Old 07-13-2012, 08:53 PM   #15
Exhaust
UCanThrottleMyBody
Exhaust's Avatar
Drives: 2015 GM 370z Sport
Yeah, brz/frs is better than frs/brz rivalries is bound to happen later on. Its already pretty obvious even now.
Not only can this be a problem for mold, but rust could be a problem as well.. not to mention and god forbid, mosquitoes.
Exhaust is offline   Reply With Quote
Old 07-13-2012, 08:55 PM   #16
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Originally Posted by ft86Fan View Post
Good question. I was thinking the same thing.
They didn't do it on mine. I assume. It's common.
blu_ is offline   Reply With Quote
Old 07-13-2012, 09:02 PM   #17
zoomzoomers
zoomzoomers's Avatar
Are you sure there isn't a tiny drain hole in there somewhere? Of course, it could be a small design flaw, but I would think that a strut top has a hole somewhere near it that would allow any liquid to drain out. No?
Old 07-13-2012, 10:21 PM   #18
WTF
WTF's Avatar
Drives: FT86, BMW 5, JZA80, Porsche 986S
Is yours the same? I am just wondering if someone else can check they too have a hole there?
600hp Built FA20 Widebody Toyota 86/FRS.. build thread
WTF is offline   Reply With Quote
The Following User Says Thank You to WTF For This Useful Post:
aznsensazian (07-14-2012)
Old 07-13-2012, 10:36 PM   #19
RRnold
2 wheel member
RRnold's Avatar
Drives: JZA80, 997.1, Taco
Originally Posted by cyde01 View Post
could this be the cause of Hanakuso's gnats in the trunk problem?
Maybe!!
That's weird, shouldn't there be a rubber grommet or something to seal it?! It's definitely an issue and I would bring it in.
Old 07-13-2012, 10:41 PM   #20
czar07
czar07's Avatar
Drives: '97 RSP JZZ30 GT-T
Lol this statement. Team 86 approved everything and it was headed up by a Toyota engineer and comprised of both companies employees. The chirping is a design issue. The high pressure high pressure fuel pump isn't a Subaru parts bin part.
Tail light condensation? Design flaw or manufacturing flaw?
Germans>Japanese>Italians>Americans. Unless its a Corvette.
czar07 is offline   Reply With Quote
Old 07-13-2012, 10:41 PM   #21
RRnold
2 wheel member
RRnold's Avatar
Originally Posted by czar07 View Post
Sadly this car is not made at toyota. This is the sort of shit (and the chirping and all those other little niggles) that happens when you let inferior manufacturers build your cars for you.
Well it does have the common Subaru specific issues that Spacewilly mentioned before so...
Old 07-13-2012, 10:51 PM   #22
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Unintended acceleration? Subarus fault?
Every manufacturer, especially on first year models has issues. Your point about the chirping just shows that you are painting a generality about this cars issues that isnt true.
Old 07-13-2012, 10:52 PM   #23
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
I caught that they didnt do it the day after I bought the car and fixed it. In theory though the described symptoms in the OP could be explained by this.
There are just two plastic plugs near the rear of the car that need to be installed during PDI or moisture can get into the rear subframe.
The Following User Says Thank You to blu_ For This Useful Post:
adprokid (07-14-2012)
Old 07-13-2012, 11:10 PM   #24
R8
Spinning Triangles
R8's Avatar
Drives: RX-8
Why aren't they installed by the factory?
R8 is offline   Reply With Quote
Old 07-13-2012, 11:15 PM   #25
WTF
WTF's Avatar
^^ This..
and how did you manage to notice it the day after you got the car? Only reason we noticed it was when removing the stock suspension to fit coilovers.
Mark
Old 07-13-2012, 11:29 PM   #26
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
Good question but they don't. It has something to do with how the car is transported. They are usually sitting in your glove compartment from the factory. And putting them on is part of the pdi doc.
Old 07-13-2012, 11:33 PM   #27
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Because those holes are used to transport the car to the dealer.
Old 07-13-2012, 11:35 PM   #28
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
^^ This..
Mark
Hey buddy. The reason I noticed it was because other people who were some of the first to take delivery had the same issue. So I looked under my car in May and saw they were not installed. If you actually care about the truth you cAn look at my posts from then and see that I mentioned this then
tripjammer (07-14-2012)
Basic tech info: spring rates, rear suspension, motion ratios, and you. Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 07-08-2022 03:56 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 03:57 AM
Impressive boot space! BD AUSTRALIA 14 08-24-2012 05:30 AM
Fatal FRS Flaw!! Skin Scion FR-S / Toyota 86 GT86 General Forum 4 07-12-2012 05:21 PM
Pics of rear passenger area with plastic removed JRitt Cosmetic Modification (Interior/Exterior/Lighting) 20 06-12-2012 09:17 AM
