Old 11-13-2018, 07:40 PM   #183
WVAsphalt
Drives: 2016 Asphalt FR-S
I read the first 100 replies and didn't see this question addressed: I apologize if I missed it. Is the custom sway bar required, or is that just to offset the extra weight up front with the kit? Can other aftermarket sway bars be used is my main question, really.
Sent from my SM-N950U using Tapatalk
WVAsphalt is offline   Reply With Quote
Old 11-14-2018, 01:21 AM   #184
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
The oem sway bar is straight, the one included dips down to clear the turbo.
The Following User Says Thank You to Kiske For This Useful Post:
Joveen (11-14-2018)
Old 11-14-2018, 10:30 AM   #185
WVAsphalt
I was afraid that was the case.
Old 11-14-2018, 11:13 AM   #186
Mrc@ptuning
Mrc@ptuning's Avatar
Drives: S1000RR
Our turbo system requires that we manufacturer a custom sway bar to clear the placement of the turbo. With that said, we made our sway bar is 21mm which is larger than stock (18mm) and most will run a larger diameter bar when upgrading their sway bars. Our kit also includes whiteline adjustable end links. So you're basically getting upgraded front swaybars and end-links in the price of the kit. There was no point in us making a custom front sway bar in the stock diameter since most of our customer upgrade their suspensions along with adding more power.
Mrc@ptuning is offline   Reply With Quote
Old 11-14-2018, 11:18 AM   #187
WVAsphalt
Right, I understand, and that's a really nice bonus that there's a sway bar with the kit. It just makes any previously purchased sway bars obsolete. What rear bar do you guys recommend running with it?
Old 11-14-2018, 11:18 AM   #188
WVAsphalt
Also, a lot of sway bars are only sold as a set.
Old 11-14-2018, 11:45 AM   #189
Mrc@ptuning
Drives: S1000RR
We offer a rear 18mm bar, but we are currently out of stock on it. It depends on your other suspension and wheel tire setup, but you can stick with stock rear or 16mm to 18mm rear. It all depends on your driving style. Their are plenty of manufacturers that sell the front and rear separately, such as Whiteline, Progress, Perrin, just to name a few.
garrett, ptuning, tial, turbo, turbosmart
PTUNING Spec-SS Turbo System with GTX2867R option ptuning Forced Induction 52 06-11-2018 10:25 AM
PTUNING: FR-S/BRZ/GT86 Spec-SS Turbo System (Now Shipping) ptuning Forced Induction 151 09-23-2016 11:48 AM
PTUNING Equal-Length Competition Header RJasonKlein Engine, Exhaust, Bolt-Ons 5 07-07-2016 01:43 AM
PTUNING: 501WHP 377WTQ 20psi Stock Motor PTUNING Spec-SS GTX3076R Turbo System ptuning Forced Induction 47 06-16-2014 04:52 PM
