| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Subaru BRZ
Lightweight pulley(s) good or bad?
Hello guys,
Time to put in the car in the garage for the winter soon, and i have a lot of ideas, where i will be spending my time for the next couple of months! Yes, i have serached in the forum about this subject, but i didn't get much out of it though. However, there is a lot of options to chose by here. I have seen that you can buy those cheap kit with pulleys from china for about 50usd, and i thought that even if it may be some bad quality, it wont hurt very much, if the crank pulley would fail, but then i readed that the oil pump is going by the crank pulley as well, so that might not be a good idea? There may also be some problem if the pulleys are not balanced, right? Maybe the best would be to buy proper quality from the ft86 shop, or should i just skip the whole idea and not change it at all? Just want to hear some input from other perspective here. (as usually, i'm from Sweden. My English is not very well, hope you get the most text though) Cheers! |
#2 |
6/22/12-2/6/24
Ah .. this topic.
| The Following 4 Users Say Thank You to Bonburner For This Useful Post: |
#3 |
Drives: 2017 toyota 86
There are about 100 threads discussing this. I’ll give you the basic run down.
Ppl say it’s pointless. Ppl say they can feel a big difference on butt dyno. Ppl say subaru/Toyota say stock pulley has a balancer/dampener. Ppl say stock doesn’t have a balancer/dampener. Then the people with half a brain have researched and done the math/physics calculations to essentially prove its pointless, as well as stock does have a dampener ring on it. Fluidampr Pulley can potentially reduce high rpm vibration/frequency especially the more none stock you are the more beneficial it potentially can be. And oversized/underdriven accessory pulleys can free up close to 2hp. Now you have at least 90% of all the information from 1000s of posts about this subject. |
#4 | |
![]() There ain't nothing wrong with the pulleys that came with your car, so why mess with them. humfrz |
#5 |
The Dictater
Drives: '13 Red Scion FRS
If you are looking just for something to wrench on as a hobby, you can get decently made pullies that probably* won't break anything. You are going to see shortly all the various opinions on the effect of said pullies so I hope you are strapped in lol. Rule Number One of Pulley Club, you do not talk about Pulley Club.
It's not the pulley that fails, it's the things attached to the pullies that can fail due to a bad pulley/harmonic balancer (look that one up). This includes your crankshaft. You REALLY don't want your crankshaft to fail. I'll leave you to ponder that for the next few pages... |
| The Following User Says Thank You to Spuds For This Useful Post: | why? (09-27-2018) |
#6 |
Famous Potatoes
Drives: '15 ultramarine
Yes.
#7 |
#8 |
Drives: _
When designing an accessory drive system, the pulleys are an integral part of the calculations. Inertias of the pulleys act as dampers to the system.
(Same goes with flywheels - inertia of the flywheel dampens out crank torsional vibrations and resonances, and improves accessory drive performance) |
#9 |
Only happy when it rains.
Drives: series.blue
You absolutely did not search. You are absolutely a troll. We've had our battles on this. Cheap pulleys are not worth buying, they will absolutely break.
Go for the best made lightest pulleys and you will not have a problem as long as you do not add forced induction. |
#10 | |
Drives: 2013 frs red
#11 | |
Also important note when you under drive the pulleys to the alternator and water pump, you gain a little bit of power but you sacrifice the performance of those accessories. You have less power coming out of the alternator and slightly less flow from the water pump.
#12 | ||
#13 |
Go another route. I would recommend waiting til next season, getting some fresh fuel in it and tuning it.
#14 | |
Also cost to benefit ratio or what order you should do each mod in is a different discussion. And assumes you know what he has and hasn’t done already or is planning on doing already. But yes generally speaking, pulleys are low bang for buck. And should take a back seat until other mods of greater importance and value have been done. |
| [GA] FS: NEW Grimmspeed Lightweight Crank Pulley (NIB) + OEM Crank Pulley Bolt | reeves | Engine, Exhaust, Bolt-Ons | 0 | 08-22-2018 08:01 PM |
| lightweight pulley | shaynek | Want-To-Buy Requests | 2 | 03-19-2016 03:16 AM |
| FS: New Lightweight Pulley Set | nlowell | Engine, Exhaust, Bolt-Ons | 5 | 03-13-2015 02:43 PM |
| AP Lightweight pulley $70 | tq86 | Engine, Exhaust, Bolt-Ons | 3 | 02-04-2015 09:54 PM |
| Lightweight pulley wow | Silverdub | Engine, Exhaust, Transmission | 240 | 01-23-2013 02:00 PM |
