Old 05-05-2018, 12:38 AM   #1
muz.mohammad
Drives: 2015 Scion FR-S RS 1.0
2015 Scion FRS Unusual Window Issue
Hello guys.
I am having issue with my driver side window not automatically coming down and back up upon door open and close.
This is not typical winter freeze.
I don't have the lights flashing on window switches.
Here's what happened.
After washing the car, while wiping it down, I accidentally pressed the push button switch for the door light while the door was open. The car obviously thought that the door has been closed and automatically raised the window. But, since the door was open, the window did not have a stopping point, so it went up past its normal stopping point. After that it the automatic function stopped working.
I have tried resetting by holding the window switch for 10 seconds...didn't work.
I can actually not even hold the window up while door is closed, because as soon as the window hits the top, it comes back down like 6 inches.
Not sure how to fix it.
Dealership in my area are not fixing the issue even though the car is under bumper to bumper warranty.
Please help!
muz.mohammad is offline   Reply With Quote
Old 05-05-2018, 01:01 AM   #2
Originally Posted by muz.mohammad View Post
Hello guys.
Please help!
Put the window all the way down and disconnect the battery for a minute. Should reset everything.
BirdTRD (05-05-2018), funwheeldrive (08-17-2018)
Old 06-15-2018, 10:24 AM   #3
muz.mohammad
Thank you. I’ll give that a try and get back to you.
The Following User Says Thank You to muz.mohammad For This Useful Post:
Tcoat (06-15-2018)
Old 06-15-2018, 11:09 AM   #4
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
FYI the window switch reset is holding for 10 seconds down, and then holding for 10 seconds up. Not sure if you did both, but if you only held it for 10 seconds in one direction, the reset may not have happened properly.
Good luck.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 06-15-2018, 04:24 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Hello guys.
Please help!
Make sure you've done the window reset procedure properly, also you can always go to a different dealership
Old 08-17-2018, 11:19 AM   #6
muz.mohammad
Window down, disconnecting battery did not work.
I feel like the motor timing is out or something.
Old 08-17-2018, 03:09 PM   #7
Brz_racer
Drives: Subaru BRZ
Did you try closing the door with the window all the way down, then rolling it up with the door closed? There is a stop at the full up and down positions to keep the window from going too high or low, although incant imagine you have a broken stop I suppose it is possible, the only way to tell would be to remove the door panel and get a good look in there.
Brz_racer is offline   Reply With Quote
brz, frs, window
window issue twag4 Issues | Warranty | Recalls / TSB 2 03-29-2017 12:15 AM
Window issue after window replacement Gabzor Issues | Warranty | Recalls / TSB 11 03-03-2017 06:48 AM
Window Reset Issue finch1750 Issues | Warranty | Recalls / TSB 2 12-19-2016 05:26 PM
Driver Side Window Issue kevinchavarria Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-27-2016 12:28 PM
passenger window issue =.= Jeong Issues | Warranty | Recalls / TSB 0 03-13-2013 09:19 PM
