Old 10-19-2018, 08:55 AM   #1
stlgrym3
Recommendation for lowering spring on 2017 BRZ AT
For 2017 BRZ limited (without performance package) what lowering springs do you recommend? My priorities are perfect fit with oem shocks, maintain oem ride comfort, lower about an inch front and rear. Budget is less than $300.
stlgrym3 is offline   Reply With Quote
Old 10-19-2018, 11:44 AM   #2
DaBoBo21
Brett
DaBoBo21's Avatar
Drives: ‘94 Supra
I think the TRD lowering springs would be a good fit for you. Made for the OEM struts and have a 1" drop.
https://parts.toyota.com/p/Toyota__8...TR0718130.html
DaBoBo21 is offline   Reply With Quote
Old 10-19-2018, 12:07 PM   #3
stlgrym3
Do those fit on BRZs?
Old 10-19-2018, 12:09 PM   #4
Vital
Drives: 2015 BRZ
Yes, they have the same suspension...
Also, look into the RCE Yellows. I know you said your budget is below $300 but these springs are amazing. I honestly felt the ride got better and i have had no issues with DD.
The Following User Says Thank You to Vital For This Useful Post:
DaBoBo21 (10-19-2018)
Old 10-19-2018, 12:21 PM   #5
churchx
churchx's Avatar
Drives: 2014 GT86
Mind you that all proper lowering springs are also stiffer, to compensate reduced travel, to not hit bumpstops often, if left of old spring rates but simply shortened. Also often lowering springs are chosen for performance reasons .. and thus are also bought(/designed/sold) stiffer, to eg. reduce body roll on grippier tires.
There is also bit that our cars are rather low and with rather short shock travel to begin with.
Summarizing it up, slight sacrifice to comfort/compliance will be made anyway, and it's worth going for springs, that lower to reasonable amount, within inch, not much more than that, as those that lower even more very probably will be even stiffer, there will be very little travel left, so it will be harder for suspension to actually do it's job of handling road defects, and also to fix up overlowered suspension one may need extra parts, like to fix roll center, diff riser and such, rising needed budget by much.
And yes, RCE yellows seems popular & good enough choice for lowering springs, many go with.
humfrz (10-20-2018), wparsons (10-21-2018)
Old 10-19-2018, 09:53 PM   #6
stlgrym3
Just ordered a set of RCE Yellow, hope it’s good as advertised.
The Following User Says Thank You to stlgrym3 For This Useful Post:
Racecomp Engineering (10-20-2018)
Old 10-19-2018, 10:23 PM   #7
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
Hope you were smart enough to save for an alignment, and hope you're capable enough to do it yourself, or saved enough to pay someone to put the springs on for you.
The Following User Says Thank You to x808drifter For This Useful Post:
Old 10-19-2018, 10:25 PM   #8
stlgrym3
Alignment is a must every time I do suspension mod.
Old 10-20-2018, 02:54 AM   #9
Decep
Drives: 2013 FR-S Series 10
Get camber bolts while you're at it.
Old 10-20-2018, 03:34 AM   #10
stlgrym3
Are those required for this springs? When u had Apexi N1 coilovers I didn’t get any camber bolts or LCAs, I had some negative camber in rear but not too bad.
Old 10-20-2018, 04:54 AM   #11
churchx
churchx's Avatar
Drives: 2014 GT86
Camberbolts are not "required", but good alignment is advised to have and those are relatively cheap way to add camber adjustment to front, especially if it's for shocks without camberplates in set, like stock shocks, with which usually springs are used with. Some camber adjustment can be done within slack of bolts, but range is very limited (sometimes insufficient to get close/even side-to-side) and real pain to change precise.
Afaik no coilovers ship with LCAs, unless it's some kit of coilovers and them (&maybe something else) custom picked up by shop. There is some negative camber in stock twins (~ -1dg IIRC), and even more negative camber is naturally gained from lowering due geometry changes, both front and rear.
Old 10-20-2018, 10:56 AM   #12
Not required. But the super cheap OEM bolts for the front make a very nice difference allowing you to get a little extra camber for even better handling. Not enough to worry about tire wear but noticeable improvement in handling.
- Andrew
smg1138 (10-20-2018), wparsons (10-21-2018)
Old 10-20-2018, 05:22 PM   #13
x808drifter
LMGTFY
So just to clarify in one post.
There is little to no camber adjustment in the stock suspension. (camber wise)
So a good it's usually a good idea to get camber bolts for the front so you can guarantee that you can get the fronts even.
The rears would also need LCA's, but most just use what the springs do naturally.
Leonardo (10-20-2018)
Old 10-20-2018, 09:45 PM   #14
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
There is no camber adjustability stock except for minor slop in the hardware, but it's almost never enough to get you 0.1 degrees difference.
Bolts are less about even for the front, and more "why the fuck didn't Subaru put camber bolts in this thing oh God it sucks without camber" if you are interested in performance. A modest -1.5 up front is just more grip for less than a tank of gas and you'll always want them in there.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Racecomp Engineering (10-22-2018), wparsons (10-21-2018)
Coilover/Spring recommendation? PaoloJR CANADA 17 10-10-2018 06:32 PM
Help with lowering spring install in PDX? AnotherDude000 Northwest 4 09-05-2017 02:22 AM
Lowering spring FAQ- stock FR-S gconron_86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 11-22-2015 04:35 PM
LOWERING WITH SPRING IN CANADA bhbnuckle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 03-14-2014 01:42 AM
WTB Lowering Spring FRS_Jack Want-To-Buy Requests 0 02-27-2014 01:48 AM
