#127 | |
Drives: 10 Series #895
ISO cheap led halo fogs peeps! Sent from my SM-G950U using Tapatalk
PDX86 / 86 Sessions / 86Squad / DarkSquad
#128 |
Drives: 2015 Firestorm FRS
#129 |
Drives: 2015 FRS
So I bought an HID kit and projector that's supposed to fit the stock FRS headlights. Does anyone know if I were to buy Valenti headlights if it would still fit as if they were also stock? Not sure how the interior of the valentis look.
#130 |
Anyone have the 2017+ Toyota headlight wiring diagram? I want to put it on my FRS. Thanks
#131 | |
Did you mean these headlights?: http://www.ft86club.com/forums/showthread.php?t=83144 The valenti jewels require the OEM HIDS which you don't have in an FR-S
#132 | |
Drives: 2015 Scion FR-S (halo)
I wanted to add an LED strip to the fog light bezel of my 2015 FRS, know of any good brands that make it?
#133 | |
Drives: 2013 WRB BRZ Limited
other wards universal strips maybe from DiodeDynamics or TheRetrofitSource? -B |
#134 |
Drives: Golf TDI for now
Are there any decent upgrade options for a stock halogen headlight on a 2013 FRS if I don't want to disassemble/bake/etc?
Are any of the LED plug and play options worthwhile? |
#135 | |
However they aren't going to have anywhere near the precision cutoff of a retrofit LED projector install as you already know, but right now they are very good from what I've seen. The LED headlight bulbs from morimoto and diode dynamics are pretty good, technology on LED bulbs has come along way, and they have pretty good cutoff and seem to match the stock bulbs beam pattern pretty well. I've got the morimoto 2 strokes on my CX-5 and they never needed any adjustment and the light output is way way better. I'm planning on taking the HIDs out of my winjets on my FR-S and possibly buying them for it as well. The HIDs from my diode dynamics on my winjets are starting to take a bit longer to warm up then they did when new and an LED upgrade would definitely fix that. So either Diode dynamics SL leds or morimotos 2 strokes would probably be best
#136 | |
LED bulbs optics do not work out very well in projectors. If you don't plan on doing opening the headlights and swapping the projectors out for proper HID ones, i recommend just a basic Morimoto HID kit for your car from www.TheRetrofitSource.com There is no need for extra harnesses for your car either. -B |
#137 |
| The Following User Says Thank You to Akrochik For This Useful Post: | HeresMyMind (09-22-2018) |
#138 |
Another noob q: what's the benefit of paying 3-4x more for something like this? Or is there none for this car?
https://www.theretrofitsource.com/h1...oto-elite.html |
#139 | |
(this does NOT work with BRZ's) This kit replaces all the internals with HID specific components that will be much brighter than oem projectors with HIDs in them. They are also bixenon which means they are both a low beam and a highbeam. They do require you to open up the headlights, but the install is pretty straight forward. This is the next best option besides upgrading to OEM BRZ headlights. -B |
#140 |
Drives: 2016 FRS
What size led's will fit in winjet fog lights? Thanks!
| OEM foglight install question | DarkSideFRS | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 06-12-2017 04:21 PM |
| FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides | Verge | Exterior Parts (Aero, Lighting, Etc.) | 12 | 11-21-2014 09:56 PM |
| Automation Lighting offers HID xenon headlight + foglight kits | jjdrivesajazz | Exterior Parts - Lighting | 138 | 01-13-2014 02:19 AM |
