Old 09-04-2018, 03:23 AM   #71
alf
alf's Avatar
here you go:
https://datazap.me/u/alf/log-1536041584 - hwy
https://datazap.me/u/alf/log-1536041844 - street
alf is offline   Reply With Quote
Old 09-04-2018, 08:50 PM   #72
Kodename47
Kodename47's Avatar
Drives: UK GT86
The engine should not be knock limited unless you start loading it with heat and/or high load. Therefore if you can only have poor fuel, just don't go crazy. Highway, town or city driving should be a non issue. The car manual in the UK says that 95RON is fine, just expect poorer performance. That is probably around 88/89 Octane in US terms.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-06-2018, 12:27 PM   #73
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by alf View Post
IAM is 0 it definitely does not like it unless that's a data-logging glitch, and that FLKC holy balls thats bad
Old 09-06-2018, 12:52 PM   #74
steve99
Drives: FT86
Hmmm
That looks pretty ugly
However
FLKC up to -20 I did not even know it could go that high
The IAM=0 are possibly logging glitchs
But looking at KC_Learned it looks like iam might be very low like 0.3
what tune are you running ?? if oft want version ?? ie V4 ? so we can see if its logging issue
what is your ECU calibration ID like ZA1JB01C
You would rearly want to make some substiantial changes to tune to try to reduce the level of knock for long term use and as I understand it you not on pure 87 either.
for starters id pull at least 6 to 8 degrees out of the map over the entire rpm range
richen your closed loop fueling
if you don't see a very substiantal reduction in knock then it likely the engine wont cope with 87 no matter what you do due to the 12.5:1 compression ratio.
The first thing that went on these cars subject to knock in early days was the direct injector seals, they are quite expensive and difficult to replace and not the sort of part that will be available on back road garage.
But first you need to run a tune that logs correctly with a bunch of timing reduction
The Following 2 Users Say Thank You to steve99 For This Useful Post:
FRSBRZGT86FAN (09-08-2018), solidONE (09-08-2018)
Old 09-08-2018, 02:02 AM   #75
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You know @steve99, as bad as that flkc looks it seems to resemble tip in knock. Though that -24.53 flkc looks pretty scary.
Intent > Content
Old 09-08-2018, 02:08 AM   #76
FRSBRZGT86FAN
I'm curious if this happens on the stock tune, I'm not sure what tune OP is running either
Old 09-08-2018, 02:14 AM   #77
steve99
Drives: FT86
Im pretty sure the max flkc is like -6 degrees, so i think the flkc and the iam are bogus logging issues
I think hes probably eunning a old v2 oft tune which didnt log properly on anything past a B01C or D rom
Old 09-08-2018, 08:33 PM   #78
alf
alf's Avatar
Is IAM the same as "Adv Multiplier" in OFT?
I have it at 0 across the board on 91 as well.
BTW it is '17 car and relatively new OFT.
Old 09-08-2018, 10:17 PM   #79
FRSBRZGT86FAN
Make sure the OFT is updated and I believe it is, it should be 1 on 91 or 93 octane. Also as the manual states make sure your running 93 if its available
Old 09-08-2018, 11:19 PM   #80
steve99
Drives: FT86
you need to run oft V4 tunes for logging to work
if your calid is say ZA1JK00C then search that calid on openflash support site. then download tunes , upload to oft and flash to car. logging will then work
https://support.openflashtablet.com/...7-us-6mt-v4-03
also update you oft template file
https://support.openflashtablet.com/...OJv0eWrG3dA%3D
Old 09-15-2018, 07:53 PM   #81
alf
alf's Avatar
Steve,
Thanks for the info. I was not aware of V4 until now. I will report results of running 87 grade fuel with V4 soon.
I wonder though how those maps change how OFT monitors data. Are actual values (like "Knock Corr." or "KC Learned" located at different RAM addresses in ECU?
Also I am not sure what are templates for. I just grab CVS files from OFT and upload to datazap. Are templates used for Excel?
A.
Old 09-16-2018, 02:46 PM   #82
steve99
Drives: FT86
Steve,
A.
Template files allow oft to display log parameters correctly, templates are loaded into oft
mixing e85 (109 octane) with e15 (91 octane) pcguru2000 Engine, Exhaust, Transmission 19 03-08-2022 11:35 PM
100 Octane? hellyvin Northern California 23 07-24-2017 09:01 PM
Do you use 93% octane RichardsFRS Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 62 02-09-2016 12:21 AM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 02:23 AM
93 Octane? ashtray BRZ First-Gen (2012+) — General Topics 175 04-04-2012 01:22 PM
