#15 |
Drives: Red BRZ
My TOB is going, started making noise last winter. Been quite for a while, got loud today. Unfortunately, I can't DIY this time. What's the cost at dealer to replace clutch/TOB? Should I consider a local shop?
Thanks. |
#16 | |
I suggest you call your local dealer and a couple of auto shops for an estimate. Either way, make sure they use the new and improved TOB. I wouldn't wait too long - ![]() humfrz |
#17 | |
Drives: 2016 Oceanic, "base" model
Weird thing is, a few weeks before that I went to the same dealer service department just to get an estimate and was told $1600. Not sure why such a huge discrepancy... |
#18 |
Drives: Red BRZ
My car is at the dealer now, TOB, clutch disc and PP being replaced with new. Pricing similar to what's been quoted above. Thanks.
#19 |
Drives: Silver 10 series
Well my daughter called me tonight saying her car started smoking and she smelled a burning smell coming through the ac and said the clutch was acting weird *♂️. I went to her work and thought maybe the line was leaking clutch fluid or something because she said the reservoir was a little low, but not below the min line. So I started the car and it sounded fine, until I pushed in that clutch pedal. Squealing and sounded like metal on metal grinding, not good. I was able to get it home. I guess that means a TOB and new clutch for me too. 2013 FR-S 50k miles. So I should expect around 1500?
#20 | |
![]() It does seem that about 50,000 miles on a 2013 FR-S, is about when the TOB can start acting up - ![]() Just make sure they replace the toasted TOB with the new and improved one. humfrz |
#21 |
I got just over 100k out of mine but I was stubborn and put it off until it wasn't possible to go any longer. I paid $1200 at Aamco and it seems to be working reasonably well but needs to be bled again.
#22 | |
I’ve seen that the old part is faulty and there is a new one like you’re talking about, but will shops know what I’m talking about? How will I know if it’s the new part or not? I wonder if I shouldn’t just take it to a suburu dealer to get it fixed? |
#23 | |
Then ask an automotive shop, or the dealership to replace the TOB with the one I give them. humfrz |
| DIY Clutch Replacement | Supermassive | DIY (Do-It-Yourself) Guides | 217 | 08-27-2023 01:35 PM |
| Clutch creaking noise (not the clutch fork one...) | treminaor | Issues | Warranty | Recalls / TSB | 59 | 10-23-2017 02:53 AM |
| Clutch replacement | pinetree | Engine, Exhaust, Transmission | 21 | 05-03-2017 09:48 AM |
| Exedy OE replacement clutch. | APEXIT53 | Transmission and Driveline | 2 | 04-08-2017 09:54 AM |
| Clutch replacement | Thatguyjeremy | Engine, Exhaust, Transmission | 0 | 02-28-2015 05:22 AM |
