Old 11-01-2018, 10:30 AM   #85
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
If you dont think they work. dont get them. I got them and noticed a difference in steering input required, when near the limit, as well as a nicer sound when closing the door. If you're not on a relatively sticky tire and driving at 8/10ths you wont notice they are there unless you close the door and notice its less 'clangy' and more 'thunky'.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 11-28-2018, 11:32 AM   #86
markitect
Drives: Scion FRS
I work with a LOT of loctite. Heat the screws up with a heat gun first it will make it a lot easier to break them loose.
markitect is offline   Reply With Quote
The Following 2 Users Say Thank You to markitect For This Useful Post:
Scargod (03-11-2022), SuperTom (11-28-2018)
Old 11-28-2018, 11:36 AM   #87
Roadcone
StreetKart
Just use the correct tool and they come out quickly and easily with little effort. The correct bit on a rachet makes quick work of these with little fuss. If you try to use a screw driver with the right bit you're going to have a lot bigger hassle
Sent from my Pixel 2 XL using Tapatalk
Old 11-28-2018, 11:53 AM   #88
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Exactly these bolts along with the bolts holding the seats to the floor were a PIA. 2 seconds with a $10 torch from home depot them came off so easily even with them being half stripped. Make it easy on yourself
SuperTom is offline   Reply With Quote
Old 03-06-2019, 09:27 AM   #89
Tristor
Tristor's Avatar
Just did this last night. A few things that I think will be helpful to everyone else to know:
1) You need a torch. Hitting the tops of the screws with MAP gas for a bit will make life easier.
2) Breaker Bar + a #3 Phillips Head Socket (It's a #3 not a #2. And it's not PZ).
3) Use constant even pressure on the back of the head to prevent camming out.
If all else fails, you'll have to do what I did on one of the 4 screws (the other 3 came out with torch + breaker in a shop with ~30F ambient temp). You'll need an air hammer with a screw remover attachment. Careful application of this will definitely get them out, every time, all the time.
Also fun story, in the process of installing this, I made the alignment of my driver's side door better and realized my passenger side door was misaligned from the factory (I checked before and after). New item to add to the list is to find a decent body guy to help me adjust my hinges to re-align my passenger door.
Tristor is offline   Reply With Quote
Old 06-24-2019, 03:47 AM   #90
Ryan GT86
Ryan GT86's Avatar
Drives: 2019 Toyota 86
After not being able to get the screws out with a impact driver. I'm admitting defeat and I'm just gonna pay a shop to do this.
Ryan GT86 is offline   Reply With Quote
Old 06-24-2019, 05:25 AM   #91
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
Try using a ratchet and the appropriate Philips bit socket, that did the trick for me. Impact driver didn't do anything for me either.
Old 06-24-2019, 07:33 AM   #92
Ryan GT86
Ryan GT86's Avatar
On t he driver's side I tried one screw and it worked and then the other screw stripped. I'm gonna see if I can find a mechanic that can just loosen these 4 fucking screws.
Old 03-11-2022, 11:38 AM   #93
Scargod
Track Day Junkie
Scargod's Avatar
Drives: 2022 BRZ Limited
What about Second Gen cars? Needs them too?
Anyone put them on the 2022's? Same 1st Gen parts fit?
Scargod is offline   Reply With Quote
Old 03-11-2022, 01:03 PM   #94
WNDSRFR
Drives: FR-S,GTI
Originally Posted by t.chk View Post
They look nice. I wish there was a STI version, but I might buy it just for the bling...but $190 bling...idk.
I think a hundred dollar bill taped to each door jam would look nicer.
The Following User Says Thank You to WNDSRFR For This Useful Post:
SuperTom (03-11-2022)
LED Door Sill? joergasm Cosmetic Modification (Interior/Exterior/Lighting) 46 06-17-2014 08:37 PM
8's in the door cruzinbill Electronics | Audio | NAV | Infotainment 2 01-26-2013 06:10 PM
fs: TRD door stabilizers narfy Canada Classifieds 12 11-16-2012 12:57 AM
out the door pricing wallace03 BRZ First-Gen (2012+) — General Topics 6 06-12-2012 02:30 PM
