Old 10-31-2018, 07:44 PM   #1
notout86
Drives: GTS 86 auto
battery knowledge
I recently learned that, without modification, there is no possibility of ever FULLY charging the battery BY DRIVING.
Thus our batteries are not lasting as long as they might, especially if the charge gets low e.g. if allowed to stand for a few days.
This is probably because software control is aimed at reducing alternator load to produce better fuel economy figures in government testing.
In our cars, if the battery is low, on startup "it will deliver about 20A at 14.45V for a minute, then reduce to about 4A for a couple of minutes then taper off to NIL
with the voltage across the battery falling below 13V."
In prior decades the alternator would supply a constant 14.4V.
If anyone knows how to change our software to make that happen then let us know.
Meanwhile, using a charger regularly to top up the battery is a solution.
GTS86 Auto (Australia)
Old 10-31-2018, 07:49 PM   #2
stevesnj
stevesnj's Avatar
Are you having electrical issues? Battery discharging? No start or slow start condition?
My 2016 Build thread
Old 10-31-2018, 07:53 PM   #3
Well, I don't know about all of that, all I know is that the alternator in my 2013 FR-S produced enough electricity to run the car and has kept the battery charged for the past 5 years, with many short trips.
Old 10-31-2018, 07:58 PM   #4
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Just changed my 2013 original battery last month. Got a solid 5 years of daily driving everyday.
So I don't know what you are smoking but pass that stuff over here.
If you don't have any problems, you are way overthinking this.
Old 10-31-2018, 07:59 PM   #5
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I used to commute one mile, with the stereo on, the lights on, and the defrost going too. This is not long enough to charge my car. And after a week of quick 1 mile trips, my car would die.
Now that I drive 50+ miles each way, my battery stays FULLY charged. I have tested its voltage; it's good to go now.
I have also upgraded from, IMO, the crappy Panasonic battery.
I LIKE TIRES!
Old 10-31-2018, 08:13 PM   #6
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I know less than the battery engineers at work, and probably much less than the battery engineers at Toyobaru.
I ran my OE flat two or three times (dome light left on, trunk open) and it lasted just shy of 5 years, the Panasonic is a tank as long as you don't drive too little. 1 year on a lightweight PC680 battery with no issues on a <5 mile commute (~15 minutes in traffic).
ineedyourdiddly
Old 10-31-2018, 08:21 PM   #7
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
So what's the problem again?
The Following User Says Thank You to Spuds For This Useful Post:
stevesnj (10-31-2018)
Old 10-31-2018, 08:37 PM   #8
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
People don't think chemisty be like it is, but it do.
PetrolioBenzina is offline   Reply With Quote
The Following 3 Users Say Thank You to PetrolioBenzina For This Useful Post:
Spuds (10-31-2018), strat61caster (10-31-2018), Ultramaroon (11-01-2018)
Old 10-31-2018, 08:44 PM   #9
I disagree.
Old 10-31-2018, 08:54 PM   #10
stevesnj
stevesnj's Avatar
Service manual says Alternator voltage output should be between 11-14v.
The Following User Says Thank You to stevesnj For This Useful Post:
notout86 (11-01-2018)
Old 10-31-2018, 09:14 PM   #11
Impureclient
Drives: 2015 FR-S
What if I do drive very little and also ran it flat(trunk open) a couple times? Should I then do a trickle charge for a couple hours every couple months in that case?
Old 10-31-2018, 09:15 PM   #12
strat61caster
Re-read the part where I'm not a battery engineer
ineedyourdiddly
Old 10-31-2018, 09:19 PM   #13
ls1ac
ls1ac's Avatar
The new systems are smart.
The old voltage regulators were slow to react and were not very accurate.
After starting you should get 14.2 or 14.4 depending on where you measure. that is full charge voltage the amps depend on the state of the battery. After the battery approaches full charge the voltage will drop to about 13.6, this is a maintain voltage for the battery. If it stayed at 14.4 it would over charge and convert the water in electrolyte to gas. A comin problem with old cars. The new cars often have a voltage and charge sensor connected to the battery terminal.
I might suggest that you check the battery terminals to make sure there is a good connection, then do a load test on the battery. A lead acid battery that has been fully discharged will have a loss of load capacity each time it is fully discharged. (The exception are deep cycle type.)
It is possible you have a bad regulator. Excluding the sensor type most are "one wire" type and are built into the alternator.
Even if you put a battery on a new smart charger, out of the car, you will see the same kind of a voltage drop.
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
Spuds (10-31-2018), stevesnj (10-31-2018), Tcoat (10-31-2018)
Old 10-31-2018, 09:36 PM   #14
All this ^
There is zero need to have 14 volts all the time.Old cars just did it because they were dumb and didn't know any better.
Dash Cam Knowledge SmireyFase Electronics | Audio | NAV | Infotainment 19 09-04-2016 11:35 AM
Someone who has knowledge about the stock touchscreen HU IDFWU 420 Electronics | Audio | NAV | Infotainment 11 01-27-2015 10:07 PM
I need a plumbers knowledge whaap Off-Topic Lounge [WARNING: NO POLITICS] 7 11-04-2013 05:28 PM
Anyone go from a 06-11 Civic Si to an FR-S/BRZ? Opinions/ Knowledge needed! jbsali Other Vehicles & General Automotive Discussions 2 01-15-2013 02:41 AM
Some Scion Knowledge and History... Jay Grey Scion FR-S / Toyota 86 GT86 General Forum 130 06-08-2011 01:08 PM
