Old 09-03-2018, 08:53 PM   #127
ShadowWolf_99
ShadowWolf_99's Avatar
Drives: 10 Series #895
Originally Posted by HeresMyMind View Post
Those look like very cheap projector style lights without a proper shield / optic system. That stinks. When you can find a set of used dogs from a frs or brz to swap in
-B
I could have sworn my friend who gave me these ( out of his frs) said he got them on his car from the dealership. I can tell he forgot that isn't true. Now I have it wired I just need better projectors. Yay. Free harness I guess.
ISO cheap led halo fogs peeps!
Sent from my SM-G950U using Tapatalk
PDX86 / 86 Sessions / 86Squad / DarkSquad
ShadowWolf_99 is offline   Reply With Quote
Old 09-03-2018, 09:03 PM   #128
carlovestela
Drives: 2015 Firestorm FRS
I dont have that. So if i put brz headlights? I cant adjust or aim it?
Originally Posted by ShadowWolf_99 View Post
Middle switch runs the motor to adjust my beam height.
carlovestela is offline   Reply With Quote
Old 09-04-2018, 11:47 AM   #129
vandemo1133
Drives: 2015 FRS
So I bought an HID kit and projector that's supposed to fit the stock FRS headlights. Does anyone know if I were to buy Valenti headlights if it would still fit as if they were also stock? Not sure how the interior of the valentis look.
vandemo1133 is offline   Reply With Quote
Old 09-04-2018, 07:33 PM   #130
Thaeyo
Thaeyo's Avatar
Anyone have the 2017+ Toyota headlight wiring diagram? I want to put it on my FRS. Thanks
Thaeyo is offline   Reply With Quote
Old 09-05-2018, 02:15 AM   #131
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Did you mean these headlights?:
http://www.ft86club.com/forums/showthread.php?t=83144
The valenti jewels require the OEM HIDS which you don't have in an FR-S
Old 09-07-2018, 01:14 PM   #132
saclambda127
Drives: 2015 Scion FR-S (halo)
I wanted to add an LED strip to the fog light bezel of my 2015 FRS, know of any good brands that make it?
If you have a question regarding headlights, fog lights or other external lighting feel free to post here. I have been building custom lights for over 13 years now. And would be more than happy to answer your questions. Retrofits, additional lighting, color temps, leds, you got a question about it and I can probably answer it.
-B
saclambda127 is offline   Reply With Quote
Old 09-10-2018, 07:02 PM   #133
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
http://store.ijdmtoy.com/Scion-FR-S-...wE&click=12691
other wards universal strips maybe from DiodeDynamics or TheRetrofitSource?
-B
HeresMyMind is offline   Reply With Quote
Old 09-20-2018, 09:01 PM   #134
Akrochik
Drives: Golf TDI for now
Are there any decent upgrade options for a stock halogen headlight on a 2013 FRS if I don't want to disassemble/bake/etc?
Are any of the LED plug and play options worthwhile?
Akrochik is offline   Reply With Quote
Old 09-21-2018, 01:52 AM   #135
FRSBRZGT86FAN
However they aren't going to have anywhere near the precision cutoff of a retrofit LED projector install as you already know, but right now they are very good from what I've seen.
The LED headlight bulbs from morimoto and diode dynamics are pretty good, technology on LED bulbs has come along way, and they have pretty good cutoff and seem to match the stock bulbs beam pattern pretty well.
I've got the morimoto 2 strokes on my CX-5 and they never needed any adjustment and the light output is way way better. I'm planning on taking the HIDs out of my winjets on my FR-S and possibly buying them for it as well. The HIDs from my diode dynamics on my winjets are starting to take a bit longer to warm up then they did when new and an LED upgrade would definitely fix that.
So either Diode dynamics SL leds or morimotos 2 strokes would probably be best
Old 09-21-2018, 08:23 AM   #136
HeresMyMind
These projectors accept HID kits very well without causing glare to oncoming due to the projectors optic's style as a whole.
LED bulbs optics do not work out very well in projectors.
If you don't plan on doing opening the headlights and swapping the projectors out for proper HID ones, i recommend just a basic Morimoto HID kit for your car from www.TheRetrofitSource.com
There is no need for extra harnesses for your car either.
-B
Old 09-22-2018, 10:07 PM   #137
Akrochik
Thanks. Going to grab these in 5500k
https://www.theretrofitsource.com/h1...to-xb-hid.html
The Following User Says Thank You to Akrochik For This Useful Post:
HeresMyMind (09-22-2018)
Old 09-22-2018, 10:18 PM   #138
Akrochik
Another noob q: what's the benefit of paying 3-4x more for something like this? Or is there none for this car?
https://www.theretrofitsource.com/h1...oto-elite.html
Old 09-22-2018, 10:59 PM   #139
HeresMyMind
https://www.theretrofitsource.com/mo...cion-gt86.html
(this does NOT work with BRZ's)
This kit replaces all the internals with HID specific components that will be much brighter than oem projectors with HIDs in them. They are also bixenon which means they are both a low beam and a highbeam. They do require you to open up the headlights, but the install is pretty straight forward.
This is the next best option besides upgrading to OEM BRZ headlights.
-B
Old 09-24-2018, 01:14 AM   #140
Tangizdope
Drives: 2016 FRS
What size led's will fit in winjet fog lights? Thanks!
Tangizdope is offline   Reply With Quote
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 03:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
