| Hawaii Aloha! |
#29 |
Drives: frs 2015
I have the same issue starting last year at about 70000 km. It feels crunchy as if clutch (linkage, pushrod, return springs etc ) is binding. I tried applying grease to the slave cylinder pushrod where it contacts the release fork, tried flushing the hydraulic fluid. These seemed to improve it until it came back. I replaced the hydraulic fluid again, and could objectively say it had no effect. I then tried lubing all the moving linkage components inside the car ( very complicated linkage setup) where the sound seemed to come from in my case. The problem, if your getting crunchy clutch is probably the pushrod going into the clutch master cylinder is dry. You will need to find a compatible lube that won’t break down the seals and cause further problems
| Rattles/Squeaks in the BRZ? | cammyfive | BRZ First-Gen (2012+) — General Topics | 190 | 01-12-2017 11:24 PM |
| Squeaks when shifting gears/happens every 15 or so seconds while holding speed | Simon99 | Issues | Warranty | Recalls / TSB | 10 | 10-11-2014 04:54 PM |
| door handle/pull squeaks | NRG x FRS | Issues | Warranty | Recalls / TSB | 1 | 11-27-2013 10:38 PM |
| I knew about cabin squeaks before I bought the car but... | NOMNOM | Issues | Warranty | Recalls / TSB | 10 | 05-23-2013 06:00 PM |
