Old 06-29-2018, 06:13 PM   #1
SPCorBUST
SPCorBUST's Avatar
MAF sensor o-ring size
Does anybody know the size of the MAF sensor's o-ring? I can't seem to find it and none of the ones at Autozone seem to fit. Would really hate to buy a new MAF sensor for a rubber seal if I can avoid it, its like $230.
Hoping to pick one up at Home Depot, Lowe's, or someplace similar.
SPCorBUST is offline   Reply With Quote
Old 06-29-2018, 06:27 PM   #2
CSG Mike
CSG Mike's Avatar
H2.00 x 22
Buna Nitrile.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
FunnyGopher (06-30-2018), Kestrel (06-29-2018), Ultramaroon (06-29-2018), whataboutbob (06-04-2022)
Old 08-27-2018, 03:21 PM   #3
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
H2.00 x 22
Buna Nitrile.
Sorry for my lack of understanding, what does the H stand for?
Having a hard time finding this, there are quite a few 22x2.5 on Amazon.
1Cor10:23 is offline   Reply With Quote
Old 08-27-2018, 06:20 PM   #4
CSG Mike
CSG Mike's Avatar
Part number
Anything that fits the specs will work.
Buna-Nitrile
22 mm ID
26 mm OD
2 mm Width
1Cor10:23 (08-27-2018), menikmati (11-15-2023)
Old 08-28-2018, 09:54 AM   #5
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
https://www.amazon.com/dp/B005RUR0F6/ref=biss_dp_t_asn
Trueweltall is offline   Reply With Quote
The Following 2 Users Say Thank You to Trueweltall For This Useful Post:
1Cor10:23 (09-12-2018), Sportsguy83 (09-13-2018)
Old 09-12-2018, 03:20 PM   #6
1Cor10:23
1Cor10:23's Avatar
Originally Posted by Trueweltall View Post
Just tried some 75A Viton o-rings and they are significantly stiffer than OEM, so much so that I can tell the engine is stumbling when slowing down in neutral gear, suggesting that the MAF is leaking.
@CSG Mike any suggestion for shore rating? Internet says 70Ais most common but not sure what the OE is.
Old 09-12-2018, 04:09 PM   #7
mrg666
pessimistic skeptic
mrg666's Avatar
I would make sure that o-ring stays in place while pushing the MAF sensor. MAF sensor should sit flush. Sometimes the o-ring does not stay in its groove while pushing the MAF sensor in place. You can also rub a dab of grease just to wet the o-ring for sealing it air-tight.
The Following User Says Thank You to mrg666 For This Useful Post:
Old 09-12-2018, 04:11 PM   #8
1Cor10:23
1Cor10:23's Avatar
Yup, flush and using grease...
Old 09-12-2018, 04:26 PM   #9
CSG Mike
CSG Mike's Avatar
Tape around it to check for a seal.
Still stumbling? u got other issues.
Old 09-13-2018, 11:35 AM   #10
Trueweltall
Did you use an oiled air filter?
Old 08-15-2023, 03:35 PM   #11
dynarun55
Drives: 2015 midnight blue limited edition.
Part number
Buna-Nitrile
22 mm ID
26 mm OD
2 mm Width
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
dynarun55 is offline   Reply With Quote
The Following User Says Thank You to dynarun55 For This Useful Post:
CSG Mike (08-15-2023)
Stock MAF sensor screws size/pattern jonbonazza Engine, Exhaust, Transmission 9 07-23-2020 01:39 PM
Crankshaft position sensor bolt size sfruski Engine, Exhaust, Transmission 0 09-02-2017 12:10 AM
Omni 3-Bar Map Sensor O-Ring Size? xjohnx Forced Induction 0 10-02-2013 11:29 AM
02 Sensor Socket Size? swift996 Engine, Exhaust, Transmission 6 08-19-2013 10:30 PM
Size of Centric Hub Ring wheel? Akired86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-08-2012 12:19 AM
