Old 09-13-2018, 11:35 PM   #1
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Brand New: PureAutomotive Motec ECU + PNP wiring harness
Brand new, never used Pure Automotive MoTeC LS plug and play ECU and harness.
ALSO included are the required sensors that PureAutomotive doesnt mention on their site:
AEM fuel pressure sensor: 30-2130-150 $160.45
AEM (oil) pressure sensor: 30-2131-150 $63.84
AEM wideband + controller: 30-0310 $162.00
LS oil pressure thread to universal adapter $40
It cost me a total of $6422
YOURS for $5400 (thats a $1k loss!)
Had to wait 9 weeks for this harness to be built and shipped to me, I have it ready to ship for who-ever is ready to swap!
Description from PURE AUTOMOTIVE:
You’ve Put an LS Swap into your 2013-2107 86 Platform, how are you going to make it run and still use all the factory functions and amenities of your car?
After trying numerous methods of getting an LSX Swap to work in the Scion FRS/Subaru BRZ platform, buying multiple wiring harnesses with various issues, and spending countless dollars on other company’s “Solutions”, we decided to take matters into our own hands.
Swapping an LSX into any car is not for the faint of heart. It requires a laundry list of parts to make it fit right, run right, and drive right. Physically putting the engine into the car is fairly easy using all of our swap parts. Buying Go-Fast parts for your LSX engine is pretty straight forward. But getting it to run in a car it didn’t originally come in, that is an entirely different issue.
The FRS/BRZ electronic system relies heavily on CAN BUS. That makes it very difficult to make basic amenities, such as the gauge cluster, work with the swapped engine. Other cars output different signals than the FRS/BRZ. Many people have tried short cutting this, but it never quite works like factory.
So how do you make it work? You find an ECU that’s intelligent enough to convert the swapped engine data, into something the car can understand! With our kit, you will be able to bridge the communication gap. We have teamed up with Obsidian Motorsport Group to develop a complete package that will make swapping your FRS/BRZ a breeze!
What Factory Functions Do I Get to Keep?
OEM Power Steering -OEM Electronic Throttle Pedal -OEM Gauge Cluster -OEM Wheel Speed Sensors and ABS System -OEM Fan Module Control -OEM Fuel Pump Module Control
What does MoTeC offer for your setup?
The real question is, what doesn’t it offer? MoTeC is the pinnacle of control and customization for your setup. Endless possibilities for customization await you. Everything from basic functions like boost control to fully customized traction control! For more information, contact us!
What do you need?
Our Plug and Play MoTeC M130 Kit, Which Includes:
-MoTeC M130 Stand Alone ECU
-MoTeC M130 Data Logging Package Level 2
-Obsidian Motorsport Group LSX Toyota 86 Swap Package
-Obsidian Motorsport Group / PURE Toyota 86 to LSX Adapter Harness
-Pure Automotive Custom LSX Engine Harness With BRZ Breakout Harness
spitsnaugle is offline
Old 09-18-2018, 02:52 PM   #2
Clash0901
2 ugga dugga's
Clash0901's Avatar
Drives: Nike
This is a great deal!!
I never got one of these nice carrying cases. I'm curious though what is the thumb drive for? I never got that either but i'm guessing I don't need it. I doubt it's some sort of "key" since I it never came with my kit.
Also, why did you need the fuel pressure sensor? And where did you plan to install it?
Want to 2JZ swap your 86? Click here first!!
Clash0901 is offline
Old 09-19-2018, 03:00 PM   #3
spitsnaugle
I'm assuming the thumb drive is the tuning software for the M130.
I never finished the planed location for the fuel pressure sensor, probably an inline AN to NPT fitting.
Old 10-12-2018, 02:18 PM   #4
spitsnaugle
PRICE DROP. Now at $1k less than I paid, AND ITS BRAND NEW!
Old 10-14-2018, 02:49 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The usb is just the Motec tuning software.
The LS oem fuel rails have an AN4 male port with a schrader valve. Remove the cover, remove the schrader valve, use the 4AN to 1/8 npt adapter included with fuel pressure sensor and you have fuel pressure. Useful for fuel return systems and on returnless systems as a simple check to see if you have fuel in the engine.
Sportsguy83 is offline
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
adjusts (11-01-2022), Clash0901 (10-17-2018)
Old 10-22-2018, 04:26 PM   #6
spitsnaugle
SOLD
Held by deposit.
The Following User Says Thank You to spitsnaugle For This Useful Post:
GrabTheWheel (10-23-2018)
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:49 AM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 11:23 AM
WTB wiring harness awang0528 Want-To-Buy Requests 1 06-06-2016 02:55 AM
3rd harness wiring? kndonlee Electronics | Audio | NAV | Infotainment 3 07-01-2012 07:49 PM
Wiring harness sastexan Electronics | Audio | NAV | Infotainment 0 06-16-2012 11:41 PM
