Old 08-13-2018, 06:46 PM   #2059
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Manifold mounted, Verus radiator and fans wired up. Several other odds and ends connected/secured
The Following 5 Users Say Thank You to ATL BRZ For This Useful Post:
aimforapex (08-24-2018), DustinS (08-14-2018), mistople (08-14-2018), TheStig85 (08-23-2018), VerusEric (08-15-2018)
Old 08-15-2018, 10:04 AM   #2060
ATL BRZ
ATL BRZ's Avatar
Ordered a new intercooler yesterday!
JDL are now custom making these with a Garrett high density core that will support over 500hp sustained. Fitment is the exact same as the original. I opted for this because I want a more efficient intercooler without sacrificing room under the bumper cover, since I will need it on the passenger's side for the Blitz oil cooler and duct. The Greddy/Zage tube and fin intercooler that I have is barely rated for 400hp and at that point my turbo becomes a hair dryer with all the heat soak, so this new core should really help with IATs on track! Should have it in a few weeks.
The Following 8 Users Say Thank You to ATL BRZ For This Useful Post:
aimforapex (08-24-2018), DustinS (09-04-2018), Irace86.2.0 (08-15-2018), jflogerzi (08-15-2018), JonAvalon (08-15-2018), jubella2 (08-16-2018), MCTeeJ (08-15-2018), Racecomp Engineering (08-15-2018)
Old 08-19-2018, 05:09 PM   #2061
ATL BRZ
ATL BRZ's Avatar
More progress!
Installed the turbo and Blitz oil cooler.
The kit fit perfectly with the exception of the upper bracket, which is meant to be secured to the stock crash beam. The two lower brackets support the core and duct assembly very well and I have a couple zip ties on the upper mount for now. It's very sturdy. The only difference in the 2017+ bumper is the left side of the shroud has less material to clear the inside of the bumper.
The Following 3 Users Say Thank You to ATL BRZ For This Useful Post:
aimforapex (08-24-2018), TheStig85 (08-19-2018), Trust86 (08-19-2018)
Old 08-19-2018, 09:54 PM   #2062
Trust86
Drives: 2016 Halo FRS
Does the blitz kit use banjo style fittings on the sandwich plate? Also would that almost 180 degree fitting on the core cause a pretty significant pressure drop? Just curious, been reading up on oil coolers and fittings/pressure drop before I order one. Just don’t know what kit I want to go with.
Trust86 is offline   Reply With Quote
Old 08-20-2018, 09:20 AM   #2063
ATL BRZ
ATL BRZ's Avatar
Yes they are banjo fittings on the sandwich plate. No, the fitting on the core won't cause a significant pressure drop. When using an oil cooler it is advisable to step up to a 30 weight engine oil or higher if your tracking the car to keep the pressures up when hot. This kit is among the best on the market. The quality is exceptionally high and the fitment is perfect. I wouldnt hesitate to get it and if you're worried about pressure then there are four different 1/8 PT ports for temp/pressure sensors on the sandwich plate.
Old 08-23-2018, 05:24 PM   #2064
ATL BRZ
ATL BRZ's Avatar
New bumper is back from paint
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
DocWalt (08-28-2018), DustinS (08-24-2018)
Old 08-24-2018, 12:47 AM   #2065
TeutonicShift89
TeutonicShift89's Avatar
Drives: '13 LAVA - lightly modded
OOOOOOH---well, don't just sit there put it on already
You are going to be condemned to live out the consequences of your taste - TM
TeutonicShift89 is offline   Reply With Quote
The Following User Says Thank You to TeutonicShift89 For This Useful Post:
ATL BRZ (08-24-2018)
Old 08-24-2018, 09:52 AM   #2066
aimforapex
aimforapex's Avatar
Drives: car
Good to see you making very good progress. Looks like it almost ready for the track.
aimforapex is offline   Reply With Quote
The Following User Says Thank You to aimforapex For This Useful Post:
Old 09-03-2018, 07:35 PM   #2067
ATL BRZ
ATL BRZ's Avatar
Finished up and got it running yesterday!
Was so nice to hear it rumble again after nine months.
New bumper is looking good with the Verus carbon fiber canards. The brake ducts went on perfectly with the new brackets for the '17 bumper. Thinking about running without the mustache and grille piece for now. If I do install it I will probably trim the lower grille section off completely as I did before.
Still need to install the new splitter and the hood and it should be good to go! Once I get the new intercooler that will go on too
aimforapex (09-06-2018), DustinS (09-04-2018), TheStig85 (09-06-2018), Tristor (09-03-2018), Zer0 (09-05-2018)
Old 09-06-2018, 12:07 AM   #2068
pearlhatchiroku
pearlhatchiroku's Avatar
Drives: pearl white eighty six
Glad to see your car is up and running again. That's a very sinister looking front end.
Did you also change the valves, or just went with the valve springs and retainer kit?
pearlhatchiroku is offline   Reply With Quote
Old 09-06-2018, 07:14 PM   #2069
ATL BRZ
ATL BRZ's Avatar
Thank you!
Still using the stock valves, just GSC single springs with retainers. The stock heads flow pretty well for the power levels I'm looking at.
The Following User Says Thank You to ATL BRZ For This Useful Post:
pearlhatchiroku (09-06-2018)
Old 09-10-2018, 03:44 PM   #2070
ATL BRZ
ATL BRZ's Avatar
Buttoned everything up and took it out for a short spin around the block to ensure all is well with the tune. Not too much longer now before I can get into boost again!
[ame]https://www.youtube.com/watch?v=0qe_KFIXRhM[/ame]
DocWalt (09-10-2018)
Old 09-10-2018, 05:50 PM   #2071
Lust
Drives: 2017 Subaru BRZ
Free weekend time has been hard to come by, but the hot parts are wrapped with DEI Inferno
and the engine is back in!
Going to start reconnecting everything tomorrow and hopefully start putting the turbo kit back on!
That looks like a lot of overlap. Is that what DEI told you to do?
Lust is offline   Reply With Quote
Old 09-10-2018, 05:56 PM   #2072
ATL BRZ
ATL BRZ's Avatar
It's not a DEI wrap, so no. I followed the instructions from HSP as best I could, though.
EDIT: realized that I stated it was a DEI wrap originally by mistake. I've edited my original post to correct that.
Zer0 (09-11-2018)
jdl turbo, mazworx, racecomp engineering, track build, verus engineering
Wnt3d's 86 - Turbo E85 Daily/Track Build wnt3d Member's Car Journals 77 07-17-2017 03:35 PM
No Limit Motorsport Full Blown BRZ Build No Limit Motorsport Member's Car Journals 16 07-08-2014 12:46 PM
