
That's what I'm wondering, "wheels scraping on bumps"? Do you mean the car is scraping the road while your going over bumps or your tires are rubbing on the car?
Scraping is used for car meeting road/bumps. Rubbing is used for tires meeting fender and/or fender liners. I am lowered about 2" and I will scrap on the occasional speed bump if I am not careful or a parking garage transition, but scraping is pretty rare. As far rubbing I have none. Other then height my coilovers are set pretty comfortable, maybe a little bit stiffer then stock, and preload is set to a recommend street setup, nothing fancy. |
#4 |
Reformed
Drives: '23 GRC, '11 Prius, '04 RAV4
wheels are scraping on bumps? are you going over speedbumps fast as fuck or something? either you too low for your own good or you're trying to overcome physics...
#5 |
Drives: frs
* i meant the TIRES are scraping the top of the fender on bumps. Wheel is not scraping anything. sorry for confusion
| The Following User Says Thank You to msaikhan For This Useful Post: | Leonardo (11-16-2018) |
#6 |
Weight Weenie
Drives: 15 FR-S
A "bouncy" ride means you need to dial the coils in to be stiffer. You need less travel.
| The Following User Says Thank You to new2subaru For This Useful Post: | Leonardo (11-16-2018) |
| driveway scraping | Toyarzee | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 01-20-2015 07:18 AM |
| Solution for Clamp Scraping? | DemonRawr | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 12-08-2014 12:54 AM |
| Lowered on coils- scraping | Dispect | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-04-2013 04:41 PM |
| Scraping metal noise? | Gost | Issues | Warranty | Recalls / TSB | 0 | 03-14-2013 09:11 PM |
| How to avoid scraping your lowered vehicle | PMok | DIY (Do-It-Yourself) Guides | 9 | 11-20-2012 07:49 PM |
