Old 08-24-2018, 12:45 PM   #1
msaikhan
Drives: frs
understeer over the shallowest puddles on highway
car: scion frs all stock with uel & q300 , stock tires(worn threads)
So, i was going on the highway about 65mph, and the highway starts curving to the right and it was raining. I see few puddles just streaming across the highway, not deep at all, less than 1 inch. And there are like 3 streams just going across the highway about 2 foot wide. As soon as i go over each puddle, i feel the car understeers and goes straight till i get over the puddle. Does this happen to others as well? or is it just my tires dying on me. It's pretty sketchy feeling, since this never happened to me driving other cars.
msaikhan is offline   Reply With Quote
Old 08-24-2018, 01:06 PM   #2
BigTuna
BigTuna's Avatar
Drives: 2013 WRB BRZ
https://en.wikipedia.org/wiki/Aquaplaning
BigTuna is offline   Reply With Quote
The Following 3 Users Say Thank You to BigTuna For This Useful Post:
Brooklyn (08-27-2018), mrderp (08-31-2018), Tcoat (08-24-2018)
Old 08-24-2018, 01:23 PM   #3
Originally Posted by BigTuna View Post
This ^
Drive to the conditions.
/thread
mrderp (08-31-2018)
Old 08-24-2018, 01:40 PM   #4
Welcome to ye ol forum, msaikhan -
Well, what you are experiencing is most likely due to a combination of warn tires and a relatively light car.
The "fix" is to get new tires and then slow down when you see water puddled (streaming) over the road. If it sneaks up on you, don't try to compensate, just ride through it.
Old 08-24-2018, 01:54 PM   #5
johan
Drives: '14 981CS, '99 NB1
Get good all season tires and this will greatly reduce this effect. The stock tires are crappy summer touring tires. They're terrible in wet climates, well really just terrible all around.
I rolled on 245 wide DWS06 and drove through an incredibly wet winter here in Oregon without issue. Usually wider tires mean more hydroplaining - having good tires make all the difference.
johan is offline   Reply With Quote
Old 08-24-2018, 03:16 PM   #6
Clipping_Path
Drives: 13 FRS – Whiteout
Though I've read countless reviews espousing their rain performance, I have a lot of sketchy moments with my Super Sports. Any all season tire seems to handle better in wet conditions.
Clipping_Path is offline   Reply With Quote
Old 08-24-2018, 03:32 PM   #7
Brink
Drives: 2017 BRZ
Stock tires which are terrible in wet to begin with, plus they're worn? Yeah, you're gonna have a bad time doing 65 mph through puddles. I changed out my stock tires after I fishtailed on a turn on wet roads when the tires were basically new (<5k miles). Had plenty of space to correct safely but I still came away from it feeling like a different set of tires would have held the corner under those conditions.
Brink is offline   Reply With Quote
Old 08-24-2018, 04:43 PM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
You've already answered your question
Stock tires are bad in heavy rain as it is, but being worn exacerbates the effect of aquaplaning.
If you want summers that perform well in the rain get Michelin Pilot super sports
If you want ok performance in heavy rain, very light snow and dry with a trade-off to a bit of handling get some all seasons
Old 08-24-2018, 04:47 PM   #9
bkharmony
bkharmony's Avatar
Drives: 2017 86GT
Assuming "threads" means "tread," I think you're very close to discovering the answer.
bkharmony is offline   Reply With Quote
Old 08-24-2018, 05:02 PM   #10
Brink
Drives: 2017 BRZ
It's the exhaust, right? I'm pretty sure the exhaust is causing this.
The Following User Says Thank You to Brink For This Useful Post:
bkharmony (08-24-2018)
Old 08-24-2018, 09:26 PM   #11
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Yea, Aquaplaning
ToySub1946 is offline   Reply With Quote
Old 08-24-2018, 09:40 PM   #12
Decep
Drives: 2013 FR-S Series 10
that's weird. My MPSS are ridiculous in the rain, can keep on trucking at the speed limit when people are slowing down to 45mph. 215s on 17x8.
The Following User Says Thank You to Decep For This Useful Post:
guybo (08-28-2018)
Old 08-24-2018, 10:27 PM   #13
Clipping_Path
Same spec as mine - I do have a good 25k on them.
Old 08-24-2018, 10:46 PM   #14
Impureclient
Drives: 2015 FR-S
Weird that MPSS come up in a conversation about hydroplaning as a cure for it. Did a couple 360s on wet road on my MPSS. The car would slide around super easy in the dry too like it was wet out.
I wouldn't recommend them at all. I even took them off before they were worn because I didn't want to wrap the car around a pole or slide into somebody. At I think 12k, they were taken off and still had
maybe a couple thousand more miles left on them at best. Maybe I had Chinese made replicas?
Why does car understeer when going downhill? hpde_addict Tracking / Autocross / HPDE / Drifting 20 01-15-2018 10:42 AM
Understeer after new wheels carsebuco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-04-2017 06:49 PM
understeer on 17 brz alex.s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 09-11-2017 05:05 AM
Not understeer, not oversteer... something else? Mazikowski Tracking / Autocross / HPDE / Drifting 15 07-25-2016 10:24 PM
Do pigs understeer? Thrustin Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2014 10:42 AM
