Old 11-03-2018, 05:36 AM   #15
gpvecchi
gpvecchi's Avatar
As my car doesn’t have a stock mic, can you please measure the distance from the room light, so I can cut the hole? Preferred in mm, please...
Old 11-04-2018, 10:04 PM   #16
austinvojta
Drives: 2016 Subaru BRZ Limited
Sure, I'll go do this now. I'll try to get a few good pictures for you too.
austinvojta is offline   Reply With Quote
The Following User Says Thank You to austinvojta For This Useful Post:
gpvecchi (11-05-2018)
Old 11-05-2018, 12:43 AM   #17
austinvojta
Hole starts 17mm from the edge of the light. Hole measures 31mm wide by 43mm long.
The Following 2 Users Say Thank You to austinvojta For This Useful Post:
CraigVM (11-05-2018), gpvecchi (11-05-2018)
Old 11-05-2018, 01:47 AM   #18
gpvecchi
gpvecchi's Avatar
Many thanks! I’ll post the results of my experiments as I’ll get the microphone grill...
Old 12-13-2018, 01:43 AM   #19
jflogerzi
jflogerzi's Avatar
Originally Posted by CraigVM View Post
I ended up making a small closed cell foam housing which the after market HU mic slips into. All is then placed into the OEM bracket / grill with the OEM mic removed and setting off to the side above the headliner. The foam isolates the JVC / Kenwood HU mic and it's side openings from that roof / road noise above the headliner. Audio quality for those at the other end of the conversation is now the same as when the the aftermarket mic was installed below the headliner.
If you would not mind can you post a picture of this. I am going to do this over the winter break but not sure on the foam type etc...
2013 Series 10 FRS #553
Old 12-16-2018, 12:21 PM   #20
gpvecchi
gpvecchi's Avatar
OK, fitted mine. I cutted the head liner, as my car didn't have stock mic. It's quite easy, as there is a plastic chassis on the inside, so you can't cut it wrongly.
I put the mic in vertical, closing around with some foam. This covered the side holes of stock DDX917WS mic, but test call went flawless. I'll make some other calls in the next days while in movement.
Old 12-25-2018, 11:53 AM   #21
gpvecchi
gpvecchi's Avatar
Update: closing side openings of the mi is absolutely not a good idea, I now tried making a cone that insulates mic from rear noise, but keeping the openings free.
Old 01-09-2019, 04:18 PM   #22
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
snip
kevaughan is offline   Reply With Quote
Old 01-09-2019, 05:49 PM   #23
gpvecchi
gpvecchi's Avatar
Dash? Mic is not in the dash, it's near the room lamp. Check some post above...
Old 01-09-2019, 06:00 PM   #24
kevaughan
kevaughan's Avatar
snip
Old 01-10-2019, 06:16 PM   #25
gpvecchi
gpvecchi's Avatar
The Following User Says Thank You to gpvecchi For This Useful Post:
kevaughan (01-11-2019)
Old 01-11-2019, 08:34 AM   #26
Varelco
Drives: '15 GT86 & '22 GR86
@gpvecchi What headunit is that? Looks a like Kenwood DDX... something
Varelco is offline   Reply With Quote
Old 01-11-2019, 05:35 PM   #27
gpvecchi
gpvecchi's Avatar
Yep, Kenwood DDX917WS.
Old 05-13-2020, 12:58 AM   #28
FRZ
FRZ's Avatar
Drives: Subaru BRZ
@gpvechhi, I'm looking to cut my headliner as well with the microphone grill but feeling nervous about it..
What is the plastic chassis you are referring to? How did you cut the hole and what did you cut it with? Do you have any more pictures? The previous one you posted seems to be gone now. Thanks in advance!!!
FRZ is offline   Reply With Quote
Andriod Headunit Backup Camera darko Electronics | Audio | NAV | Infotainment 0 11-29-2016 02:23 PM
OEM Microphone with aftermarket HU? PNW-BRZ Electronics | Audio | NAV | Infotainment 2 09-28-2015 10:39 AM
Is there any auto alarm that works with the BRZ (limited) Cahue Electronics | Audio | NAV | Infotainment 21 01-22-2014 04:20 PM
Andriod Headunit with HKS OB-Link? stevo_12v Electronics | Audio | NAV | Infotainment 40 04-14-2013 04:31 AM
