Old 09-01-2018, 02:24 PM   #29
R_E_L
He's got this.
R_E_L's Avatar
Drives: 50th Anni BRZ
Originally Posted by 86MLR View Post
Like dis
That would be great, were you able to weigh it like that?
Don't worry, I'm certified... promise.
R_E_L is offline   Reply With Quote
Old 09-01-2018, 07:29 PM   #30
86MLR
86MLR's Avatar
I'll take one into work when I get a chance
The Following User Says Thank You to 86MLR For This Useful Post:
R_E_L (09-02-2018)
Old 09-03-2018, 08:03 PM   #31
MrClean614
Drives: 981 Boxster, ‘24 Emira
Can someone confirm whether or not the Eibach bolt on spacers will work with the factory Performance Pkg wheels?
My concern is that the bolt on ones require the wheels have pockets on the backside to clear the factory studs when the spacer is bolted down.
http://www.ft86speedfactory.com/eiba...l#.W428oxopChC
MrClean614 is offline   Reply With Quote
Old 09-03-2018, 09:22 PM   #32
MrClean614
Took my wheel off, found a 20mm H&R spacer with 5x100 pattern and did some measurements with dial calipers. Appears I have about 0.050”-0.085” clearance between the poke of the studs through the spacer and the recessed area of the wheel pockets.
Poke: ~0.175”
Pocket: 0.225” to 0.260”
Still couldn’t hurt to have someone with actual use confirm.
Thanks!
Old 10-19-2018, 01:38 AM   #33
FremontSubaru
FremontSubaru's Avatar
Drives: 2018 BRZ P/P
Just for reference:
slightly used 2018 PP BRZ wheel and tire combo weight on my industrial scale: 39.5 lbs
new WedsSport TC105N 17x9 +35 and 255/40/17 RE71R combo: 15.5 + 24 = 39.5 lbs
with weights and brake dust should be about 40 lbs
FremontSubaru is offline   Reply With Quote
Old 04-17-2020, 04:17 PM   #34
alphadubs
Drives: 2018 BRZ PP
Did you ever get a chance to weigh it?
alphadubs is offline   Reply With Quote
Old 04-17-2020, 07:31 PM   #35
N_Raged
Drives: 2019 BRZ Sport-Tech RS
https://www.ft86club.com/forums/show...&postcount=600
N_Raged is offline   Reply With Quote
2017 BRZ Performance Package Brembo Brakes Part Numbers Veloist Suspension | Chassis | Brakes -- Sponsored by 949 Racing 146 04-27-2023 10:36 AM
To get the Performance Package or Not? Thread Zaku BRZ First-Gen (2012+) — General Topics 141 12-06-2016 11:04 PM
*Wheels Collection* Winter Package 2015-2016 (Alloy Wheels + Tires) wheelsco Canada Classifieds 4 10-08-2015 04:55 PM
Specs on PRS BRZ Wheels Bach415 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 12-01-2014 02:54 PM
Dyno results for the Nameless Performance street package! John@Nameless Announcements, Contests, Giveaways 31 06-26-2012 05:37 AM
