Old 08-20-2018, 10:55 PM   #29
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by DandoX View Post
That price sounds too high.
OEM clutch part should be around 230-250
I had my TOB and new clutch installed out the door at $621.60
Look how fast someone familiar can take out the trans:
http://www.ft86club.com/forums/showp...7&postcount=44
Either way man I suggest getting your TOB replaced since someone will be up in there anyway (TOB=$50). Also check your flywheel you may not need it resurfaced/replaced. I'm at 70k and my flywheel looked great. However be prepared to resurface/replace the flywheel if needed.
Remarkable. If I ever need that done, I'm going to make my wrench watch that video first.
Qwimby1 is offline   Reply With Quote
Old 08-21-2018, 09:08 AM   #30
gravitylover
Originally Posted by JazzleSAURUS View Post
Don't worry, my wife is HELLA pregnant so she requires too much attention to take on side jobs these days.
I can point you in the direction of a few enthusiast shops for future reference to avoid the chain shops who have no idea what they are doing.
Congratulations!
That's a good idea for a new thread. Probably in the New England regional subforum and put a link in the NY/NJ/CT sub too. A list of recommended enthusiast shops would be a good resource.
Old 08-21-2018, 09:36 AM   #31
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
Originally Posted by gravitylover View Post
Congratulations!
Appreciate it! I did have to ditch the BRZ for car seat room, but I found a pretty clean V8 4Runner should should be fun too!
JazzleSAURUS is offline   Reply With Quote
The Following User Says Thank You to JazzleSAURUS For This Useful Post:
gravitylover (08-21-2018)
Old 08-21-2018, 01:50 PM   #32
Just need taller jack stands.
JazzleSAURUS (08-22-2018)
Old 08-22-2018, 09:22 AM   #33
JazzleSAURUS
I actually use the 6 ton truck stands. It's awesome being able to get a regular car up 2 feet in the air to work under without struggling for space.
Edit: I did get the joke, it was awesome, but I already have the big stands haha. So maybe she can take on a clutch job.
Ultramaroon (08-22-2018)
Old 08-22-2018, 02:05 PM   #34
JazzleSAURUS (08-23-2018)
clutch, replacement, transmission
DIY Clutch Replacement Supermassive DIY (Do-It-Yourself) Guides 217 08-27-2023 01:35 PM
Clutch replacement pinetree Engine, Exhaust, Transmission 21 05-03-2017 09:48 AM
Exedy OE replacement clutch. APEXIT53 Transmission and Driveline 2 04-08-2017 09:54 AM
Clutch replacement Thatguyjeremy Engine, Exhaust, Transmission 0 02-28-2015 05:22 AM
Clutch/flywheel replacement? bucket BRZ First-Gen (2012+) — General Topics 1 11-19-2012 01:25 PM
