Southern California SoCal
Old 10-03-2018, 02:38 PM   #1
Gatoortiz86
Drives: 2017 Toyota 86
Blitz Advanced intake
Is an intake really worth it for an Ft86?
Gatoortiz86 is offline   Reply With Quote
Old 10-03-2018, 03:00 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Worth what? What do you hope to get out of one? Help us get some perspective on your goals, and we can use that measurement to affirm for you the effectiveness of an intake. Please also be aware that they are not all going to have the same design, aesthetically or purposefully, so some choices will be better suited to a goal than others.
Old 10-03-2018, 03:20 PM   #3
Gatoortiz86
In general, money wise, does the performance increase with an intake or is my 2017 oem is just fine? Thanks!!!
Old 10-03-2018, 03:30 PM   #4
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Welcome to the forum!
This has been talked about before.... Tip: use google to search. type in "ft86club" and what you are interested in, Like "ft86club best intake" or what ever. You will actually find things this way.
I had the stock intake for years. I recently upgraded to a silicone inlet tube and a K&N drop in filter. I would consider this mod to be mainly cosmetic. To take full advantage of an intake (or ANY mod for that matter) you will need a tune. So, aside from the intake sound and the look, intakes are not going to give you a boost in performance that you can feel.
EDIT: Damn, that thing is expensive. I think that OFT would be a better way to spend that much, if performance is your goal.
Good luck!
I LIKE TIRES!
Old 10-03-2018, 03:39 PM   #5
Gatoortiz86
Thanks!!! That makes sense!!! First time I use this app! Thanks for the advice! I appreciated it!
The Following User Says Thank You to Gatoortiz86 For This Useful Post:
Leonardo (10-03-2018)
Old 10-03-2018, 04:06 PM   #6
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Just buy a K&N drop in filter and OFT. Intakes arent worth it. Then get a header and use the OFT to gain you some hp
Decimus is offline   Reply With Quote
Old 10-03-2018, 06:58 PM   #7
Thaeyo
Thaeyo's Avatar
If money isn't an issue get all your bolt on and then get it dyno & tuned, you would have to use ECUTek for any non-OEM intake
Thaeyo is offline   Reply With Quote
Old 10-03-2018, 06:59 PM   #8
Gatoortiz86
Thanks guys! That helps a lot!!
Old 10-11-2018, 11:26 AM   #9
jflogerzi
jflogerzi's Avatar
Oem is fine. Get open flash tablet. Much wiser investment.
2013 Series 10 FRS #553
Intake Cam Timing advanced 20 Degrees at IDLE Kris86 Engine, Exhaust, Transmission 67 08-25-2017 04:28 PM
BLITZ FR-S/BRZ Intake released CrazyWookiee Engine, Exhaust, Transmission 34 04-23-2017 03:17 AM
FS: BLITZ intake tube. myusernameisrob Engine, Exhaust, Bolt-Ons 2 01-29-2015 07:58 PM
Blitz or trd cold air intake? type_o Engine, Exhaust, Transmission 6 04-02-2014 09:19 PM
