Old 10-31-2018, 09:36 PM   #15
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I disagree.
If you can design a chemical energy storage device not subject to degredation you'd be a wealthy man.
PetrolioBenzina is offline   Reply With Quote
Old 10-31-2018, 09:39 PM   #16
stevesnj
stevesnj's Avatar
Originally Posted by ls1ac View Post
The new systems are smart.
The old voltage regulators were slow to react and were not very accurate.
After starting you should get 14.2 or 14.4 depending on where you measure. that is full charge voltage the amps depend on the state of the battery. After the battery approaches full charge the voltage will drop to about 13.6, this is a maintain voltage for the battery. If it stayed at 14.4 it would over charge and convert the water in electrolyte to gas. A comin problem with old cars. The new cars often have a voltage and charge sensor connected to the battery terminal.
I might suggest that you check the battery terminals to make sure there is a good connection, then do a load test on the battery. A lead acid battery that has been fully discharged will have a loss of load capacity each time it is fully discharged. (The exception are deep cycle type.)
It is possible you have a bad regulator. Excluding the sensor type most are "one wire" type and are built into the alternator.
Even if you put a battery on a new smart charger, out of the car, you will see the same kind of a voltage drop.
I would think the ECU would put up a CEL if the voltage isn't within spec?
My 2016 Build thread
Old 10-31-2018, 09:45 PM   #17
Impureclient
Drives: 2015 FR-S
Re-read the part where I'm not a battery engineer
If you're such a hotshot battery engineer then why during a discharge of electricity does the chemical on the anode release electrons to the negative terminal and ions in the electrolyte through an oxidation reaction?
Old 10-31-2018, 09:49 PM   #18
notout86
Drives: GTS 86 auto
Originally Posted by notout86 View Post
I recently learned that, without modification, there is no possibility of ever FULLY charging the battery BY DRIVING.
Thus our batteries are not lasting as long as they might, especially if the charge gets low e.g. if allowed to stand for a few days.
This is probably because software control is aimed at reducing alternator load to produce better fuel economy figures in government testing.
In our cars, if the battery is low, on startup "it will deliver about 20A at 14.45V for a minute, then reduce to about 4A for a couple of minutes then taper off to NIL
with the voltage across the battery falling below 13V."
In prior decades the alternator would supply a constant 14.4V.
If anyone knows how to change our software to make that happen then let us know.
Meanwhile, using a charger regularly to top up the battery is a solution.
Well I have learned some more from you people. I just read the info. in Silicon Chip magazine July 2018 page 12 and thought I should post it, but it sounds as if it was not quite the full story. I am not having a problem other than I got only 4 years from the o.e. battery and our car does just stand for up to a week fairly often.
GTS86 Auto (Australia)
Old 10-31-2018, 09:55 PM   #19
I have one running around here - she is my 2 year old granddaughter -
Spuds (10-31-2018)
Old 10-31-2018, 09:56 PM   #20
DJCarbine
Thupercharged
DJCarbine's Avatar
I only got 3 years out of my OE battery. Parked it for 2 weeks in the winter, came back to 2 volts across terminals. Would not hold a charge after that no matter how much I tried charging with various methods. It would actually hit 13-14 volts, then slowly drain to 10 after the charge leads removed with absolutely no reserve capacity.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-31-2018, 10:25 PM   #21
All this ^
There is zero need to have 14 volts all the time.Old cars just did it because they were dumb and didn't know any better.
They were so dumb that sometimes you could rap the voltage regulator up side the case with a screwdriver handle and it would start working again.
stevesnj (11-01-2018), Tcoat (10-31-2018)
Old 10-31-2018, 10:57 PM   #22
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Impureclient (11-01-2018), Ultramaroon (11-01-2018)
Old 11-01-2018, 12:33 AM   #23
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
I have also upgraded from, IMO, the crappy Panasonic battery.
Unless things have changed with Panasonic batteries the last 5-6 years, then I'm not aware of it. My Panasonic in my xA lasted 9.5 years, and finally died towards the end of 2016. At that point, I had about 85k miles on the car. About a year previous to replacing it (got a Optima Red top), I had left on the dome light over one late Fall night (so it was on a solid 12 hours), so that drastically drained the battery. I was able to revive it(charged it over 8-10 hours), and it lasted about 12-14 months past that point.
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
The Following User Says Thank You to Adam_L For This Useful Post:
Leonardo (11-01-2018)
Old 11-01-2018, 12:44 AM   #24
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Yea things have changed, the panasonic battery in our cars is trash, and is under powered for the car honestly. Well known to become a problem on the BR-Zs with more active electronics when the car is off at 4 years. On my FR-S I've already replaced it, on my friends 2014 it got replaced after only 3 years. It's simply not the right size for our cars and the quality is crap.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
Old 11-01-2018, 12:51 AM   #25
Still on my original battery. I have, mostly through my past experience servicing home electronics, become a die hard fan of Panasonic's approach to design and documentation, no matter what their product. I was truly excited to see the label on the battery. When the time comes, I'll replace it with the same.
Old 11-01-2018, 12:53 AM   #26
Adam_L
Adam_L's Avatar
Gotcha.
OK, the other point I wanted to make was (it's common knowledge, but in case others didn't know) : batteries lifespan decreases when outside ambient temperatures are at their extremes (below freezing , and above say 90 F). If you live where the temps are more temperate ( 40-80 degrees night/day year round) you're good to go. If you live where it snows , or desert (90+ degrees) several days per year then your battery will live a short life.
I'd think (believe) colder temperatures do more damage to batteries, then hotter temps (both aren't good). This winter, when temps are going to be under 32 degrees at night for 7-10 straight days, I'm going to give my battery a trickle charge for 8-12 hours at least once maybe twice this winter
notout86 (11-01-2018)
Old 11-01-2018, 02:35 AM   #27
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I got rid of the OE one mostly for piece of mind. Running extra electronics and wires here and there. Cold crank being a tiny bit longer. I figured it wouldn't hurt to bump up the juices. I think the cold crank helped and it helped reduce the ignition coil code for me. I got the code a lot less frequently.
Dash Cam Knowledge SmireyFase Electronics | Audio | NAV | Infotainment 19 09-04-2016 11:35 AM
Someone who has knowledge about the stock touchscreen HU IDFWU 420 Electronics | Audio | NAV | Infotainment 11 01-27-2015 10:07 PM
I need a plumbers knowledge whaap Off-Topic Lounge [WARNING: NO POLITICS] 7 11-04-2013 05:28 PM
Anyone go from a 06-11 Civic Si to an FR-S/BRZ? Opinions/ Knowledge needed! jbsali Other Vehicles & General Automotive Discussions 2 01-15-2013 02:41 AM
Some Scion Knowledge and History... Jay Grey Scion FR-S / Toyota 86 GT86 General Forum 130 06-08-2011 01:08 PM
