Old 08-05-2018, 10:52 AM   #1
COBlue
COBlue's Avatar
Drives: 2017 Subaru BRZ Limited PP
Oil drain valve recs
I'm considering putting in an oil drain valve to make life easier. Curious:
1) For those using Fumoto - any long term issues with leaks? Ground clearance? (I'm stock height)
2) Anyone using or have opinions on any others? (EZ Oil, Femco, NoSpill, Stahlbus)
Thanks!
COBlue is offline   Reply With Quote
Old 08-05-2018, 11:04 AM   #2
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Fumoto here.
Changed the oil again last week.
No leaks. It's above the under fairing.
Can drain directly into old empty 1gal jugs. No oil drainpan cleanup.
Shweet!
COBlue (08-05-2018)
Old 08-05-2018, 11:41 AM   #3
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I also have a Fumoto. If you go with that, make sure you get the part with the shorter nipple.
No leaks for me, and I remember laughing maniacally at how easy it makes oil changes the first time I used it. If you do your own work I highly recommend it. I also got the little plastic locking clip for added peace of mind, though it's not really necessary.
Spuds is online now   Reply With Quote
The Following User Says Thank You to Spuds For This Useful Post:
COBlue (08-05-2018)
Old 08-05-2018, 11:46 AM   #4
KMA KiCKz
Certified Wumbologist
KMA KiCKz's Avatar
Drives: 2015 Scion FR-S
I too have a Fumoto valve with the little clip to also give me reassurance that it won't open on its own.
Had it for about a year and a half with no issues so far.
I'm on coilovers with a mild drop and have no issues with ground clearance.
Highly recommend!
KMA KiCKz is offline   Reply With Quote
The Following User Says Thank You to KMA KiCKz For This Useful Post:
COBlue (08-05-2018)
Old 08-06-2018, 03:41 AM   #5
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
I use the Fumoto valve with clip. Tracked and daily it. Seems to work fine. No leaks or issues.
I'm lowered about 1.5" (moderate). The metal engine tray sits lower than the lowest point of the valve, so that helps protect the area.
EndlessAzure is offline   Reply With Quote
Old 08-06-2018, 08:33 AM   #6
czechm8
520
czechm8's Avatar
Drives: Series 10 Fr-s #520
I use Fumoto on all my vehicles. Never had a leak or any problems. I've had one on my Sequoia for 13 years.
czechm8 is offline   Reply With Quote
Old 08-06-2018, 09:19 AM   #7
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I've had a Fumoto valve on my BRZ for almost 3 years now, no issues.
Trueweltall is offline   Reply With Quote
The Following User Says Thank You to Trueweltall For This Useful Post:
COBlue (08-06-2018)
Old 08-06-2018, 01:51 PM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I've had the Fumoto for a couple years. Just get the one with no nipple or the short nipple.
Mine has even take a hit from a decent piece of debris (it dented the metal skid plate) and still no leaks.
COBlue (08-06-2018)
Old 08-07-2018, 04:26 PM   #9
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
if you live in an apartment or don't want to ever get under the car you can just use an oil drain pump. Put a tube down the dip stick hole and pump a few times and all the oil gets siphoned out. No jacks, never have to remove the oem oil drain plug, no getting on the ground, and can be done when the engine is hot.
Something similar to this. Just throwing out an alternative. :-)
https://www.amazon.com/Mityvac-7201-...words=oil+pump
TachyonBomb is offline   Reply With Quote
The Following User Says Thank You to TachyonBomb For This Useful Post:
FLYFISHR (08-25-2018)
Old 08-22-2018, 01:02 AM   #10
reeves
6 years and 70K+ miles on my Fumoto valve.
No nipple, no clip. I travel on dirt roads and gravel in rural areas too (stock height).
No problems so far.
The Following 2 Users Say Thank You to reeves For This Useful Post:
COBlue (08-22-2018), gravitylover (08-24-2018)
Old 08-22-2018, 01:20 PM   #11
radroach
Drives: car
@TachyonBomb until somebody makes a video of them doing a topside oil change successfully on their 86, I'm going to wait. I don't want to be the guy to report getting the tube stuck in the dipstick hole.
I have a fumoto valve and its nice. I checked it this morning and it was dirty but didn't seem like any oil has seeped from the drain hole.
The Following User Says Thank You to radroach For This Useful Post:
COBlue (08-22-2018)
Old 08-24-2018, 10:14 AM   #12
gravitylover
I got a decent pump and tried to do it this way and nearly got the hose stuck in there. It was caught on something and it took me a good 10 minutes of wiggling to get it loose. At that point I had only pumped out about 1 quart of oil so it still needed to be pushed further in but there was no way I was going to risk that. I had visions of getting it towed to a shop and having to drop the oil pan to get the hose unstuck without leaving bits of it to get stuck somewhere in the motor.
The Following User Says Thank You to gravitylover For This Useful Post:
radroach (08-24-2018)
Old 08-24-2018, 10:46 AM   #13
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Another vote for Fumoto, I've had mine for almost a year and love it.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 08-24-2018, 12:26 PM   #14
radroach
Drives: car
@gravitylover which specific brand pump did you try (and fail) with?
Some guy was all over my car the other day telling me I needed to do a topside change. On other cars maybe, I explained, but on subarus the dipstick is too narrow
jbsali (08-24-2018)
First Oil Change, Fumoto Oil Drain Valve oldnotdead Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 29 07-23-2021 12:39 PM
FS: Fumoto Drain Valve turbos86 Engine, Exhaust, Bolt-Ons 2 03-15-2017 06:41 PM
Greddy Magnetic Oil Drain Plug or Fumoto Drain Valve? tracerit Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 01-04-2016 07:36 PM
SOLD - Fumoto F108 Oil Drain Valve - NEW ZZT86 Australia Classifieds 0 09-25-2015 05:03 AM
GROUP BUY: Fumoto Drain Valve Simon99 Mechanical Maintenance and Tools 8 03-28-2014 06:27 PM
