#43 | |
Drives: FT86, BMW 5, JZA80, Porsche 986S
So the plug doesnt actually go where the strut top damper adjustment is in my pictures, the water is actually coming from a problem further underneath the car?? hmm this could mean there is water settling in the subframe and finding its way to the strut top? When I wrote this, I assumed that maybe there was something missing where the camber adjust goes, but it seems it may be an even larger issue? :S
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
#44 |
Drives: SWP BRZ LTD
Yes, if its because they didnt put those plugs in, then it would mean water has been accumulating in your subframe and the mosture starting accumlating up there.
#45 | |
I have a feeling the water I am seeing is from a different area completely, however thanks very much for that image.. I will look to see if mine is in there or not.. That would be a very big oversight if that one wasn't in there! I am assuming the water I am reporting is coming up through the strut itself, as you can see road grime in the strut top, so it's obviously not very well sealed.. I figure if they arent going to seal the strut top, then a measure to stop that water getting into the car eventually should be in place..
#46 | |
AutoX-10/10ths every run
I'm missing my tie-down grommet on the driver's side, and I can confirm that there are no caps on top of the struts in my trunk.
![]() Quote:
#47 |
Drives: 2011 Civic Si
#48 | |
#49 |
Drives: ZN6 / GDB-G
this is a nasty mistake, thanks for the heads up, it will be the first thing to check when i get my car
#50 |
Maybe the holes above the rear struts are more 'noise generators'.....
#51 |
Drives: 2013 Premium White, 2006 TL
Sounds like we need to start a list of items that need to be checked when we get our car.
I don't know how to set that thread up. Any help out there? So far. 1. Check if grommet is in place about 1' in front of the rear tires 2. Make sure there is transmission fluid 3. 4. 5. |
#52 | |
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
![]() One of the old hands here able to set that up? |
| The Following 2 Users Say Thank You to nzer For This Useful Post: | adprokid (07-14-2012), DrDuquette (07-14-2012) |
#53 |
First 86
Drives: Scion FRS Argento Automatic
Where are you getting the body plugs. I don't live far from you, Yuba City
Life is short...NO BORING CARS |
#54 |
Drives: ExigeS,M3,S2k,MCpe,MR2T,T4R,Sienna
Everyone stop buying this car!
Current: 19 GT-R[]17 M2[]17 WRX[]14 T4R[]12 NV2500[]07 Exige S[]07 S2k[]05 M3[]03 M3[]02 MCoupe[]94 MR2T[]93 MR2 T[]92 MR2 T[]91 MR2 T[]95 SC400[]
Gone but not forgotten: 04 STI[]05 MR2 Spyder[]04 S2k[]03 IS300[]90 MR2[] |
#55 | |
Drives: FR-S, Exige S, Miata
'13 Scion FR-S (Whiteout)
'07 Lotus Exige S (Aspen White) Touring, Traction, Starshield '95 Miata (Montego Blue) |
#56 | |
Re-member
Drives: Toyota camry
That's the hole that should be capped with the rubber grommet during PDI. Water and road debris can get up there and eventually cause rust or rattles but I would personally worry about a small animal getting up there and taking a shit or dying. Ive opened my hood and found poop on top of the engine because an animal found it to be a warm dry safe place to take a nap in the winter.
Nothing decays like progress, and nothing preserves like neglect.
| Basic tech info: spring rates, rear suspension, motion ratios, and you. | Racecomp Engineering | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 77 | 07-08-2022 03:56 PM |
| water temp | driver01 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 30 | 04-11-2013 03:57 AM |
| Impressive boot space! | BD | AUSTRALIA | 14 | 08-24-2012 05:30 AM |
| Fatal FRS Flaw!! | Skin | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 07-12-2012 05:21 PM |
| Pics of rear passenger area with plastic removed | JRitt | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 06-12-2012 09:17 AM |
